I added Bluetooth support using the below article and all seems to be installed correctly, but when I turn on the headphone, hold the button for the ready to pair message, press connect button in systray applet while still holding down the button on the headphones I get the below.
Bluedio
Connect to the device failed
If I try it from Bluetooth in System Settings I get.
Host is down
Type: Headset
Address: 16:03:24:11:15:57
Adapter: TheMothership #1
Name Bluedio
Trusted checked
How to Set up Bluetooth in Arch Linux.pdf (580.1 KB)
Ideas on how to fix this would be greatly appreciated. Thanks
[alienprober@TheMotrhership ~]$ inxi -Fxxxza
Kernel: 5.9.8-arch1-1 x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux
root=UUID=128d1d7c-1028-4416-b91d-882b6c7c7d2b rw rootflags=subvol=@ quiet
loglevel=3 nowatchdog
Desktop: KDE Plasma 5.20.3 tk: Qt 5.15.1 wm: kwin_x11 dm: SDDM
Distro: EndeavourOS
Type: Desktop Mobo: ASUSTeK model: ROG STRIX B450-F GAMING v: Rev 1.xx
serial: <filter> UEFI: American Megatrends v: 3103 date: 06/17/2020
Battery:
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: Discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Keyboard K360
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: Discharging
Info: Quad Core model: AMD Ryzen 3 3200G with Radeon Vega Graphics bits: 64
type: MCP arch: Zen+ family: 17 (23) model-id: 18 (24) stepping: 1
microcode: 8108109 L2 cache: 2048 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 28757
Speed: 1325 MHz min/max: 1400/3600 MHz boost: enabled Core speeds (MHz):
1: 1298 2: 1632 3: 1272 4: 1434
Vulnerabilities: Type: itlb_multihit status: Not affected
Type: spec_store_bypass
mitigation: Speculative Store Bypass disabled via prctl and seccomp
Type: spectre_v1
Type: spectre_v2
mitigation: Full AMD retpoline, IBPB: conditional, STIBP: disabled, RSB filling
Device-1: NVIDIA TU116 [GeForce GTX 1650 SUPER] vendor: eVga.com.
driver: nvidia v: 455.38 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:2187
Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: nvidia
unloaded: fbdev,modesetting,vesa alternate: nouveau,nv display ID: :0
screens: 1
Screen-1: 0 s-res: 2560x1080 s-dpi: 97 s-size: 670x283mm (26.4x11.1")
s-diag: 727mm (28.6")
Monitor-1: HDMI-0 res: 2560x1080 hz: 60 dpi: 97 size: 673x284mm (26.5x11.2")
diag: 730mm (28.8")
OpenGL: renderer: GeForce GTX 1650 SUPER/PCIe/SSE2 v: 4.6.0 NVIDIA 455.38
direct render: Yes
Device-1: NVIDIA TU116 High Definition Audio vendor: eVga.com.
driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:1aeb
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus ID: 0a:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k5.9.8-arch1-1
Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
port: d000 bus ID: 04:00.0 chip ID: 8086:1539
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 16.38 TiB used: 7.79 TiB (47.6%)
ID-1: /dev/nvme0n1 model: Viper M.2 VPN100 size: 238.47 GiB block size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter>
rev: ECFM22.6 scheme: GPT
ID-2: /dev/sda vendor: Western Digital model: WD10EARS-00Y5B1 size: 931.51 GiB
block size: physical: 512 B logical: 512 B speed: 3.0 Gb/s serial: <filter>
rev: 0A80 scheme: GPT
ID-3: /dev/sdb vendor: Seagate model: ST3000DM001-1E6166 size: 2.73 TiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s rotation: 7200 rpm
serial: <filter> rev: SC48 scheme: GPT
ID-4: /dev/sdc type: USB vendor: Seagate model: Expansion size: 1.82 TiB
block size: physical: 4096 B logical: 512 B serial: <filter> rev: 9300
scheme: GPT
ID-5: /dev/sdd type: USB vendor: MediaMax model: WL3000GSA6454 size: 3.41 TiB
block size: physical: 4096 B logical: 512 B rotation: 5400 rpm
serial: <filter> scheme: GPT
ID-6: /dev/sde type: USB vendor: Seagate model: Expansion Desk size: 7.28 TiB
block size: physical: 4096 B logical: 512 B serial: <filter> rev: 9401
scheme: GPT
ID-1: / raw size: 237.99 GiB size: 237.99 GiB (100.00%)
used: 69.55 GiB (29.2%) fs: btrfs dev: /dev/nvme0n1p2
ID-2: /home raw size: 237.99 GiB size: 237.99 GiB (100.00%)
Alert: No Swap data was found.
System Temperatures: cpu: 40.2 C mobo: N/A gpu: nvidia temp: 43 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 0%
Processes: 336 Uptime: 3h 41m Memory: 15.62 GiB used: 3.94 GiB (25.2%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: 1500 pacman: 1449
lib: 364 flatpak: 44 snap: 7 Shell: Bash v: 5.0.18 running in: konsole
inxi: 3.1.08
