Kernel: 6.7.0-arch3-1 arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12
wm: kwin_x11 vt: 2 dm: SDDM Distro: EndeavourOS base: Arch Linux
Type: Desktop Mobo: Micro-Star model: MPG B550 GAMING CARBON WIFI (MS-7C90)
v: 1.0 serial: UEFI: American Megatrends LLC. v: 1.E0
date: 06/27/2023
Info: 8-core model: AMD Ryzen 7 3800X bits: 64 type: MT MCP smt: enabled
arch: Zen 2 rev: 0 cache: L1: 512 KiB L2: 4 MiB L3: 32 MiB
Speed (MHz): avg: 2297 high: 3900 min/max: 2200/4559 boost: enabled cores:
1: 3900 2: 2200 3: 2200 4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 9: 2200
10: 2200 11: 2057 12: 2200 13: 2200 14: 2200 15: 2200 16: 2200
bogomips: 124855
Device-1: NVIDIA GK208B [GeForce GT 710] vendor: ASUSTeK GT710-4H-SL-2GD5
driver: nouveau v: kernel arch: Fermi 2 pcie: speed: 2.5 GT/s lanes: 1
ports: active: HDMI-A-3,HDMI-A-4 empty: HDMI-A-1,HDMI-A-2 bus-ID: 04:00.0
chip-ID: 10de:128b class-ID: 0300
Device-2: Alcor Micro USB 2.0 PC Camera driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 bus-ID: 1-10:7
chip-ID: 058f:3861 class-ID: 0102
Display: x11 server: X.Org v: 21.1.11 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,nouveau,nv,vesa dri: nouveau
gpu: nouveau display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.00x11.22")
s-diag: 1055mm (41.54")
Monitor-1: HDMI-A-3 mapped: HDMI-3 pos: right model: LG (GoldStar) FHD
serial: res: 1920x1080 hz: 75 dpi: 102
size: 480x270mm (18.9x10.63") diag: 551mm (21.7") modes: max: 1920x1080
min: 720x400
Monitor-2: HDMI-A-4 mapped: HDMI-4 pos: primary,left
model: LG (GoldStar) FHD serial: res: 1920x1080 hz: 75 dpi: 102
min: 720x400
API: EGL v: 1.5 hw: drv: nvidia nouveau platforms: device: 0 drv: nouveau
device: 1 drv: swrast gbm: drv: nouveau surfaceless: drv: nouveau x11:
drv: nouveau inactive: wayland
API: OpenGL v: 4.5 compat-v: 4.3 vendor: mesa v: 23.3.3-arch1.1 glx-v: 1.4
direct-render: yes renderer: NV106 device-ID: 10de:128b
Device-1: NVIDIA GK208 HDMI/DP Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel pcie: speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.1 chip-ID: 10de:0e0f
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
bus-ID: 2c:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Alcor Micro USB 2.0 PC Camera driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.7.0-arch3-1 status: kernel-api
Server-1: PipeWire v: 1.0.1 status: active with: 1: wireplumber
status: active 2: pipewire-alsa type: plugin 3: pw-jack type: plugin
Server-2: PulseAudio v: 17.0 status: active
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: speed: 5 GT/s
lanes: 1 bus-ID: 29:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlan0 state: down mac:
Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: speed: 5 GT/s lanes: 1 port: e000 bus-ID: 2a:00.0
chip-ID: 10ec:8125 class-ID: 0200
IF: enp42s0 state: up speed: 100 Mbps duplex: full mac:
IF-ID-1: pan1 state: down mac:
Bluetooth:
Device-1: Intel AX200 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 bus-ID: 1-9:8 chip-ID: 8087:0029 class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: bt-v: 5.2
lmp-v: 11 class-ID: 6e0104
Local Storage: total: 2.27 TiB used: 1.18 TiB (51.9%)
ID-1: /dev/nvme0n1 vendor: A-Data model: LEGEND 750 size: 465.76 GiB
speed: 31.6 Gb/s lanes: 4 tech: SSD serial: fw-rev: SVN9902
temp: 33.9 C scheme: GPT
ID-2: /dev/sda vendor: Seagate model: ST2000DM008-2FR102 size: 1.82 TiB
speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: fw-rev: 0001
scheme: MBR
ID-1: / size: 456.41 GiB used: 18.16 GiB (4.0%) fs: ext4 dev: /dev/nvme0n1p2
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 34.2 C mobo: N/A gpu: nouveau temp: 43.0 C
Fan Speeds (rpm): N/A
Processes: 490 Uptime: 13m wakeups: 0 Memory: total: 32 GiB
available: 31.27 GiB used: 3.08 GiB (9.8%) Init: systemd v: 255
default: graphical Compilers: gcc: 13.2.1 Packages: pm: pacman pkgs: 1195
Shell: Bash v: 5.2.26 running-in: konsole inxi: 3.3.31
It looks like you have both Pipewire and pulse-audio up and running.
They are probably in conflict, the next step depends on what you would like to do - if you want to remove pulse-audio you could run:
Thank you for your help…yes you are correct and now working perfectly
If you could please mark Strontium’s post as the solution, it would be very helpful ![]()
I found it odd that audio would be causing bluetooth to not work sometimes. ![]()
Edit: Was it a case where audio is being played over a bluetooth connected device?
