Hello, I am trying Cassini Nova release in Virtualbox.
During installation I created swap partition and the system booted fine. Then I created RAID0 on another 2 disks and created swap on it. Updated resume=
option in /etc/default/grub
and UUID in etc/fstab
Ran grub-mkconfig -o /boot/grub/grub.cfg
and dracut --force
and now it is stuck during boot after mounting ZFS root on A start job is running on /dev/disk/by-uuid/7b8e9413-c312-44da-9b6e-2291be027343
Some related info below:
[root@nbpg0603vm ~]# lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
sda 8:0 0 15G 0 disk
├─sda1 8:1 0 1000M 0 part /boot
├─sda2 8:2 0 1000M 0 part
├─sda3 8:3 0 8M 0 part
├─sda4 8:4 0 512M 0 part /boot/efi
└─sda5 8:5 0 6,8G 0 part
sdb 8:16 0 5G 0 disk
├─sdb1 8:17 0 8M 0 part
├─sdb2 8:18 0 512M 0 part
├─sdb3 8:19 0 1000M 0 part
│ └─md126 9:126 0 1,9G 0 raid0
├─sdb4 8:20 0 1000M 0 part
│ └─md125 9:125 0 1,9G 0 raid0 [SWAP]
└─sdb5 8:21 0 2,5G 0 part
└─md127 9:127 0 5,1G 0 raid0
├─md127p1 259:0 0 5,1G 0 part
└─md127p9 259:1 0 8M 0 part
sdc 8:32 0 5G 0 disk
├─sdc1 8:33 0 8M 0 part
├─sdc2 8:34 0 512M 0 part
├─sdc3 8:35 0 1000M 0 part
├─sdc4 8:36 0 1000M 0 part
└─sdc5 8:37 0 2,5G 0 part
sr0 11:0 1 1,9G 0 rom
[root@nbpg0603vm ~]# blkid
/dev/sdb4: UUID="0f80200e-653f-20b2-e47e-b227f55ceadf" UUID_SUB="766c2b76-2e2f-c52d-0280-0a3ffda00ffe" LABEL="nbpg0603vm:swap" TYPE="linux_raid_member" PARTUUID="1872a0d1-8545-496c-abc7-85ebbf85cb33"
/dev/sdb5: UUID="9f07b10d-30a2-2c24-d45e-d535452b0b05" UUID_SUB="970f5efd-0ff8-c2c1-46c5-2ddc8b1ed338" LABEL="nbpg0603vm:root" TYPE="linux_raid_member" PARTUUID="b20a90e0-e643-4991-9cbf-208cd1376f41"
/dev/sdb3: UUID="f3b4478f-7c98-1910-ce42-7a6884952a55" UUID_SUB="ccb0398a-ed96-5e7c-3dbf-a8fa4f838677" LABEL="nbpg0603vm:boot" TYPE="linux_raid_member" PARTUUID="e4b4706a-468d-4527-9c6d-c40e887859c3"
/dev/sr0: BLOCK_SIZE="2048" UUID="2023-05-28-11-02-36-00" LABEL="EOS_202305" TYPE="iso9660" PTUUID="b15bb315" PTTYPE="dos"
/dev/sdc5: UUID="9f07b10d-30a2-2c24-d45e-d535452b0b05" UUID_SUB="4f61d318-d7c8-5659-465a-f60c56708dd8" LABEL="nbpg0603vm:root" TYPE="linux_raid_member" PARTUUID="2ce72cf4-557f-495e-8b24-d23e0f5e65a6"
/dev/sdc3: UUID="f3b4478f-7c98-1910-ce42-7a6884952a55" UUID_SUB="c7a23842-e36e-c30b-8a6b-a903bebb6106" LABEL="nbpg0603vm:boot" TYPE="linux_raid_member" PARTUUID="afb4d604-169d-4f15-8227-f734fc5c6083"
/dev/sdc4: UUID="0f80200e-653f-20b2-e47e-b227f55ceadf" UUID_SUB="44f1b4ac-690d-cc80-ccff-e85ac80eb5ab" LABEL="nbpg0603vm:swap" TYPE="linux_raid_member" PARTUUID="5414f4a6-e0dd-4b61-8494-25e53841e6d2"
/dev/sda4: LABEL_FATBOOT="EFI" LABEL="EFI" UUID="ED76-E911" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="d34f522a-ab79-4dda-b46b-9f90f8403d82"
/dev/sda5: LABEL="zpendeavouros" UUID="8206987191204923832" UUID_SUB="6749455970033933757" BLOCK_SIZE="4096" TYPE="zfs_member" PARTUUID="2587dadd-7d23-4a6e-bc69-420a41ae28f4"
/dev/sda1: LABEL="BOOT" UUID="b8bb1b28-ab6b-4759-bd8c-d7c8d59b62c0" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="c3f54808-945a-45c9-bd6d-404084622e84"
