Boot and mouse pointer issue
Endeavour KDE installed and updated as per welcome procedure and I also installed some packages, unfortunately two small inconveniences occur: the mouse and sometimes the entire screen freeze apparently for no reason for a few seconds; I don’t know what data can be useful, I can say that I have NVIDIA GRAPHIC CARD RTX 3060 12 GB (I left the default drivers, I haven’t installed nVidia drivers yet), Intel i7 and 32 GB RAM. Then there is the more serious problem: I am in multiboot with Windows 11 and Linux Mint 22.1 at startup Endeavour is present on the GRUB (of Linux Mint, I did not install it with EOS) and starts but the startup freezes and it also freezes when I want to restart from suspend (no screen in this case). I tried with “sudo update-grub” but it does not always work, now I am writing but I do not know if I will be able to access the next time I turn on the computer.
Thanks for your attention
Ciao
EDIT
21.02.2025: just now I did another update with the command
“sudo pacman -Syu”
apparently everything works fine now
22.02.2025: It didn’t last…
(I can’t log in)
Stuck at “a start job is running…”
