Blacklisting a kernel is module not working
blacklist <kernel_module> at etc/modprobe.d/blacklist.conf
is not working. I’m using eos with systemd boot. Any suggestions?
What shows: cat /etc/modprobe.d/blacklist.conf ?
It would be nice if your post was more descriptive. What module are you trying to blacklist and for what reason?
03:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8821CE 802.11ac PCIe Wireless Network Adapter
	Subsystem: Lenovo RTL8821CE 802.11ac PCIe Wireless Network Adapter
	Flags: bus master, fast devsel, latency 0, IRQ 135
	I/O ports at d000 [size=256]
	Memory at df000000 (64-bit, non-prefetchable) [size=64K]
	Capabilities: <access denied>
	Kernel driver in use: rtw_8821ce
	Kernel modules: rtw88_8821ce, 8821ce
wifi speed is very low
Its blank
So you should be trying to blacklist rtw88_8821ce?
Edit:
sudo nano /etc/modprobe.d/blacklist.conf
add
ctrl + o then enter to save
ctrl + x to exit nano
reboot
Edit: Or which ever module you are trying to blacklist.
Thanks
