It’s because if the hardware isn’t recognized it’s not going to show or work. It has to be firmware or kernel module one would think. But it could be some other issue also. ![]()
Windows fast start has always been turned off. But earlier today I tried to reset the bios once again and BIOS Fast Boot stayed on, but I’ve now turned it off again.
It doesn’t work on live ISO, I used a tethering connection with my smartphone to configure and update. By desktop did you mean the other distributions I tried?
Were the logs you shared in your initial post, before or after that BIOS reset?
Might it be worth running lspci -vnn again?
@ricklinux, KDE Plasma is the DE.
lspci -vnn:
https://0x0.st/Xg6N.txt
Under Windows, seeing as that’s where it’s working, might you be able to share your WiFi driver info?
netsh wlan show drivers
Nome da interface: Wi-Fi
Driver : Intel(R) Wi-Fi 7 BE200 320MHz
Fornecedor : Intel Corporation
Provedor : Intel
Data : 24/07/2024
Versão : 23.70.2.3
Arquivo INF : oem59.inf
Tipo : Driver Wi-Fi Nativo
Tipos de rádio com suporte : 802.11b 802.11g 802.11n 802.11a 802.11ac 802.11ax 802.11be
Suporte para o modo FIPS 140-2: Sim
Suporte para Proteção de Quadro de Gerenciamento 802.11w: Sim
Rede hospedada compatível: Não
Autenticação e codificação com suporte no modo de infraestrutura:
Abrir Nenhum
Abrir WEP-40bit
Abrir WEP-104bit
Abrir WEP
WPA-Enterprise TKIP
WPA-Enterprise CCMP
WPA-Personal TKIP
WPA-Personal CCMP
WPA2-Enterprise TKIP
WPA2-Enterprise CCMP
WPA2-Personal TKIP
WPA2-Personal CCMP
Abrir Definido pelo fornecedor
WPA3-Personal CCMP
WPA3-Personal GCMP-256
Definido pelo fornecedor Definido pelo fornecedor
WPA3-Enterprise 192 Bits GCMP-256
OWE CCMP
OWE GCMP-256
WPA3-Enterprise CCMP
Número de bandas suportadas : 2
2,4 GHz [ 2412 MHz - 2472 MHz]
5 GHz [ 5180 MHz - 5885 MHz]
Serviço IHV presente : Sim
OUI do adaptador IHV : [00 00 00], tipo: [00]
Caminho da DLL de extensibilidade de IHV: C:\Windows\System32\DriverStore\FileRepository\netwtw6e.inf_amd64_8231e64986f91750\IntelIHVRouter16.dll
ClSID de extensibilidade de UI de IHV: {00000000-0000-0000-0000-000000000000}
CLSID de diagnósticos de IHV : {00000000-0000-0000-0000-000000000000}
Vídeo sem Fio com Suporte: Sim (Driver de Gráficos: Sim, Driver Wi-Fi: Sim)
@KakoMG
You could try installing linux-firmware-git and then reboot.
linux-firmware-git installed, now the version is 20241001.95bfe086-1
lspci, lsusb, inxi, hwinfo after install and reboot:
https://0x0.st/Xg6W.txt
Okay… have you tried installing the Pci-e card in another slot? Or is there only one slot available? Then maybe take it out and re-seat it. I had another user move it to another slot and then it worked. It wasn’t the exact same card but if the hardware isn’t recognized it won’t work.
Edit: It looks like you have 2 Pci-e slots so try moving it to the other slot.
I’m going to change it, I didn’t change it before because in Windows it’s working normally. But unfortunately I’ll have to do it tomorrow because to change the slots I’ll have to open the case and I don’t have any tools at the moment. I have an old BCM4350 that I used in that same slot and it worked on Linux and Windows, bluetooth+wifi.
This may be so but the be200 is WiFi 7 is quite different hardware.
WiFi 7 is the upcoming WiFi standard, also known as IEEE 802.11be Extremely High Throughput (EHT). It works across all three bands (2.4 GHz, 5 GHz, and 6 GHz) to fully utilize spectrum resources.
Edit: Make sure you have it unplugged and ground yourself to remove any static before touching any component inside the case.
@KakoMG
Hope this works for you. ![]()
I switched to the second pci-e x1 slot on the motherboard, but unfortunately it didn’t appear in lspci. ![]()
This bug is not specific to EOS, maybe some kernel bug? I have tried Ubuntu stock kernel(6.8), Ubuntu oem(6.10), Xanmod(6.10) and now EOS kernel(6.11)
Have you tried using the firmware 90 or 92 from this page that is highlighted?
https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/tree/
On Ubuntu, yes, I replaced all the linux-firmware files, including the iwlwifi 90 and 92 .ucode files (sorry for my mistake, I said “core” last time). Now on EOS I installed linux-firmware-git which is up to date with the files released until yesterday, v.20241001.95bfe086-1. I can download and replace the files if they are different.
Not sure if they are different but i thought i would ask if you tried these firmware files from this link.
Edit: It seems there is some issue with amd motherboards and this card. Read this!
Edit: This link also
@KakoMG
On one Intel support page it shows a user was ble to connect after adding these firmware but on a different distro. ![]()
iwlwifi-gl-c0-fm-c0-86.ucode
iwlwifi-gl-c0-fm-c0.pnvm
