Best workflow when Arch mirrorlist is updated?
I wonder what the suggested “best” workflow is when a new Arch mirrorlist arrives with an update, i.e., pacdiff shows a fresh mirrorlist with more/updated entries?
Should we
  1. (o)verwrite from the pacnew file, then run simple-reflector?
  2. (r)emove the pacnew file, then run simple-reflector?
  3. only run simple-reflector?
  4. do nothing?
Background: I’m a little unsure how this is handled internally—does reflector pull from the local mirrorlist or does it pull a fresh copy online?
For today’s update, I let it (o)verwrite from the pacnew file (destroying my old reflector list), then immediately ran simple-reflector again. The list now looks good to me, but I’d surely like to know the suggested “best” way, and why
Thanks for any enlightenment!
Fresh copy from online.
Not best workflow, but what I use.
I have added NoExtract = etc/pacman.d/mirrorlist to pacman.conf so that the new mirror list is not copied to disk from cache.
I use sometime milcheck to check that my mirror(s) are ok. Mostly osbeck server.
Ah, good, thanks So I could actually do 1, 2, or 3 above without any negative side effects.
I do 1 from your list above, but, as you say, it looks like any of 1-3 is OK.
Thanks for the help! Would have picked you both for a solution, but we can only have one, so it’ll be @EOS :wink:
That’s fine, I didn’t know that it fetched a fresh mirror list.
One other advantage of 1 or 2 is that then you don’t have a stray .pacnew file lurking in your system to confuse at a later date.
I have a script which run milcheck and ask if I want to update the mirrorlist (with reflector), before upgrade.
