Avahi-daemon and systemd-resolved
Hello friends,
Can you confirm if either avahi-daemon or systemd-resolved or both are running simultaneously in your computer when running KDE (provided the settings is endeavour os default and you did not enabled or disabled either of them).
Thank you in advance.
For people who don’t know how to check:
Use terminal and use the commands one by one and see the response
sudo systemctl status avahi-daemon
sudo systemctl status systemd-resolved
avahi-daemon – active (running)
systemd-resolved – inactive (dead)
Thank you @eso.
A few more samples is required to say with confidence that in eos, by default avahi-daemon is enabled and systemd-resolved is disabled while running KDE.
Come on friends. One vote done. 4 more to go.
avahi is enabled
systemd-resolved was enabled by me as my vpn needs it.
