Bluetooth not working properly
I have this bluetooth adapter.
It shows as
$ lsusb | grep Blue
Bus 001 Device 003: ID 0bda:2550 Realtek Semiconductor Corp. Bluetooth Radio
If I try to connect, I get
$ bluetoothctl
Agent registered
[bluetooth]# devices
No default controller available
$ sudo rmmod btusb
$ sudo modprobe btusb
results in
$ journalctl -e -b
firmware file rtl_bt/rtl8761b_fw.bin not found
bluez and bluez-utils is installed. And I am pretty sure that it worked the first time I put it in.
A different stick works.
My questions:
Any idea, how to resolve the problem?
Is there an easy way to find the driver (that is not google + AUR)?
Is there a way to get something like a list of all installed drivers?
Here is some info to look at first.
Edit: Also that firmware is in the AUR
https://aur.archlinux.org/packages/rtl8761b-fw/
I already did that. As said, another adapter is working, and I’m pretty sure that this adapter was working, too.
I therefore assume, that that driver must be somewhere in the main packages, and something else is wrong.
Or, I am insanely stupid, and used my old adapter while thinking it was the new one. But I really don’t think so, as my old adapter is very big, and the new one is very small, and I’m pretty sure that I changed it. And I remember beeing happy that the problems of my old adapter were not present. That’s why I’m so confused, that the drivers are apparently missing.
firmware is missing not the driver :wink:
➜  ~ » cd /usr/lib/firmware/rtl_bt
➜  lib/firmware/rtl_bt » ls
rtl8192ee_fw.bin               rtl8723d_config.bin  rtl8821c_fw.bin       rtl8822cu_fw.bin
rtl8192eu_fw.bin               rtl8723d_fw.bin      rtl8822b_config.bin   rtl8852au_config.bin
rtl8723a_fw.bin                rtl8761a_fw.bin      rtl8822b_fw.bin       rtl8852au_fw.bin
rtl8723b_fw.bin                rtl8812ae_fw.bin     rtl8822cs_config.bin
rtl8723bs_config-OBDA8723.bin  rtl8821a_fw.bin      rtl8822cs_fw.bin
rtl8723bs_fw.bin               rtl8821c_config.bin  rtl8822cu_config.bin
I did provide you a link to the firmware that is available from the AUR.
