Best Way to Update/Upgrade System
Which way is the best/recommended way to update/upgrade EndeavourOS applications and system?
pacman -Syu or yay -Syu
Just yay will update packages from both the official repositories and those from AUR if you have any installed.
Personally I changed to paru, it does not ask what packages I do not want to update! Skipping a package by mistake as the message says may cause problems.
If I were me, I’d do what this guy suggested.
Thanks! I had forgotten about that post.
