Since I’ve updated my laptop from kernel 5.8 to 5.9,1. This issue persists from kernel 5.9.1 to 5.9.6.
[santi@santiago-hplaptop15seq0xxx ~]$ inxi -Fxxc0z --no-host
System: Kernel: 5.9.6-arch1-1 x86_64 bits: 64 compiler: gcc v: 10.2.0 Desktop: KDE Plasma 5.20.2 tk: Qt 5.15.1 wm: kwin_x11
dm: SDDM Distro: EndeavourOS
Machine: Type: Laptop System: HP product: HP Laptop 15s-eq0xxx v: N/A serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 86FD v: 99.36 serial: <filter> UEFI: AMI v: F.17 date: 04/13/2020
Battery: ID-1: BAT0 charge: 28.7 Wh condition: 41.4/41.4 Wh (100%) volts: 11.5/11.3 model: Hewlett-Packard Primary
serial: N/A status: Discharging
CPU: Info: Quad Core model: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx bits: 64 type: MT MCP arch: Zen+ rev: 1
L2 cache: 2048 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 33551
Speed: 1222 MHz min/max: 1400/2100 MHz boost: enabled Core speeds (MHz): 1: 1230 2: 1229 3: 1277 4: 1260 5: 1230
6: 1283 7: 1222 8: 1222
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Picasso vendor: Hewlett-Packard driver: amdgpu v: kernel bus ID: 04:00.0
chip ID: 1002:15d8
Device-2: Luxvisions Innotech Limited type: USB driver: uvcvideo bus ID: 3-1.2:3 chip ID: 30c9:0013
Display: x11 server: X.org 1.20.9 compositor: kwin_x11 driver: amdgpu,ati unloaded: fbdev,modesetting,vesa
resolution: <xdpyinfo missing>
Audio: Device-1: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus ID: 04:00.1 chip ID: 1002:15de
Device-2: Advanced Micro Devices [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Hewlett-Packard
driver: N/A bus ID: 04:00.5 chip ID: 1022:15e2
Device-3: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
bus ID: 04:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k5.9.6-arch1-1
Network: Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter vendor: Hewlett-Packard driver: rtw_8822ce
v: N/A port: f000 bus ID: 02:00.0 chip ID: 10ec:c822
Drives: Local Storage: total: 476.94 GiB used: 251.83 GiB (52.8%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLB512HBJQ-000H1 size: 476.94 GiB speed: 31.6 Gb/s lanes: 4
serial: <filter>
Partition: ID-1: / size: 29.40 GiB used: 17.73 GiB (60.3%) fs: ext4 dev: /dev/nvme0n1p2
ID-2: /home size: 434.49 GiB used: 234.09 GiB (53.9%) fs: ext4 dev: /dev/nvme0n1p4
Swap: ID-1: swap-1 type: partition size: 4.00 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p3
Sensors: System Temperatures: cpu: 44.0 C mobo: N/A gpu: amdgpu temp: 44.0 C
Fan Speeds (RPM): N/A
Info: Processes: 244 Uptime: 34m Memory: 9.71 GiB used: 1.77 GiB (18.3%) Init: systemd v: 246 Compilers: gcc: 10.2.0
clang: 10.0.1 Packages: 1278 pacman: 1273 flatpak: 5 Shell: Bash v: 5.0.18 running in: yakuake inxi: 3.1.08
