I switched since years to root using
su -
Since a few days I got the error
-bash: append_path: command not found
Is there something missing / deleted? Or is the “-” obsolete?
su -
Here it is working as usual.
Is it possible that you made some alias or function related to su?
You could check what the following command shows:
type su
type su: “su is /usr/bin/su”
util-linux 2.36-4
The issue is only present of some of my machines - not of all. But all are running Arch testing.
This is probably caused by an old dotfile, e.g. /root/.bashrc
or similar. Check the contents and check whether there’s an append_path
command - if so, switch it to something which works.
I have no old dotfile in /root/ except .bash_history The password is working, and I am in the directory of root if I execute su - . The error message is repeated three times so I think it is related to someting in directory /root/. But it seems to be in a subfolder so I think I will live with it
Hi, Arch user here. This happened to me after last system update. After inspecting /var/log/pacman.log
to see what changed, I found this line:
warning: /etc/profile installed as /etc/profile.pacnew
Updated packages were filesystem, perl, srt and sudo.
/etc/profile
is used to set system wide environmental variables on users shells.
/etc/profile
contained appendpath function declaration, /etc/profile.pacnew
contained append_path
If that is also your case, try renaming
/etc/profile
=> /etc/profile.old
/etc/profile.pacnew
=> /etc/profile
Hope it helps.
Thanks - that was the cause!
