Hi there I have searched and followed the steps in the konsole to enable Bluetooth.I Open Bluetooth I can see my device ,I click conect ,I get the error Connections to the device failed .
@Robbie
Please read through the following link for how to provide some info of your system to those forum members who are able to help you. Thank you and good luck!
Sorry I don’t see a link .
Just realized that, sorry, my bad
Here it is:
You can also find it at top right of the page above your profile under help.
Sorry I thought I could send a question on my phone .I should have waited until I got home .will send info later thank you .
Hi there ok im at home now and i followed the journalctl comands am i to add them all at the same time and the exit.i tried and as soon as i hit enter the terminal closed .I then used Kate to type the /tmp and the konsole vanishes.
Use:
inxi -Fxxxaz | curl -F 'f:1=<-' ix.io
journal -b -o | curl -F 'f:1=<-' ix.io
and so on to get the URLs. Post the links back here.
http://ix.io/3vS9
bash: journal: command not found
[myjuicysweety@myjuicysweety-tufgamingfa506iifx506ii ~]$ inxi -Fxxxaz
Kernel: 5.13.9-arch1-1 x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-linux
root=UUID=c13982ea-182a-48ab-af7b-9d049d6ab8c9 rw quiet loglevel=3 nowatchdog
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: ASUSTeK product: TUF Gaming FA506II_FX506II v: 1.0
serial: <filter>
Mobo: ASUSTeK model: FA506II v: 1.0 serial: <filter>
UEFI: American Megatrends v: FA506II.309 date: 07/02/2020
Battery:
ID-1: BAT1 charge: 38.4 Wh (100.0%) condition: 38.4/48.2 Wh (79.6%)
volts: 3.9 min: 11.9 model: ASUS A32-K55 type: Li-ion serial: N/A
status: Full
Info: 8-Core model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64
type: MT MCP arch: Zen 2 family: 17 (23) model-id: 60 (96) stepping: 1
microcode: 8600104 cache: L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 92664
Speed: 1396 MHz min/max: 1400/2900 MHz boost: enabled Core speeds (MHz):
1: 1396 2: 1397 3: 1397 4: 1397 5: 1397 6: 1397 7: 1397 8: 1397 9: 1397
10: 1397 11: 1397 12: 1398 13: 1397 14: 1397 15: 1397 16: 1397
Vulnerabilities: Type: itlb_multihit status: Not affected
Type: spec_store_bypass
mitigation: Speculative Store Bypass disabled via prctl and seccomp
Type: spectre_v1
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
STIBP: conditional, RSB filling
Device-1: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: ASUSTeK
driver: nouveau v: kernel bus-ID: 01:00.0 chip-ID: 10de:1f95 class-ID: 0300
Device-2: AMD Renoir vendor: ASUSTeK driver: amdgpu v: kernel bus-ID: 05:00.0
chip-ID: 1002:1636 class-ID: 0300
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-4:3 chip-ID: 13d3:56a2 class-ID: 0e02 serial: <filter>
Display: x11 server: X.org 1.20.13 compositor: kwin_x11 driver:
loaded: amdgpu,ati,modesetting unloaded: fbdev,vesa alternate: nouveau,nv
resolution: <missing: xdpyinfo>
Device-1: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 01:00.1 chip-ID: 10de:10fa class-ID: 0403
Device-2: AMD vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 05:00.1
chip-ID: 1002:1637 class-ID: 0403
Device-3: AMD Raven/Raven2/FireFlight/Renoir Audio Processor driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus-ID: 05:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-4: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.13.9-arch1-1 running: yes
Sound Server-2: JACK v: 1.9.19 running: no
Sound Server-3: PulseAudio v: 15.0 running: yes
Sound Server-4: PipeWire v: 0.3.33 running: no
vendor: ASUSTeK driver: r8169 v: kernel modules: r8168 port: e000
bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp2s0 state: down mac: <filter>
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: AzureWave driver: rtw_8822ce v: N/A modules: rtw88_8822ce port: d000
bus-ID: 03:00.0 chip-ID: 10ec:c822 class-ID: 0280
Bluetooth:
Device-1: IMC Networks Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 3-1:2 chip-ID: 13d3:3548 class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 1 state: up address: see --recommends
Local Storage: total: 476.94 GiB used: 7.29 GiB (1.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: OM8PCP3512F-AB
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 rotation: SSD serial: <filter> rev: ECFK52.3 scheme: GPT
ID-1: / raw-size: 476.43 GiB size: 467.88 GiB (98.21%) used: 7.29 GiB (1.6%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%) used: 296 KiB (0.1%)
fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 62.9 C mobo: 54.0 C
Fan Speeds (RPM): N/A
GPU: device: nouveau temp: 30.0 C device: amdgpu temp: 43.0 C
Processes: 314 Uptime: 4h 29m wakeups: 1 Memory: 15.06 GiB
used: 5.24 GiB (34.8%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 Packages: pacman: 935 lib: 212 Shell: Bash v: 5.1.8
running-in: konsole inxi: 3.3.05
[myjuicysweety@myjuicysweety-tufgamingfa506iifx506ii ~]$ curl -F 'f:1=<-' ix.io
journal -b -o | curl -F 'f:1=<-' ix.io```
This is my second omission/mistake in one and same thread in one and same day
http://ix.io/3vS9
Of course ‘o’ shoul be ‘0’ and nothing else!
Sorry!
ps - I better get some time offline
Its ok bro i appreciate your help .so i need to copy
journal -b -0 | curl -F ‘f:1=<-’ ix.io
http://ix.io/3vS9
bash: journal: Do i copy and paste everything including command not found ?```
I guess this is one of those cases:
Third time’s a charm
journal -b -o | curl -F ‘f:1=<-’ ix.io
journalctl -b -0 | curl -F ‘f:1=<-’ ix.io
bash: -’: No such file or directory
[myjuicysweety@myjuicysweety-tufgamingfa506iifx506ii ~]$ ```
Ok so not sure why this is so confusing for you. @pebcak has been asking you to provide some very simple information here. You really need to do more research on an arch linux system.
Try this:
Open the welcome application…
Click the button for "logs for troubleshooting…
ONLY select the first entry as in the picture and hit OK…
This will save a file in your home directory with the log as in the picture…
Open the log by double clicking it. Then copy and paste the output from the text editor that opens and post it here.
It should look like this:
my output
Body is limited to 90000 characters; you entered 448998. i removed all the other checks .What do you suggest please .I was only following instructions from Pebcak,as you can see in the messages he made several errors.Many thanks for your help.
How about 4th time’s the charm? The command previously posted had tick marks instead of single quote marks. Run this:
journalctl -b -0 | curl -F 'f:1=<-' ix.io
When it finishes running, the terminal will display a link that you can post here.
Wrong…
http://ix.io/3vSJ
Right…
Moderator edit: I fixed this for you.
Oh Ok then thank you so much for your help .Can you also check what GPU is running please .
Do you have the package pulseaudio-bluetooth
installed?
If not, install it. Reboot.
Hi there no i wouldn’t think so this is a fresh install i haven’t installed any packages yet thank you brb
You should also read this from the Wiki:
