no devices show up
healp ‘-’
wiki your friend
thanks mate
the connection button doesnt stay onn can you help?
Look in the journal what happens while connecting your realme Buds Q.
User something like journalctl -b -0 -n20.
This gives you the latest 20 lines. Please post those lines here.
Jul 05 23:20:05 vishesh-hp241g1 discord.desktop[4698]: [Modules] Module installed file path: /home/vishesh/.config/discord/0.0.15/modules/installed.json
Jul 05 23:20:05 vishesh-hp241g1 discord.desktop[4698]: [Modules] Module download path: /home/vishesh/.config/discord/0.0.15/modules/pending
Jul 05 23:20:09 vishesh-hp241g1 discord.desktop[4698]: [Modules] No updates to install
Jul 05 23:20:09 vishesh-hp241g1 discord.desktop[4698]: [Modules] Checking for host updates.
Jul 05 23:20:10 vishesh-hp241g1 discord.desktop[4698]: [Modules] Host is up to date.
Jul 05 23:20:10 vishesh-hp241g1 discord.desktop[4698]: [Modules] Checking for module updates at https://discord.com/api/modules/stable/versions.json
Jul 05 23:20:10 vishesh-hp241g1 discord.desktop[4698]: [Modules] No module updates available.
Jul 05 23:20:33 vishesh-hp241g1 systemd[1226]: Started Application launched by gnome-shell.
Jul 05 23:20:34 vishesh-hp241g1 /usr/lib/gdm-x-session[1242]: (II) RADEON(0): EDID vendor “CMN”, prod id 5281
Jul 05 23:20:34 vishesh-hp241g1 /usr/lib/gdm-x-session[1242]: (II) RADEON(0): Printing DDC gathered Modelines:
Jul 05 23:20:34 vishesh-hp241g1 /usr/lib/gdm-x-session[1242]: (II) RADEON(0): Modeline "1366x768"x0.0 76.42 1366 1434 1479 1592 768 772 779 800 +hsync -vsync (48.0>
Jul 05 23:20:34 vishesh-hp241g1 /usr/lib/gdm-x-session[1242]: (II) RADEON(0): Modeline "1366x768"x0.0 50.95 1366 1434 1479 1592 768 772 779 800 +hsync -vsync (32.0>
Jul 05 23:20:42 vishesh-hp241g1 bluetoothd[504]: profiles/audio/avdtp.c:avdtp_connect_cb() connect to 6C:CE:44:7A:75:19: Host is down (112)
Jul 05 23:20:45 vishesh-hp241g1 systemd[1226]: Started Application launched by gnome-shell.
Jul 05 23:20:45 vishesh-hp241g1 dbus-daemon[1256]: [session uid=1000 pid=1256] Activating via systemd: service name=‘org.gnome.Terminal’ unit='gnome-terminal-server.se>
Jul 05 23:20:45 vishesh-hp241g1 systemd[1226]: Starting GNOME Terminal Server…
Jul 05 23:20:45 vishesh-hp241g1 dbus-daemon[1256]: [session uid=1000 pid=1256] Successfully activated service ‘org.gnome.Terminal’
Jul 05 23:20:45 vishesh-hp241g1 systemd[1226]: Started GNOME Terminal Server.
Jul 05 23:20:45 vishesh-hp241g1 systemd[1226]: Started VTE child process 5069 launched by gnome-terminal-server process 5050.
Jul 05 23:20:45 vishesh-hp241g1 systemd[1226]: app-gnome-org.gnome.Terminal-5046.scope: Deactivated successfully.
sudo rfkill list
- metal or vm ?
EDit
just idea ( check device in pairing/discovery mode)
There is only this one line that is related to bluetooth. To me this line is not that specific.
Please check the arch wiki: https://wiki.archlinux.org/title/Bluetooth especially the troubleshooting section. May be you can find some hints why it is not connecting.
archwiki suggests to pair/trus/connect headset/headphones with bluetoothctl as root the first time if it fails.
