ich habe den Befehl korrigiert…
dein pastebin zeigt nur den xorg log und der is ohne warnungen, könnte im journal irgendwas geben was einen Hinweis gibt… aber wenn es jetzt geht .
journal sieht gut aus, sehe das du r8168 benutzt, kann sein das wir dich mal fragen was zu testen da wir gerade daran arbeiten einen Weg zu finden diese Netzwerkkarte zu ermitteln um den passenden “Treiber” zu verwenden/installieren.
Aug 02 21:26:30 endeavouros kernel: r8168 Gigabit Ethernet driver 8.048.03-NAPI loaded
Aug 02 21:26:30 endeavouros kernel: r8168 0000:02:00.0: enabling device (0000 -> 0003)
Aug 02 21:26:30 endeavouros kernel: input: PC Speaker as /devices/platform/pcspkr/input/input2
Aug 02 21:26:30 endeavouros kernel: r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
Aug 02 21:26:30 endeavouros kernel: r8168 Copyright (C) 2020 Realtek NIC software team <nicfae@realtek.com>
This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[ 6.037] (II) NVIDIA(0): Validated MetaModes:
[ 6.037] (II) NVIDIA(0): "DFP-1:nvidia-auto-select"
[ 6.037] (II) NVIDIA(0): Virtual screen size determined to be 1920 x 1080
[ 6.040] (--) NVIDIA(0): DPI set to (304, 304); computed from "UseEdidDpi" X config
[ 6.040] (--) NVIDIA(0): option
[ 6.040] (II) NVIDIA: Using 6144.00 MB of virtual memory for indirect memory
[ 6.040] (II) NVIDIA: access.
[ 6.042] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 6.042] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 6.042] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 6.042] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 6.042] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 6.042] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 6.042] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 6.042] (II) NVIDIA(0): Config Options in the README.
[ 6.059] (II) NVIDIA(0): Setting mode "DFP-1:nvidia-auto-select"
[ 6.133] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 6.133] (==) NVIDIA(0): Backing store enabled
[ 6.133] (==) NVIDIA(0): Silken mouse disabled
[ 6.133] (==) NVIDIA(0): DPMS enabled
[ 6.133] (WW) NVIDIA(0): Option "NoLogo" is not used
[ 6.133] (II) Loading sub module "dri2"
[ 6.133] (II) LoadModule: "dri2"
[ 6.133] (II) Module "dri2" already built-in
[ 6.134] (II) NVIDIA(0): [DRI2] Setup complete
[ 6.134] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
Nvidia läuft auch erkennt den Monitor und lädt alles nötige…
ACPID könntest du aktivieren um zu sehen ob das was ändert sollte aber eigentlich nicht nötig sein, kann genauso zu anderen Problemen führen …
