I have installed recently endeavour os and everything seems to be working finely. I’m facing some issue though… Everytime I lock my workstation and I try to unlock it in it returns this blacksreen
This looks like a laptop. I assume you have installed Xfce? Does it do this when you close the lid and then come back and open. Can you lock it unlock it right after? Or does it sit locked for a while and then you come back and try to unlock and is the lid closed? There is a setting for the closing the laptop lid in settings somewhere. It could be that maybe. Also check sleep and suspend. You may have to try these settings and experiment.
That’s the default DE that comes within the distro right after the installation. Personally, I was looking for a Openbox or lxqt DE. Maybe in some new future releases.
Extended partitions are not an issue for linux at all… you could have created /home on a samba share on a remote server and bind it to the system without an issue
As you say “lock my workstation” it will be about the used locker command/backend in use.
What ISO do you use for install? As we have had an issue with locker (light-locker) before…
to see this try the keystrokes i give you before (switching to TTY2 and back to TTY7, where TTY7 is where X is running and the Login Manager, TTY2 is one of the virtual Terminals where you can log in textbased to the system)
What says: pacman -Qs light-locker
Also a journal from the timespace where you lock the system would be helpfull:
something like:
journalctl --since "10 minutes ago"
will give the journaloutput from last 10 minutes before, you can autopastebin this and provide the link to the log like this:
journalctl --since "10 minutes ago" | curl -F 'f:1=<-' ix.io
it will give you a short url after command is running.
but the command: pacman -Qs light-locker shows if the named package is installed or not on your system.
We do not use light-locker as it is not working properly, so better uninstall it. sudo pacman -R light-locker
And may it helps to switch to tty2 and then back to tty7 to get the lock screen shown up again.
[ Ctrl+Alt+F2 ] and then [ Ctrl+Alt+F7 ]
If not show your related config:
cat ~/.config/xfce4/xfconf/xfce-perchannel-xml/xfce4-session.xml
to pastebin it and give url to the pastebin:
