Bluetooth is not working.
According to @Hystrix advice,
sudo pacman -S --needed bluez bluez-utils
sudo systemctl start bluetooth –> start till next reboot/power off system
sudo systemctl enable bluetooth –> enable to start on booting the machine (permanent)
I have even rebooted laptop, it is still not working.
It received the notification of incoming bluetooth transfer… but there is not data in my download folder
dmesg
[ 65.358307] Bluetooth: RFCOMM TTY layer initialized
[ 65.358316] Bluetooth: RFCOMM socket layer initialized
[ 65.358324] Bluetooth: RFCOMM ver 1.11
[ 70.499030] fuse: init (API version 7.31)
journalctl
Sep 13 01:51:15 enos-andrew-pc plasmashell[1131]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml:78:5: QML Connections: Implicitly defin>
Sep 13 01:51:15 enos-andrew-pc plasmashell[1131]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ToolButtonStyle.qml:209:13: QML Connections: Implicitly defined onFoo properties in >
Sep 13 01:51:15 enos-andrew-pc plasmashell[1131]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ScrollViewStyle.qml:60:5: QML Connections: Implicitly defined onFoo properties in Co>
Sep 13 01:51:16 enos-andrew-pc NetworkManager[804]: <info> [1599954676.3730] manager: (0C:A8:A7:AC:68:5B): new Bluetooth device (/org/freedesktop/NetworkManager/Devices/5)
Sep 13 01:51:16 enos-andrew-pc NetworkManager[804]: <info> [1599954676.3733] device (0C:A8:A7:AC:68:5B): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'extern>
Sep 13 01:51:16 enos-andrew-pc NetworkManager[804]: <info> [1599954676.3774] device (0C:A8:A7:AC:68:5B): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'manage>
Sep 13 01:51:29 enos-andrew-pc spectacle[1222]: Cyclic dependency detected between "file:///usr/lib/qt/qml/org/kde/kirigami.2/styles/org.kde.desktop.plasma/Units.qml" and "file:///usr/lib/>
Sep 13 01:51:29 enos-andrew-pc spectacle[1222]: qrc:/JobDialog.qml:28: TypeError: Cannot read property 'pluginName' of undefined
Sep 13 01:51:30 enos-andrew-pc spectacle[1222]: qrc:/org/kde/purpose/RunningJob.qml:29:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this synta>
Sep 13 01:51:30 enos-andrew-pc spectacle[1222]: qrc:/org/kde/purpose/RunningJob.qml:46:9: Unable to assign ulong to double
Sep 13 01:51:30 enos-andrew-pc plasmashell[1131]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:285:5: QML Connections: Implicitly defined onFoo proper>
Sep 13 01:51:36 enos-andrew-pc plasmashell[1131]: qrc:/plasma/plasmoids/org.kde.plasma.volume/contents/ui/main.qml:482:39: QML StreamListItem: Binding loop detected for property "width"
Sep 13 01:52:05 enos-andrew-pc obexd[1337]: Source ID 70 was not found when attempting to remove it
Sep 13 01:52:05 enos-andrew-pc kded5[1091]: bluedevil: Removed Obex session is not ours "/org/bluez/obex/server/session2"
Sep 13 01:52:05 enos-andrew-pc bluetoothd[802]: src/profile.c:ext_io_disconnected() Unable to get io data for Object Push: getpeername: Transport endpoint is not connected (107)
Sep 13 01:52:05 enos-andrew-pc kded5[1091]: bluedevil: ReceiveFileJob-Transfer Error
Sep 13 01:52:05 enos-andrew-pc obexd[1337]: PUT(0x2), Forbidden(0x43)
Sep 13 01:52:05 enos-andrew-pc obexd[1337]: disconnected: Transport got disconnected
Sep 13 01:52:10 enos-andrew-pc NetworkManager[804]: <info> [1599954730.2773] device (0C:A8:A7:AC:68:5B): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'remov>
Sep 13 01:52:10 enos-andrew-pc kded5[1091]: plasma-nm: virtual void SecretAgent::DeleteSecrets(const NMVariantMapMap&, const QDBusObjectPath&)
Sep 13 01:52:10 enos-andrew-pc kded5[1091]: plasma-nm: Path: "/org/freedesktop/NetworkManager/Settings"
Sep 13 01:53:54 enos-andrew-pc systemd[1039]: Started apps-org.kde.konsole-cade6a38f987433a89367ce01ecff4d0.scope.
Sep 13 01:53:54 enos-andrew-pc plasmashell[1131]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:285:5: QML Connections: Implicitly defined onFoo proper>
Can you please tell me from the above 2 error logging mechanism, what can be seem is the problem ?
