AUR/yay-bin-11.3.0-1-x86_64:
/usr/bin/yay sha1: b1166c4145eb194fd44e9c0a8a295b4ad311b07f
endeavouros/yay-11.3.0-1-x86_64:
/usr/bin/yay sha1: 69fd0c3d66cee201c31e16d2ee62e34cf3aa77a0
Why would they? They aren’t identical.
Two things:
makepkg
will always create reproducable builds. I believe it depends what you do in the PKGBUILD.AUR/yay-bin is pre-build and endeavouros/yay’s PKGBUILD just copy AUR/yay-bin
The package contains the metadata which is different. Also things like the directories can be different.
Even if the binaries are identical, the package won’t be.
The problem is that binaries are identical
yeah if i rebuild the package the sha1sum is different from endeavour one but its also possible it is rebuilded mayby for some reason.
With the current build instructions/flags in the yay PKGBUILD you can’t expect reproducible builds anyways. The use of CGO might also play a role.
https://wiki.archlinux.org/title/Go_package_guidelines#Flags_and_build_options
f.e. -trimpath
flag…
This is a rather pointless argument - If I have my compiler flags set differently than say, the person who built the aur binary, then I will get a different answer.
Did you read the comment in README? It seems pretty important.
Especially this part “Note: this PKGBUILD is currently not used.”
We are building yay
from source.
Furthermore, gcc does not create reproducible builds. Of course, this does not apply to yay
which is written in Golang, but I’m almost positive that Golang compiler also does not make reproducible builds.