so remove the device close bluetooth settings and run this from terminal:
sudo bluetoothctl
scan on
pair uuid-of-headset
trust uuid-of-headset
connect uuid-of-headset
[vishesh@vishesh-hp241g1 ~]$ sudo rfkill list
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
1: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
this doent work
[bluetooth]# trust 6C:CE:44:7A:75:19
Changing 6C:CE:44:7A:75:19 trust succeeded
[bluetooth]# connect 6C:CE:44:7A:75:19
Attempting to connect to 6C:CE:44:7A:75:19
Failed to connect: org.bluez.Error.Failed
[bluetooth]#
Can you also post the output of inxi -Fxxxza --no-host
Format the copied and pasted text from a terminal by placing three ``` before and after the output so it looks like:
copied text
[vishesh@vishesh-hp241g1 ~]$ inxi -Fxxxza --no-host
Kernel: 5.12.14-arch1-1 x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-linux
root=UUID=4f10ee29-8d80-4d05-8d75-6c2ef5bdb993 rw quiet splash
usbcore.autosuspend=-1
Desktop: GNOME 40.2 tk: GTK 3.24.29 wm: gnome-shell dm: GDM 40.0
Type: Laptop System: Hewlett-Packard product: HP 241 G1
v: 0985100000400010060670081 serial: <filter> Chassis: type: 10
serial: <filter>
Mobo: Hewlett-Packard model: 8072 v: KBC Version 70.07 serial: <filter>
UEFI: Insyde v: F.34 date: 09/01/2015
Battery:
ID-1: BAT0 charge: 25.1 Wh (100.0%) condition: 25.1/25.1 Wh (100.0%)
volts: 16.7 min: 14.8 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: Full
Info: Quad Core model: AMD A4 PRO-3340B with Radeon HD Graphics bits: 64
type: MCP arch: Jaguar family: 16 (22) model-id: N/A stepping: 1
microcode: 700010F cache: L2: 2 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 17573
Speed: 2194 MHz min/max: 1100/2200 MHz Core speeds (MHz): 1: 2194 2: 2171
3: 1644 4: 2196
Vulnerabilities: Type: itlb_multihit status: Not affected
Type: spec_store_bypass
mitigation: Speculative Store Bypass disabled via prctl and seccomp
Type: spectre_v1
Type: spectre_v2
mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
Device-1: AMD Kabini [Radeon HD 8240 / R3 Series] vendor: Hewlett-Packard
driver: radeon v: kernel alternate: amdgpu bus-ID: 00:01.0
chip-ID: 1002:9838 class-ID: 0300
Device-2: Chicony HP Truevision HD type: USB driver: uvcvideo
bus-ID: 1-4:2 chip-ID: 04f2:b509 class-ID: 0e02
Display: x11 server: X.org 1.20.11 compositor: gnome-shell driver:
loaded: ati,radeon unloaded: fbdev,modesetting,vesa
resolution: <missing: xdpyinfo>
Device-1: AMD Kabini HDMI/DP Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:01.1 chip-ID: 1002:9840
class-ID: 0403
Device-2: AMD FCH Azalia vendor: Hewlett-Packard driver: snd_hda_intel
v: kernel bus-ID: 00:14.2 chip-ID: 1022:780d class-ID: 0403
Sound Server-1: ALSA v: k5.12.14-arch1-1 running: yes
Sound Server-2: JACK v: 0.125.0 running: no
Sound Server-3: PulseAudio v: 14.2 running: yes
Sound Server-4: PipeWire v: 0.3.31 running: no
vendor: Hewlett-Packard driver: r8168 v: 8.049.02-NAPI modules: r8169
port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: eno1 state: down mac: <filter>
Device-2: Realtek RTL8723BE PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtl8723be v: kernel port: 2000
bus-ID: 05:00.0 chip-ID: 10ec:b723 class-ID: 0280
IF-ID-1: anbox0 state: down mac: <filter>
Bluetooth:
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 5-1:2 chip-ID: 0bda:b001 class-ID: e001 serial: <filter>
Report: This feature requires one of these tools: hciconfig/bt-adapter
Local Storage: total: 465.76 GiB used: 15.89 GiB (3.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS545050A7E680
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter> rev: A350 scheme: GPT
ID-1: / raw-size: 465.26 GiB size: 456.88 GiB (98.20%)
used: 15.89 GiB (3.5%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%)
used: 296 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
Alert: No Swap data was found.
System Temperatures: cpu: 65.5 C mobo: N/A gpu: radeon temp: 68.0 C
Fan Speeds (RPM): N/A
Processes: 213 Uptime: 5h 00m wakeups: 7 Memory: 3.31 GiB
used: 2.96 GiB (89.4%) Init: systemd v: 248 tool: systemctl Compilers:
gcc: 11.1.0 Packages: 978 pacman: 974 lib: 240 snap: 4 Shell: Bash
v: 5.1.8 running-in: gnome-terminal inxi: 3.3.03
here
Your BIOS is 6 years old. You might want to look at updating that. You could also try the LTS kenel and see if that helps. To install the LTS Kernel in a terminal type:
sudo pacman -S linux-lts linux-lts-headers
Then update grub:
and reboot.
Select the LTS kernel from the grub screen.
i would also look into what this is trying to tell you.
You may also find this thread interesting…seems some older hardware has issues with Arch linux.
https://bbs.archlinux.org/viewtopic.php?id=263040
it says this
‘’‘==> Image generation successful
(4/4) Update grub after installing or removing a kernel or microcode.
/etc/default/grub: line 6: usbcore.autosuspend=-1: command not found
error: command failed to execute correctly’‘’
i dont remeber what was there before i changed it
You have to long press each ear bud for 5 seconds to put them in pairing mode. Press both at the same time and hold for 5 seconds. They should pair properly after that and connect if you go through the proper procedure. It’s not Bluetooth not working on the laptop. It’s the earbuds not connecting properly and staying connected.
had trouble with gnome before @ bluetooth headset, now i use blueman ( i no little about bluetooth ) where gnome settings fail me on bluetooth ! blueman never let me down …
try that as your computer bluetooth works
sudo pacman -S blueman ( worth try )
i am tired of trying at this point
i have tried that too
i saw there are no updated