/dev/md127p1: LABEL="zpendeavouros" UUID="8206987191204923832" UUID_SUB="12164798272366758411" BLOCK_SIZE="4096" TYPE="zfs_member" PARTLABEL="zfs-544b578bb8fa0859" PARTUUID="3f09c016-5b26-6543-868a-716d236bad48"
/dev/md125: LABEL="SWAP" UUID="7b8e9413-c312-44da-9b6e-2291be027343" TYPE="swap"
/dev/md127p9: PARTUUID="99f03426-6501-084b-9804-5dfa8764b72a"
/dev/sdb2: PARTUUID="ba28b77c-4082-46d3-abba-29e15ef30d09"
/dev/sdb1: PARTUUID="99e96e33-0f71-49c8-a424-f84193bf2789"
/dev/sdc2: PARTUUID="7fc5249e-0e25-41d0-81e0-c321ea73946d"
/dev/sdc1: PARTUUID="1e4d4a27-afb7-4610-94ca-efce64d1dc1a"
/dev/sda2: PARTUUID="2347de75-62b0-4a43-9f07-66b73710475a"
/dev/sda3: PARTUUID="9930867c-5770-4567-a0ec-47bae247dd00"
[root@nbpg0603vm ~]# cat /etc/fstab
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=ED76-E911 /boot/efi vfat defaults,noatime 0 2
UUID=b8bb1b28-ab6b-4759-bd8c-d7c8d59b62c0 /boot ext4 defaults,noatime 0 2
UUID=7b8e9413-c312-44da-9b6e-2291be027343 swap swap defaults 0 0
[root@nbpg0603vm ~]# cat /etc/default/grub
# GRUB boot loader configuration
GRUB_DEFAULT='0'
GRUB_TIMEOUT='5'
GRUB_DISTRIBUTOR='EndeavourOS'
GRUB_CMDLINE_LINUX_DEFAULT='nowatchdog nvme_load=YES resume=UUID=7b8e9413-c312-44da-9b6e-2291be027343 loglevel=3 root=ZFS=zpendeavouros/ROOT/eos/root'
GRUB_CMDLINE_LINUX=""
# Preload both GPT and MBR modules so that they are not missed
GRUB_PRELOAD_MODULES="part_gpt part_msdos"
# Uncomment to enable booting from LUKS encrypted devices
#GRUB_ENABLE_CRYPTODISK=y
# Set to 'countdown' or 'hidden' to change timeout behavior,
# press ESC key to display menu.
GRUB_TIMEOUT_STYLE=menu
# Uncomment to use basic console
GRUB_TERMINAL_INPUT=console
# Uncomment to disable graphical terminal
#GRUB_TERMINAL_OUTPUT=console
# The resolution used on graphical terminal
# note that you can use only modes which your graphic card supports via VBE
# you can see them in real GRUB with the command `videoinfo'
GRUB_GFXMODE=auto
# Uncomment to allow the kernel use the same resolution used by grub
GRUB_GFXPAYLOAD_LINUX=keep
# Uncomment if you want GRUB to pass to the Linux kernel the old parameter
# format "root=/dev/xxx" instead of "root=/dev/disk/by-uuid/xxx"
#GRUB_DISABLE_LINUX_UUID=true
# Uncomment to disable generation of recovery mode menu entries
GRUB_DISABLE_RECOVERY='true'
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
#GRUB_COLOR_NORMAL="light-blue/black"
#GRUB_COLOR_HIGHLIGHT="light-cyan/blue"
# Uncomment one of them for the gfx desired, a image background or a gfxtheme
GRUB_BACKGROUND='/usr/share/endeavouros/splash.png'
#GRUB_THEME="/path/to/gfxtheme"
# Uncomment to get a beep at GRUB start
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to make GRUB remember the last selection. This requires
# setting 'GRUB_DEFAULT=saved' above.
#GRUB_SAVEDEFAULT=true
# Uncomment to disable submenus in boot menu
GRUB_DISABLE_SUBMENU='false'
# Probing for other operating systems is disabled for security reasons. Read
# documentation on GRUB_DISABLE_OS_PROBER, if still want to enable this
# functionality install os-prober and uncomment to detect and include other
# operating systems.
#GRUB_DISABLE_OS_PROBER=false
WTF?
When I remove the resume=
option it boots fine (the output above is after removing it).
