Hello, i’m new here and installed Endeavour OS a few months ago.
So far everything works (besides User induced errors ^_^).
Since i’m more or less forced to use Wifi, i recognized that Wifi sometimes takes very long to connect, when i’m logged on ( up to about 2 Minutes) sometimes it is already connected when the desktop shows up, directly after login.
This is probably not an display issue only because some apps like Steam report no internet connection, even after Wifi is finally connected. A app restart fixes this issue.
So my Question is how is it possible to load the Wifi-Driver early or are there any other options to prevent this issue/bug ?
Data about my machine
EndeavourOS rolling rolling
Kernel: x86_64 Linux 6.13.8-arch1-1
Shell: bash 5.2.37
Resolution: 4680x1920 (3 Monitors)
DE: KDE
WM: KWin
GTK Theme: Breeze-Dark [GTK2], Breeze [GTK3]
con Theme: breeze-dark
Disk: 2,5T / 5,4T (48%)
CPU: AMD Ryzen 7 5700G with Radeon Graphics @ 16x 4.851GHz
GPU: AMD Radeon RX 6700 XT (radeonsi, navi22, LLVM 19.1.7, DRM 3.61, 6.13.8-arch1-1)
RAM: 5833MiB / 48033MiB
Data about Wifi
face |link level noise |
wlan0: 29. -81. -256
Network controller: Intel Corporation Wi-Fi 6E(802.11ax) AX210/AX1675* 2x2 [Typhoon Peak] (rev 1a)
Subsystem: Intel Corporation Wi-Fi 6 AX210 160MHz
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
Kind Regard’s
TarBall81
