Bluethooth headset microphone not working
The headset itself shows up and sound works the microphone for it also shows up in settings only with (unplugged) next to it.
the headset is a jbl tune 710bt
please let me know if you need any more details
Can you post your terminal output of inxi -Fz to see what chipset, drivers, and kernel are in use?
…and welcome to the purple side! :enos:
sure thing here you go and thanks for the welcome ive been looking to move to linux for a while now and endevour seemd like a good fit
  Kernel: 6.1.6-arch1-1 arch: x86_64 bits: 64 Desktop: KDE Plasma v: 5.26.5
    Distro: EndeavourOS
  Type: Laptop System: ASUSTeK product: ASUS TUF Gaming F15 FX506LU_FX506LU
    v: 1.0 serial: <superuser required>
  Mobo: ASUSTeK model: FX506LU v: 1.0 serial: <superuser required>
    UEFI: American Megatrends v: FX506LU.310 date: 11/26/2021
Battery:
  ID-1: BAT1 charge: 40.2 Wh (98.5%) condition: 40.8/48.1 Wh (84.9%)
  Info: 8-core model: Intel Core i7-10870H bits: 64 type: MT MCP cache:
    L2: 2 MiB
  Speed (MHz): avg: 4200 min/max: 800/5000 cores: 1: 4330 2: 4345 3: 4375
    4: 4317 5: 4399 6: 4334 7: 4384 8: 4359 9: 4371 10: 4347 11: 2200 12: 4371
    13: 4334 14: 4381 15: 4167 16: 4187
  Device-1: Intel CometLake-H GT2 [UHD Graphics] driver: i915 v: kernel
  Device-2: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] driver: nvidia
    v: 525.78.01
  Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
  Display: x11 server: X.Org v: 21.1.6 driver: X: loaded: modesetting,nvidia
    dri: iris gpu: i915 resolution: 1920x1080~144Hz
  API: OpenGL v: 4.6.0 NVIDIA 525.78.01 renderer: NVIDIA GeForce GTX 1660
    Ti/PCIe/SSE2
  Device-1: Intel Comet Lake PCH cAVS driver: snd_hda_intel
  Device-2: NVIDIA TU116 High Definition Audio driver: snd_hda_intel
  Sound API: ALSA v: k6.1.6-arch1-1 running: yes
  Sound Server-1: PipeWire v: 0.3.64 running: yes
  Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi
    driver: r8169
  IF: enp3s0 state: down mac: <filter>
  IF-ID-1: ipv6leakintrf0 state: unknown speed: N/A duplex: N/A
    mac: <filter>
  IF-ID-2: proton0 state: unknown speed: 10 Mbps duplex: full mac: N/A
Bluetooth:
  Device-1: Intel AX201 Bluetooth type: USB driver: btusb
  Report: rfkill ID: hci0 state: up address: see --recommends
  Local Storage: total: 476.94 GiB used: 22.29 GiB (4.7%)
  ID-1: /dev/nvme0n1 vendor: Micron model: 2210 MTFDHBA512QFD
  ID-1: / size: 458.75 GiB used: 21.79 GiB (4.8%) fs: ext4 dev: /dev/nvme0n1p2
  ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%)
    dev: /dev/nvme0n1p3
  System Temperatures: cpu: 70.0 C pch: 55.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 0
  Processes: 326 Uptime: 36m Memory: 15.46 GiB used: 5.32 GiB (34.4%)
  Shell: Bash inxi: 3.3.24
Please, mark your code output for better readability as </> code-symbol in post-editor. Thanks.
is that good?
Yes! Very much so.
Unfortunately, the BT chipset in use has many known issues on Linux:
https://searx.be/search?q=linux%20Intel%20AX201%20Bluetooth%20issue&categories=general
It is one of those chipsets, pairing WiFi and BT functionality on one chip…
i see thanks for the help anyway i suppose the only real options i have is to wait for a fix or upgrade my laptop
Or getting another BT usb-dongle…
