Yes…check /etc/modprobe.d/modprobe.conf
That file does not exist
Check just the /etc/modprobe.d
There is one file. Blacklist.conf. In it, blacklist b43
You can try commenting it out or removing it from blacklist.
Already tried that
Hmm? I’m not sure what else to suggest?
Edit: Check this
https://wiki.archlinux.org/index.php/Kernel_module#Automatic_module_loading_with_systemd
Do you know what deny-listed Means?
Did you check usr/lib/modprobe.d it may have the same module listed and then it blacklists when loading. So it could have wl in it?
Edit: or b43
Check this:
journalctl - b | grep brcmfmac
Edit: Actually maybe it should be this
journalctl - b | grep b43
So if it’s the b43 being blacklisted…that is the firmware.
Ugh. Thank you! I got it
I had to remove wl. Sorry for being so clueless
Well i was wondering if it automatically was blacklisting it because it’s already a kernel module that loads.
So to recap. If anyone has any issues with a Broadcom wifi card using the brcmfmac driver, you may need to remove Broadcom-wl-dkms completely.
Thank you so much! Have a nice night
No problem sometimes it’s difficult to figure these things out.
I have (had) the exact issue here on my intel iMac.
I removed the package [ broadcom-wl-dkms ] as suggested here and this solved my issue as well. Thank You.
$ lspci -vnn -d 14e4:
03:00.0 Network controller [0280]: Broadcom Inc. and subsidiaries BCM43602 802.11ac Wireless LAN SoC [14e4:43ba] (rev 01)
— Removed the package broadcom-wl-dkms —
pacman -Ss broadcom-wl-dkms
community/broadcom-wl-dkms 6.30.223.271-28
Broadcom 802.11 Linux STA wireless driver
Thank you very much.
EDIT: This was a fresh installation of endeavourOS.
EndeavourOS_Atlantis_neo-21_5.iso
