Auto login not working
Hi I checked auto login at install it is asking me for password I have searched to find auto login in the menu no luck where is it
Hi,
this was already discussed in another topic. As far as I understand this option will be removed. :slightly_smiling_face:
you have to go to terminal, and you have to enable the autologin for now i guess, but is not so terruble dificult…
https://wiki.archlinux.org/index.php/LightDM#Enabling_autologin
check also that accountservice is installed. looks dificult but it it isnt.
ok thanks will do it later
Thanks ringo. That link solved it for me yesterday.
/etc/lightdm/lightdm.conf
[Seat:*] autologin-user= *username*
You must also be a part of autologin group, see groups in terminal
Hello,
By the way, autologin option in Calamares still doesn’t work in a VM or a real machine.
I did all the things the wiki asked me to do, but auto login still doesn’t work… :thinking:
Welcome citroen :slight_smile: are you in groups in autologin ?
Jazeker. :wink:
$ groups lemon
sys log network floppy scanner power adm wheel audio lp optical storage video users rfkill autologin
can you passbin lightdm.conf ?
As an alternative you could try this GUI solution.
yay -S lightdm-settings
Run the app Login Window . This can now also be opened from Settings Manager .
Under the ‘Users’ tab, you can enter the user that will get logged in automatically.
After installing this I still have to log in manually… :roll_eyes:
2020-01-18_14-30
@ringo
# General configuration
# start-default-seat = True to always start one seat if none are defined in the configuration
# greeter-user = User to run greeter as
# minimum-display-number = Minimum display number to use for X servers
# minimum-vt = First VT to run displays on
# lock-memory = True to prevent memory from being paged to disk
# user-authority-in-system-dir = True if session authority should be in the system location
# guest-account-script = Script to be run to setup guest account
# logind-check-graphical = True to on start seats that are marked as graphical by logind
# log-directory = Directory to log information to
# run-directory = Directory to put running state in
# cache-directory = Directory to cache to
# sessions-directory = Directory to find sessions
# remote-sessions-directory = Directory to find remote sessions
# greeters-directory = Directory to find greeters
# backup-logs = True to move add a .old suffix to old log files when opening new ones
# dbus-service = True if LightDM provides a D-Bus service to control it
[LightDM]
#start-default-seat=true
#greeter-user=lightdm
#minimum-display-number=0
#minimum-vt=7 # Setting this to a value < 7 implies security issues, see FS#46799
#lock-memory=true
#user-authority-in-system-dir=false
#guest-account-script=guest-account
#logind-check-graphical=false
#log-directory=/var/log/lightdm
run-directory=/run/lightdm
#cache-directory=/var/cache/lightdm
#sessions-directory=/usr/share/lightdm/sessions:/usr/share/xsessions:/usr/share/wayland-sessions
