Bluez is not working
After the last updates, I have the following problem with bluez:
sudo systemctl status bluetooth
ā—‹ bluetooth.service - Bluetooth service
     Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset>
     Active: inactive (dead)
       Docs: man:bluetoothd(8)
Nov 11 13:35:39 mehriddin-device systemd[1]: Bluetooth service was skipped beca>
Nov 11 13:36:29 mehriddin-device systemd[1]: Bluetooth service was skipped beca>
Nov 11 13:37:26 mehriddin-device systemd[1]: Bluetooth service was skipped beca>
How can I fix the problem?
Hello mehriddin, welcome to EndeavourOS
When I set up my Bluetooth after installing I followed this Discovery article
https://discovery.endeavouros.com/bluetooth/bluetooth/2021/03/
And it may be worth checking this one as well if it is an auto start issue
https://discovery.endeavouros.com/bluetooth/how-to-enable-disable-bluetooth-at-startup/2022/01/
I hope this helps you
