Battery shellscript for Pinebook Pro
As the EOS default battery.sh for i3blocks not work on Pinebook Pro you can use this…
All credit go to name in script
#!/bin/bash
#simple Shellscript for i3blocks on Pinebook pro
#05012020 geri123@gmx.net Gerhard S.
#battery-symbols: on Manjaro you need the awesome-terminal-fonts package installed!
PERCENT=$(cat /sys/class/power_supply/cw2015-battery/capacity)
STATUS=$(cat /sys/class/power_supply/cw2015-battery/status)
case $((
 $PERCENT >= 0 && $PERCENT <= 20 ? 1 :
 $PERCENT > 20 && $PERCENT <= 40 ? 2 :
 $PERCENT > 40 && $PERCENT <= 60 ? 3 :
 $PERCENT > 60 && $PERCENT <= 80 ? 4 : 5)) in
       (1) echo $STATUS:"" :$PERCENT%;;
       (2) echo $STATUS:"" :$PERCENT%;;
       (3) echo $STATUS:"" :$PERCENT%;;
       (4) echo $STATUS:"" :$PERCENT%;;
       (5) echo $STATUS:"" :$PERCENT%;;
esac
It also work with polybar.
You have useful script for i3 status ,i3blocks or polybar pls share it might help others …
https://github.com/endeavouros-team/i3-EndeavourOS/commit/d17762b28e83532942817c448ebc6c3fcc7e9556
