Using a fresh EOS install (August ISO) on a desktop in my basement.
Is it just me or during daylight time, the background is brighter than it is during the evening? If it’s not just my imagination, where/how do I turn that option off? While I see the advantage of it, when a PC is being used in a dark room… I always have a light on when I’m down here on the server and I find this auto-changing a TINY bit annoying.
I’m using Cinnamon and the only thing that really changes is the default, background image. During daylight hours, it’s “normal”. During the evening hours/last time, the background image is a tad darker.
So far, I haven’t been able to find the setting that controls that behavior.
personal couldnot find it, i think is also a gnome behaviour , thats especially with the background dont know if you have something extra
if you install redshift and install redshift applet you can control, i know standard wallpaper in gnome can shift from light to dark depend on the day does it do also with a own wallpaper ?
I had an idea it’s this one, this is the default Gnome adawaita wallpaper that changes during the day, it’s built-in the wallpaper. The only way you can change it is to pick the adwaita-day, adwaita-morning or the adwaita-night wallpaper (which one you prefer) in the wallpaper menu.
LOL, I never would have suspected the actual background itself of doing that. I like the background pattern but that brightness shifting was just rubbing me the wrong way. Thanks for the info!
