Thanks i will [myjuicysweety@myjuicysweety-tufgamingfa506iifx506ii ~]$ pulseaudio-bluetooth
bash: pulseaudio-bluetooth: command not found
I fear youâre going to have a difficult journey with this distro.
Pacman is the Arch package manager, which handles installation and removal of packages.
pacman -Syu pulseaudio-bluetooth
will update your system and install the pulseaudio-bluetooth package.
EDIT - letâs make that sudo pacman -Syu pulseaudio-bluetooth
, for clarity .
Thank you Im installing as root cheers .ill be back .
Yes, sorry, I should have included sudo.
Thanks so much i added su as the root then your cmd .Awesome success.Thank you now i can get on and do the things to do after installing Endeavor .Cheers everyone for all your help .
Hi Robbie,
Glad you were able to resolve the issue!
Perhaps you could consider to mark this post from @Stagger_Lee for future references as it contains the solution for to whole topic.
Hi pebcak bro how do i mark the post please
The same way you marked the other post as the solution.
There will be a checkbox you can click on. Only you can see it.
Hi there sorry i am lost ,i donât see the box is it at the top of the post please .
I donât know how to make it any more clear. You already marked one post the solution you just do it the same way again on the correct post.
Oh now i get it thanks OK .its Done .Like that ?
Hey bro OK so ive now installed Endeavor os KDE on my wifeâs laptop.But even after i follow your instructions to install Bluetooth i still fail.There is no adapter icon .Can you help please.
Did you follow the EndeavourOS Wiki article that was posted above by Elloquin?
Did you install all 3 of the following packages?
sudo pacman -S --needed bluez bluez-utils pulseaudio-bluetooth
Did you start and enable the service?
sudo systemctl enable --now bluetooth
Hi thanks for your reply ,no and not sure and i will thank you .
Thank you my friend its all good now .
