Well, after using Bluetooth yesterday, I turned on the computer this morning and when I tried to connect my Bluetooth headphones, there is no way to turn on Bluetooth on the computer.
What I have done so far is
[olividir@ProX15 ~]$ sudo systemctl start bluetooth
[sudo] password for olividir:
[olividir@ProX15 ~]$ sudo systemctl enable bluetooth
[olividir@ProX15 ~]$ sudo systemctl enable --now bluetooth
This does nothing, doesn’t even start the service for part of a second.
When I go into bluetoothctl
I get
[olividir@ProX15 ~]$ bluetoothctl
Agent registered
[bluetooth]# scan on
No default controller available
I have no idea why it is saying no controller available. Especially because I used the Bluetooth about 10 hours ago.
journalctl
des 28 09:25:32 ProX15 gnome-control-c[6655]: Error connecting to ModemManager: Error calling StartServiceByName for org.freedesktop.ModemManager1: Unit dbus-org.freedesktop.ModemManager1.service not found.
des 28 09:25:33 ProX15 gnome-shell[1348]: meta_window_set_stack_position_no_sync: assertion 'window->stack_position >= 0' failed
des 28 09:25:35 ProX15 gnome-control-c[6655]: BluetoothHardwareAirplaneMode: 0
des 28 09:25:35 ProX15 dbus-daemon[1288]: [session uid=1000 pid=1288] Activating via systemd: service name='org.bluez.obex' unit='dbus-org.bluez.obex.service' requested by ':1.255' (uid=1000 pid=6655 comm="gnome-control->
des 28 09:25:35 ProX15 systemd[1268]: Starting Bluetooth OBEX service...
des 28 09:25:35 ProX15 obexd[6716]: OBEX daemon 5.66
des 28 09:25:35 ProX15 dbus-daemon[1288]: [session uid=1000 pid=1288] Successfully activated service 'org.bluez.obex'
des 28 09:25:35 ProX15 systemd[1268]: Started Bluetooth OBEX service.
des 28 09:25:47 ProX15 systemd[1268]: Started Application launched by gsd-media-keys.
des 28 09:25:47 ProX15 dbus-daemon[1288]: [session uid=1000 pid=1288] Activating via systemd: service name='org.gnome.Terminal' unit='gnome-terminal-server.service' requested by ':1.257' (uid=1000 pid=6720 comm="gnome-te>
des 28 09:25:47 ProX15 systemd[1268]: Starting GNOME Terminal Server...
des 28 09:25:47 ProX15 dbus-daemon[1288]: [session uid=1000 pid=1288] Successfully activated service 'org.gnome.Terminal'
des 28 09:25:47 ProX15 systemd[1268]: Started GNOME Terminal Server.
des 28 09:25:47 ProX15 systemd[1268]: Started VTE child process 6745 launched by gnome-terminal-server process 6727.
des 28 09:26:00 ProX15 rtkit-daemon[975]: Supervising 10 threads of 7 processes of 1 users.
des 28 09:26:02 ProX15 systemd[1]: systemd-hostnamed.service: Deactivated successfully.
des 28 09:26:02 ProX15 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
des 28 09:26:02 ProX15 kernel: audit: type=1131 audit(1672219562.970:246): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=?>
des 28 09:26:03 ProX15 audit: BPF prog-id=0 op=UNLOAD
des 28 09:26:03 ProX15 kernel: audit: type=1334 audit(1672219563.080:247): prog-id=0 op=UNLOAD
des 28 09:26:03 ProX15 kernel: audit: type=1334 audit(1672219563.080:248): prog-id=0 op=UNLOAD
des 28 09:26:03 ProX15 kernel: audit: type=1334 audit(1672219563.080:249): prog-id=0 op=UNLOAD
des 28 09:26:15 ProX15 rtkit-daemon[975]: Supervising 10 threads of 7 processes of 1 users.
des 28 09:26:36 ProX15 dbus-daemon[692]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.146' (uid=0 pid=6965 comm="sudo systemctl start bl>
des 28 09:26:36 ProX15 dbus-daemon[692]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
des 28 09:26:36 ProX15 sudo[6965]: pam_systemd_home(sudo:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
des 28 09:26:40 ProX15 audit[6965]: USER_AUTH pid=6965 uid=1000 auid=1000 ses=4 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="olividir" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev>
des 28 09:26:40 ProX15 audit[6965]: USER_ACCT pid=6965 uid=1000 auid=1000 ses=4 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="olividir" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=s>
des 28 09:26:40 ProX15 sudo[6965]: olividir : TTY=pts/0 ; PWD=/home/olividir ; USER=root ; COMMAND=/usr/bin/systemctl start bluetooth
des 28 09:26:40 ProX15 audit[6965]: CRED_REFR pid=6965 uid=1000 auid=1000 ses=4 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=>
des 28 09:26:40 ProX15 audit[6965]: USER_START pid=6965 uid=1000 auid=1000 ses=4 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? termina>
des 28 09:26:40 ProX15 sudo[6965]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1000)
des 28 09:26:40 ProX15 kernel: audit: type=1100 audit(1672219600.758:250): pid=6965 uid=1000 auid=1000 ses=4 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="olividir" exe="/usr/bin/sudo" ho>
des 28 09:26:40 ProX15 kernel: audit: type=1101 audit(1672219600.758:251): pid=6965 uid=1000 auid=1000 ses=4 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="olividir" exe="/usr/bin/sudo" hostname=? add>
des 28 09:26:40 ProX15 kernel: audit: type=1110 audit(1672219600.758:252): pid=6965 uid=1000 auid=1000 ses=4 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? ad>
des 28 09:26:40 ProX15 kernel: audit: type=1105 audit(1672219600.758:253): pid=6965 uid=1000 auid=1000 ses=4 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sud>
des 28 09:26:40 ProX15 sudo[6965]: pam_unix(sudo:session): session closed for user root
des 28 09:26:40 ProX15 audit[6965]: USER_END pid=6965 uid=1000 auid=1000 ses=4 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal>
des 28 09:26:40 ProX15 audit[6965]: CRED_DISP pid=6965 uid=1000 auid=1000 ses=4 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=>
des 28 09:26:40 ProX15 kernel: audit: type=1106 audit(1672219600.771:254): pid=6965 uid=1000 auid=1000 ses=4 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/su>
des 28 09:26:40 ProX15 kernel: audit: type=1104 audit(1672219600.771:255): pid=6965 uid=1000 auid=1000 ses=4 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? ad>
des 28 09:26:45 ProX15 systemd[1268]: app-gnome-org.gnome.Settings-6655.scope: Consumed 1.289s CPU time.
des 28 09:26:58 ProX15 dbus-daemon[692]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.147' (uid=0 pid=6969 comm="sudo systemctl enable b>
des 28 09:26:58 ProX15 dbus-daemon[692]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
des 28 09:26:58 ProX15 sudo[6969]: pam_systemd_home(sudo:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
des 28 09:26:58 ProX15 audit[6969]: USER_ACCT pid=6969 uid=1000 auid=1000 ses=4 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="olividir" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=s>
des 28 09:26:58 ProX15 sudo[6969]: olividir : TTY=pts/0 ; PWD=/home/olividir ; USER=root ; COMMAND=/usr/bin/systemctl enable bluetooth
des 28 09:26:58 ProX15 audit[6969]: CRED_REFR pid=6969 uid=1000 auid=1000 ses=4 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pt>
des 28 09:26:58 ProX15 sudo[6969]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1000)
des 28 09:26:58 ProX15 audit[6969]: USER_START pid=6969 uid=1000 auid=1000 ses=4 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? termina>
des 28 09:26:58 ProX15 kernel: audit: type=1101 audit(1672219618.898:256): pid=6969 uid=1000 auid=1000 ses=4 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="olividir" exe="/usr/bin/sudo" hostname=? add>
des 28 09:26:58 ProX15 kernel: audit: type=1110 audit(1672219618.902:257): pid=6969 uid=1000 auid=1000 ses=4 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostn>
des 28 09:26:58 ProX15 kernel: audit: type=1105 audit(1672219618.902:258): pid=6969 uid=1000 auid=1000 ses=4 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sud>
des 28 09:26:58 ProX15 systemd[1]: Reloading.
des 28 09:26:59 ProX15 audit: BPF prog-id=60 op=LOAD
des 28 09:26:59 ProX15 audit: BPF prog-id=0 op=UNLOAD
des 28 09:26:59 ProX15 audit: BPF prog-id=61 op=LOAD
des 28 09:26:59 ProX15 audit: BPF prog-id=62 op=LOAD
des 28 09:26:59 ProX15 kernel: audit: type=1334 audit(1672219619.092:259): prog-id=60 op=LOAD
des 28 09:26:59 ProX15 kernel: audit: type=1334 audit(1672219619.092:260): prog-id=0 op=UNLOAD
des 28 09:26:59 ProX15 kernel: audit: type=1334 audit(1672219619.092:261): prog-id=61 op=LOAD
des 28 09:26:59 ProX15 kernel: audit: type=1334 audit(1672219619.092:262): prog-id=62 op=LOAD
des 28 09:26:59 ProX15 kernel: audit: type=1334 audit(1672219619.092:263): prog-id=0 op=UNLOAD
des 28 09:26:59 ProX15 kernel: audit: type=1334 audit(1672219619.092:264): prog-id=0 op=UNLOAD
des 28 09:26:59 ProX15 kernel: audit: type=1334 audit(1672219619.095:265): prog-id=63 op=LOAD
des 28 09:26:59 ProX15 audit: BPF prog-id=63 op=LOAD
des 28 09:26:59 ProX15 audit: BPF prog-id=64 op=LOAD
des 28 09:26:59 ProX15 audit: BPF prog-id=65 op=LOAD
des 28 09:26:59 ProX15 audit: BPF prog-id=66 op=LOAD
des 28 09:26:59 ProX15 audit: BPF prog-id=67 op=LOAD
des 28 09:26:59 ProX15 audit: BPF prog-id=68 op=LOAD
des 28 09:26:59 ProX15 audit: BPF prog-id=69 op=LOAD
des 28 09:26:59 ProX15 audit: BPF prog-id=70 op=LOAD
des 28 09:26:59 ProX15 audit: BPF prog-id=71 op=LOAD
des 28 09:26:59 ProX15 audit: BPF prog-id=72 op=LOAD
des 28 09:26:59 ProX15 audit: BPF prog-id=73 op=LOAD
des 28 09:26:59 ProX15 sudo[6969]: pam_unix(sudo:session): session closed for user root
des 28 09:26:59 ProX15 audit[6969]: USER_END pid=6969 uid=1000 auid=1000 ses=4 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal>
des 28 09:26:59 ProX15 audit[6969]: CRED_DISP pid=6969 uid=1000 auid=1000 ses=4 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pt>
des 28 09:27:23 ProX15 dbus-daemon[692]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.148' (uid=0 pid=7011 comm="sudo systemctl enable ->
des 28 09:27:23 ProX15 kernel: kauditd_printk_skb: 23 callbacks suppressed
des 28 09:27:23 ProX15 kernel: audit: type=1101 audit(1672219643.356:289): pid=7011 uid=1000 auid=1000 ses=4 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="olividir" exe="/usr/bin/sudo" hostname=? add>
des 28 09:27:23 ProX15 kernel: audit: type=1110 audit(1672219643.356:290): pid=7011 uid=1000 auid=1000 ses=4 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostn>
des 28 09:27:23 ProX15 kernel: audit: type=1105 audit(1672219643.356:291): pid=7011 uid=1000 auid=1000 ses=4 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sud>
des 28 09:27:23 ProX15 audit[7011]: USER_ACCT pid=7011 uid=1000 auid=1000 ses=4 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="olividir" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=s>
des 28 09:27:23 ProX15 audit[7011]: CRED_REFR pid=7011 uid=1000 auid=1000 ses=4 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pt>
des 28 09:27:23 ProX15 audit[7011]: USER_START pid=7011 uid=1000 auid=1000 ses=4 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? termina>
des 28 09:27:23 ProX15 dbus-daemon[692]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
des 28 09:27:23 ProX15 sudo[7011]: pam_systemd_home(sudo:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
des 28 09:27:23 ProX15 sudo[7011]: olividir : TTY=pts/0 ; PWD=/home/olividir ; USER=root ; COMMAND=/usr/bin/systemctl enable --now bluetooth
des 28 09:27:23 ProX15 systemd[1]: Reloading.
des 28 09:27:23 ProX15 sudo[7011]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1000)
des 28 09:27:23 ProX15 audit: BPF prog-id=74 op=LOAD
des 28 09:27:23 ProX15 audit: BPF prog-id=75 op=LOAD
des 28 09:27:23 ProX15 audit: BPF prog-id=0 op=UNLOAD
des 28 09:27:23 ProX15 kernel: audit: type=1334 audit(1672219643.543:292): prog-id=74 op=LOAD
des 28 09:27:23 ProX15 kernel: audit: type=1334 audit(1672219643.543:293): prog-id=75 op=LOAD
des 28 09:27:23 ProX15 kernel: audit: type=1334 audit(1672219643.543:294): prog-id=0 op=UNLOAD
dmesg was massive, so I put it here https://0x0.st/o5Cb.txt
I noticed the thread pointing out bluez version 5.64 being bad, don’t know if that applies to version 5.66.
Other threads have not pointed me into the right direction, but I haven’t checked them all. Will carry on going through posts to see if I find anything useful.
Edit:
Forgot to include inxi
Kernel: 6.1.1-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
Desktop: GNOME v: 43.2 tk: GTK v: 3.24.36 wm: gnome-shell dm: GDM
Type: Laptop System: SLIMBOOK product: PROX-AMD5 v: Standard
serial: <superuser required>
Mobo: SLIMBOOK model: SLIMBOOK v: Standard serial: <superuser required>
UEFI: American Megatrends LLC. v: N.1.06GRU06 date: 05/25/2022
Battery:
ID-1: BAT0 charge: 79.3 Wh (89.9%) condition: 88.2/91.6 Wh (96.2%)
volts: 12.5 min: 11.6 model: standard serial: <filter> status: discharging
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M510
serial: <filter> charge: 55% (should be ignored) status: discharging
Info: 8-core model: AMD Ryzen 7 5700U with Radeon Graphics bits: 64
type: MT MCP arch: Zen 2 rev: 1 cache: L1: 512 KiB L2: 4 MiB L3: 8 MiB
Speed (MHz): avg: 1449 high: 1800 min/max: 1400/4370 boost: enabled cores:
1: 1800 2: 1800 3: 1397 4: 1400 5: 1400 6: 1400 7: 1397 8: 1400 9: 1400
10: 1400 11: 1400 12: 1400 13: 1400 14: 1400 15: 1400 16: 1400
bogomips: 57516
Device-1: AMD Lucienne vendor: Tongfang Hongkong driver: amdgpu v: kernel
arch: GCN-5.1 pcie: speed: 8 GT/s lanes: 16 ports: active: eDP-1
empty: DP-1,HDMI-A-1 bus-ID: 05:00.0 chip-ID: 1002:164c temp: 38.0 C
Device-2: Chicony HD Webcam type: USB driver: uvcvideo bus-ID: 1-3:2
chip-ID: 04f2:b71a
Display: wayland server: X.org v: 1.21.1.6 with: Xwayland v: 22.1.7
compositor: gnome-shell driver: gpu: amdgpu display-ID: 0
Monitor-1: eDP-1 model: ChiMei InnoLux 0x152d res: 1920x1080 dpi: 142
diag: 394mm (15.5")
API: OpenGL v: 4.6 Mesa 22.3.1 renderer: AMD Radeon Graphics (renoir LLVM
14.0.6 DRM 3.49 6.1.1-arch1-1) direct render: Yes
Device-1: AMD Renoir Radeon High Definition Audio vendor: Tongfang Hongkong
driver: snd_hda_intel v: kernel pcie: speed: 8 GT/s lanes: 16
bus-ID: 05:00.1 chip-ID: 1002:1637
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Tongfang Hongkong
driver: N/A pcie: speed: 8 GT/s lanes: 16 bus-ID: 05:00.5 chip-ID: 1022:15e2
Device-3: AMD Family 17h/19h HD Audio vendor: Tongfang Hongkong
bus-ID: 05:00.6 chip-ID: 1022:15e3
Sound API: ALSA v: k6.1.1-arch1-1 running: yes
Sound Server-2: PipeWire v: 0.3.63 running: yes
vendor: Tongfang Hongkong driver: r8169 v: kernel pcie: speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 01:00.0 chip-ID: 10ec:8168
IF: enp1s0 state: down mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie:
speed: 5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:2723
Bluetooth:
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-4.4:4 chip-ID: 8087:0029
Report: rfkill ID: hci0 rfk-id: 0 state: up address: see --recommends
Local Storage: total: 465.76 GiB used: 88.67 GiB (19.0%)
ID-1: /dev/nvme0n1 vendor: Crucial model: CT500P2SSD8 size: 465.76 GiB
speed: 31.6 Gb/s lanes: 4 serial: <filter> temp: 26.9 C
ID-1: / size: 465.46 GiB used: 88.67 GiB (19.0%) fs: btrfs
dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.4 MiB used: 608 KiB (0.2%) fs: vfat
dev: /dev/nvme0n1p1
ID-3: /home size: 465.46 GiB used: 88.67 GiB (19.0%) fs: btrfs
dev: /dev/nvme0n1p2
ID-4: /var/log size: 465.46 GiB used: 88.67 GiB (19.0%) fs: btrfs
dev: /dev/nvme0n1p2
System Temperatures: cpu: 41.0 C mobo: N/A gpu: amdgpu temp: 38.0 C
Fan Speeds (RPM): N/A
Processes: 382 Uptime: 1h 48m Memory: 15.01 GiB used: 5.09 GiB (33.9%)
Init: systemd v: 252 default: graphical Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: pm: pacman pkgs: 1447 Shell: Bash v: 5.1.16
running-in: gnome-terminal inxi: 3.3.24
Also did rfkill:
rfkill
ID TYPE DEVICE SOFT HARD
0 bluetooth hci0 unblocked unblocked
1 wlan phy0 unblocked unblocked
