Pecab sorry but I thought I had it working but, no cigar. Do I need a bluetooth adapter to use a Vankyo c371 headset? Checked the review and it said nothing about needing a bluetooth adapter.
On Endeavour Atlantis I installed:
bluez-5.63-1 is up to date – skipping
bluez-utils-5.63-1 is up to date – skipping
there is nothing to do
[bobcapp@z97-aendevourAtlantisNeo ~]$ sudo systemctl enable --now bluetooth
I rebooted; under settings Bluetooth adapters I get:
Connecting to BlueZ Failed
BlueZ daemon is not running, Blueman-manager cannot continue. This probably means that there were no Bluetooth adapter detected or Bluetooth daemon was not started.
Which do you think it is, or did I mess up something else?
Thanks for your help
Your computer doesn’t appear to have a bluetooth adapter installed.
Also, when you paste terminal output, could you please format it using the “Preformatted text” option in the reply toolbar…highlight the selection and click that icon. That makes it much easier to read.
When formatted, it looks like this:
