Bluetooth enabled but does not work
When i try to connect Wii Remotes and Joycons using bluetooth i get the error message
br-connection-create-socket
the problems does not seem to be with the controllers as they worked when i had windows installed and they work on their respective consoles.
Host: HH-PC Kernel: 6.10.1-arch1-1 arch: x86_64 bits: 64
Desktop: KDE Plasma v: 6.1.3 Distro: EndeavourOS
Type: Desktop System: LENOVO product: 90RW0003MW v: IdeaCentre Gaming5
14ACN6 serial:
Mobo: LENOVO model: 3743 v: SDK0J40700 WIN 3258215464713
serial: UEFI: LENOVO v: O5EKT19A date: 06/06/2021
Battery:
ID-1: hidpp_battery_0 charge: 24% condition: N/A
Info: 6-core model: AMD Ryzen 5 5600G with Radeon Graphics bits: 64
type: MT MCP cache: L2: 3 MiB
Speed (MHz): avg: 3943 min/max: 400/4464 cores: 1: 4367 2: 4364 3: 3663
4: 3686 5: 4100 6: 3494 7: 4367 8: 3876 9: 3900 10: 3946 11: 4031 12: 3522
Device-1: NVIDIA TU116 [GeForce GTX 1660 SUPER] driver: nvidia v: 555.58.02
Device-2: Microdia Dual Mode Camera (8006 VGA) driver: hid-generic,usbhid
type: USB
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.1 driver: X:
loaded: nvidia unloaded: modesetting gpu: nvidia,nvidia-nvswitch resolution:
1: 1920x1080 2: 1280x1024
API: EGL v: 1.5 drivers: nvidia,swrast
platforms: gbm,x11,surfaceless,device
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 555.58.02
renderer: NVIDIA GeForce GTX 1660 SUPER/PCIe/SSE2
API: Vulkan v: 1.3.279 drivers: nvidia surfaces: xcb,xlib
Device-1: NVIDIA TU116 High Definition Audio driver: snd_hda_intel
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: N/A
Device-3: AMD Family 17h/19h HD Audio driver: snd_hda_intel
API: ALSA v: k6.10.1-arch1-1 status: kernel-api
Server-1: PipeWire v: 1.2.1 status: active
Device-1: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter
driver: rtw89_8852ae
IF: wlan0 state: up mac: 74:4c:a1:be:ea:f5
Device-2: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
driver: r8169
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: 1c:69:7a:c6:a5:ca
IF-ID-1: wg0-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
Bluetooth:
Device-1: Realtek Bluetooth Radio driver: btusb type: USB
Report: btmgmt ID: hci0 state: up address: 74:4C:A1:BE:EA:F6 bt-v: 5.2
Local Storage: total: 942.7 GiB used: 395.69 GiB (42.0%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: PC SN730
SDBQNTY-512G-1001 size: 476.94 GiB
ID-2: /dev/sda vendor: Crucial model: CT500MX500SSD1 size: 465.76 GiB
ID-1: / size: 28.67 GiB used: 20.47 GiB (71.4%) fs: ext4 dev: /dev/dm-0
ID-2: /home size: 438.58 GiB used: 374.97 GiB (85.5%) fs: ext4
dev: /dev/dm-1
ID-1: swap-1 type: file size: 17.09 GiB used: 245.5 MiB (1.4%)
file: /home/hjalmar/swapfile
System Temperatures: cpu: 72.9 C mobo: N/A gpu: nvidia temp: 49 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 30%
Memory: total: 16 GiB note: est. available: 14.98 GiB used: 7.4 GiB (49.4%)
Processes: 451 Uptime: 2h 21m Shell: Bash inxi: 3.3.35
