Bluetooth once again?
Using earlier releases of EndeavourOS and following the instructions on activating bluetooth, these Smokin’ Buds worked.
This screenshot confuses me as it shows, the Smoking Bud’s, it tried to ‘connect’ then ‘disconnected’ . . . and the following error message above on top say’s ‘br-connection-key missing’. . .
If I try to select a device, nothing shows up. . . . no ‘Smokin Buds’. It just scans . . . showing nothing.
Trying to figure what’s going on. . .
I’m using KDE with the latest ‘Plasma release’. . . .
richardc@richard-ms7c91
./sssso- -----------------------
:osssssss+- OS: EndeavourOS x86_64 :+sssssssssso/. Host: MS-7C91 (1.0)
-/ossssssssssssso/. Kernel: Linux 6.12.34-1-lts -/+sssssssssssssssso+: Uptime: 38 mins -:/+sssssssssssssssssso+/. Packages: 2605 (pacman)
.://osssssssssssssssssssso++- Shell: bash 5.2.37 .://+ssssssssssssssssssssssso++: Display (C32R50x): 1920x1080 @ 75 Hz in 32" [External] .:///ossssssssssssssssssssssssso++: DE: KDE Plasma 6.4.0 :////ssssssssssssssssssssssssssso+++. WM: KWin (Wayland)
-////+ssssssssssssssssssssssssssso++++- WM Theme: Breeze ..-+oosssssssssssssssssssssssso+++++/ Theme: Oxygen (BreezeDark) [Qt], Breeze-Dark [GTK2], Breeze ] ./++++++++++++++++++++++++++++++/:. Icons: breeze-dark [Qt], breeze-dark [GTK2/3/4] :::::::::::::::::::::::::------`` Font: Noto Sans (10pt) [Qt], Noto Sans (10pt) [GTK2/3/4]
Cursor: breeze (24px)
Terminal: konsole 25.4.2
CPU: AMD Ryzen 7 5700 (16) @ 4.65 GHz
GPU: AMD Radeon RX 7600 [Discrete]
Memory: 3.96 GiB / 62.68 GiB (6%)
Swap: 0 B / 12.60 GiB (0%)
Disk (/): 82.70 GiB / 918.90 GiB (9%) - btrfs
Local IP (wlan0): 192.168.1.9/24
Locale: en_US.UTF-8
[richardc@richard-ms7c91 ~]$
Rich;)
I’m terrible at posting. . . . forgive my futile attempt.
Check if the bluetooth service reports some issues.
sudo systemctl status bluetooth.service
[richardc@richard-ms7c91 ~]$ sudo systemctl status bluetooth.service
[sudo] password for richardc:
● bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset: disabled)
Active: active (running) since Sun 2025-06-22 19:25:41 MDT; 9min ago
Invocation: dad36f23eaa84cf3842a128b4b746c91
Docs: man:bluetoothd(8)
Main PID: 849 (bluetoothd)
Status: “Running”
Tasks: 1 (limit: 76989)
Memory: 2.8M (peak: 3.3M)
CPU: 96ms
CGroup: /system.slice/bluetooth.service
└─849 /usr/lib/bluetooth/bluetoothd
Jun 22 19:26:01 richard-ms7c91 bluetoothd[849]: Endpoint registered: sender=:1.53 path=/MediaEndpoint/A2DPSource/faststream_duplex
Jun 22 19:26:01 richard-ms7c91 bluetoothd[849]: Endpoint registered: sender=:1.53 path=/MediaEndpoint/A2DPSink/opus_05
Jun 22 19:26:01 richard-ms7c91 bluetoothd[849]: Endpoint registered: sender=:1.53 path=/MediaEndpoint/A2DPSource/opus_05
Jun 22 19:26:01 richard-ms7c91 bluetoothd[849]: Endpoint registered: sender=:1.53 path=/MediaEndpoint/A2DPSink/opus_05_duplex
Jun 22 19:26:01 richard-ms7c91 bluetoothd[849]: Endpoint registered: sender=:1.53 path=/MediaEndpoint/A2DPSource/opus_05_duplex
Jun 22 19:26:02 richard-ms7c91 bluetoothd[849]: Failed to set mode: Failed (0x03)
Jun 22 19:32:13 richard-ms7c91 bluetoothd[849]: src/profile.c:ext_connect() Hands-Free Voice gateway failed connect to 88:08:94:59:10:02: Connection refused (111)
Jun 22 19:32:47 richard-ms7c91 bluetoothd[849]: src/profile.c:ext_connect() Hands-Free Voice gateway failed connect to 88:08:94:59:10:02: Connection refused (111)
Jun 22 19:33:04 richard-ms7c91 bluetoothd[849]: src/profile.c:ext_connect() Hands-Free Voice gateway failed connect to 88:08:94:59:10:02: Connection refused (111)
Jun 22 19:34:12 richard-ms7c91 bluetoothd[849]: src/profile.c:ext_connect() Hands-Free Voice gateway failed connect to 88:08:94:59:10:02: Connection refused (111)
This is what I get. . .
Rich :wink:
I’ve got 3 Bluetooth icons on my kde-menu bar. . .
(1) says ‘bluetooth enabled’ Smokin’ Buds pairing enabled,marked ‘trusted’
(2) says ‘bluetooth’ No connected devices, when clicked on it shows ‘Smokin’ Buds, connected, with it’s address, connection to device failed, Disconnected. . .
(3) says ‘bluetoothe’ No connected devices, when you hit connect, it shows 'connecting to Smokin Buds, Connection to device failed, Disconnected. . .
3- bluetooth, Icons? What to do to fix this?
Rich :wink:
Bluetooth fixed . . . . re-installed system and re-established bluetooth connection. Some things aren’t clear and I may have more than likely been kicking myself in the head with some minor problems (i.e. major blunders. . . ) I suspect. Anyways all is good and I’m a happy camper.
Rich :wink:
