Bluetooth headset not getting audio after being idle for some time
After being idle for some time, the audio starts playing through my laptop’s speakers instead of headphones. I thought it might be disconnected but it is still paired.
I’m on the latest EndeavourOS update and running gnome.
I am using pipewire audio.
Please help me!!
Welcome to the forum!
Try disabling the suspend node.
To disable suspend-node in wireplumber you can just set session.suspend-timeout-seconds in bluetooth.lua.d/50-bluez-config.lua to 0
You can copy the config from /usr/share/wireplumber into user-wide config location, ~/.config and and edit however you wish.
Steps:
  1. cd ~/.config
  2. mkdir wireplumber
  3. mkdir wireplumber/bluetooth.lua.d
  4. cp /usr/share/wireplumber/bluetooth.lua.d/50-bluez-config.lua ~/.config/wireplumber/bluetooth.lua.d/50-bluez-config.lua
  5. In the newly copied file ~/.config/wireplumber/bluetooth.lua.d/50-bluez-config.lua, uncomment the line saying ["session.suspend-timeout-seconds"] = 5
  6. Change value 5 to 0
  7. Save the file
  8. Restart
