Hi @all
This is a freshly installed EOS KDE.
At system start 2 conkys should be started. Unfortunately only one is started.
First I had created 2 entries for conky in the KDE options
conky -c /home/xenox/conky_right --daemonize --pause=1
conky -c /home/xenox/conky_left --daemonize --pause=1
After a reboot the second entry was gone every time. So I put both calls in one line in the KDE autostart menu.
conky -c /home/xenox/conky_right && conky -c /home/xenox/conky_left --daemonize --pause=1
But even with this only one instance, the second one, of conky will be started.
However, I had it exactly like this before and it worked. I would be very grateful for any tips on how to fix this.
Greetings and thanks for reading.