#remote-sessions-directory=/usr/share/lightdm/remote-sessions
#greeters-directory=$XDG_DATA_DIRS/lightdm/greeters:$XDG_DATA_DIRS/xgreeters
#backup-logs=true
#dbus-service=true
# Seat configuration
# Seat configuration is matched against the seat name glob in the section, for example:
# [Seat:*] matches all seats and is applied first.
# [Seat:seat0] matches the seat named "seat0".
# [Seat:seat-thin-client*] matches all seats that have names that start with "seat-thin-client".
# type = Seat type (local, xremote)
# pam-service = PAM service to use for login
# pam-autologin-service = PAM service to use for autologin
# pam-greeter-service = PAM service to use for greeters
# xserver-command = X server command to run (can also contain arguments e.g. X -special-option)
# xmir-command = Xmir server command to run (can also contain arguments e.g. Xmir -special-option)
# xserver-config = Config file to pass to X server
# xserver-layout = Layout to pass to X server
# xserver-allow-tcp = True if TCP/IP connections are allowed to this X server
# xserver-share = True if the X server is shared for both greeter and session
# xserver-hostname = Hostname of X server (only for type=xremote)
# xserver-display-number = Display number of X server (only for type=xremote)
# xdmcp-manager = XDMCP manager to connect to (implies xserver-allow-tcp=true)
# xdmcp-port = XDMCP UDP/IP port to communicate on
# xdmcp-key = Authentication key to use for XDM-AUTHENTICATION-1 (stored in keys.conf)
# greeter-session = Session to load for greeter
# greeter-hide-users = True to hide the user list
# greeter-allow-guest = True if the greeter should show a guest login option
# greeter-show-manual-login = True if the greeter should offer a manual login option
# greeter-show-remote-login = True if the greeter should offer a remote login option
# user-session = Session to load for users
# allow-user-switching = True if allowed to switch users
# allow-guest = True if guest login is allowed
# guest-session = Session to load for guests (overrides user-session)
# session-wrapper = Wrapper script to run session with
# greeter-wrapper = Wrapper script to run greeter with
# guest-wrapper = Wrapper script to run guest sessions with
# display-setup-script = Script to run when starting a greeter session (runs as root)
# display-stopped-script = Script to run after stopping the display server (runs as root)
# greeter-setup-script = Script to run when starting a greeter (runs as root)
# session-setup-script = Script to run when starting a user session (runs as root)
# session-cleanup-script = Script to run when quitting a user session (runs as root)
# autologin-guest = True to log in as guest by default
# autologin-user = User to log in with by default (overrides autologin-guest)
# autologin-user-timeout = Number of seconds to wait before loading default user
# autologin-session = Session to load for automatic login (overrides user-session)
# autologin-in-background = True if autologin session should not be immediately activated
# exit-on-failure = True if the daemon should exit if this seat fails
[Seat:*]
#type=local
pam-service=lightdm
pam-autologin-service=lightdm-autologin
#pam-greeter-service=lightdm-greeter
#xserver-command=X
#xmir-command=Xmir
#xserver-config=
#xserver-layout=
#xserver-allow-tcp=false
#xserver-share=true
#xserver-hostname=
#xserver-display-number=
#xdmcp-manager=
#xdmcp-port=177
#xdmcp-key=
#greeter-session=example-gtk-gnome
#greeter-hide-users=false
#greeter-allow-guest=true
#greeter-show-manual-login=false
#greeter-show-remote-login=true
#user-session=default
#allow-user-switching=true
#allow-guest=true
#guest-session=
session-wrapper=/etc/lightdm/Xsession
#greeter-wrapper=
#guest-wrapper=
#display-setup-script=
#display-stopped-script=
#greeter-setup-script=
#session-setup-script=
#session-cleanup-script=
#autologin-guest=false
autologin-user=richard
#autologin-user-timeout=0
#autologin-in-background=false
autologin-session=session
#exit-on-failure=false
# XDMCP Server configuration
# enabled = True if XDMCP connections should be allowed
# port = UDP/IP port to listen for connections on
# listen-address = Host/address to listen for XDMCP connections (use all addresses if not present)
# key = Authentication key to use for XDM-AUTHENTICATION-1 or blank to not use authentication (stored in keys.conf)
# hostname = Hostname to report to XDMCP clients (defaults to system hostname if unset)
# The authentication key is a 56 bit DES key specified in hex as 0xnnnnnnnnnnnnnn.  Alternatively
# it can be a word and the first 7 characters are used as the key.
[XDMCPServer]
#enabled=false
#port=177
#listen-address=
#key=
#hostname=
# VNC Server configuration
# enabled = True if VNC connections should be allowed
# command = Command to run Xvnc server with
# port = TCP/IP port to listen for connections on
# listen-address = Host/address to listen for VNC connections (use all addresses if not present)
# width = Width of display to use
# height = Height of display to use
# depth = Color depth of display to use
[VNCServer]
#enabled=false
#command=Xvnc
#port=5900
#listen-address=
#width=1024
#height=768
#depth=8
what is your .dmrc your hidden file in home ?
you have removed the ‘#’ before pam-service and pam-autologin-service ?
i guess… ? i dont quite remember if that needed…
first of all you need to see your .dmrc that pointing to the right session, if no .dmrc or session si false it also wont login … you can doe autologin-session=xfce but only when that needed, otherwise # in front ,
regular it searches for .dmrc in your personal folder
Removing the hash in front of the pam services is what I read here: https://forum.manjaro.org/t/enable-autologin-in-xfce/34489
My .dmrc says this:
[Desktop]
Language=nl_NL.utf8
Session=xfce
Add # in autologin-session=session that give lightdm confusion or change to xfce
I just tried my approach with ligtdm-settings in a fresh VirtualBox XFCE install and auto-login worked just as I expected.
It’s possible you have some conflicting entries in /etc/lightdm/lightdm.conf.
For reference, here is my fresh /etc/lightdm/lightdm.conf. For better reading I have left out all the commented and therefore unrelevant entries:
[LightDM]
[Seat:*]
autologin-user=username
[XDMCPServer]
[VNCServer]
Yes, this worked Ringo.
And @2000, thanks for your effort as well!
Hi,
session = desktop environnement you can choose at the top right of lightDM connect screen before autologin is working.
