Blank spaces in bash
Hello,
I don’t know if this is a bug or just a matter of setting it up correctly.
Recently I have large gaps between individual words in the terminal. This makes it all look quite confusing.
Does anyone know a way to fix this?
First of all, that does not look like a mono-spaced font. What font is it, by the way?
The font is https://fonts.google.com/specimen/Roboto
I chose standard Roboto.
You think it has some thing to do with the type of font?
Roboto is a true-type font, so I’m betting that’s the problem. Try something standard like Monospace and see what happens.
Now, if you want to use a monospace Roboto font, try installing ttf-roboto-mono.
I like to use ttf-jetbrains-mono-nerd for the terminal.
That was the solution. Thanks. :wink:
