What’s the best way to install Endevour-OS with both KDE Plasma and I3? I want to try using both…but I know for a fact they have some conflicting packages such as lightdm and sddm, and some other packages.
If no easy way, guess if someone had the core-required packages to get the config files working from EndevourOS i3wm install that would be great.
As far as my testing goes, installing any number of X11 window managers alongside ONE full desktop environment is safe and doesn’t cause issues. The thing that causes issues is Settings Managers. Most, if not all, window managers don’t have a real Settings Manager, as such they don’t conflict with full desktop environments.
Now, whether you should install multiple window managers is debatable.
I have 5 (Openbox, i3, Bspwm, dk, hyprland [WC]) and Cinnamon. All good over here.
Just install one thing first, then install whatever is needed after.
EndeavourOS doesn’t provide customised configs for everything. I think they only provide custom setups for KDE and i3. The rest are in a repo that I am not sure is maintained.
Hahah…yeah I got it working from the info the lovely comunity provided. On top of that I learned a bit about its config and stuff which was awesome. Thanks though so much!!!
