This happened when i was just watching youtube. Audio on windows(i have dual boot) and external speakers works fine. Some time after this audio randomly appeared for ~2 seconds and then faded out.
Output of inxi -Aaz
Device-1: Intel Comet Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel
v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
chip-ID: 8086:06c8 class-ID: 0403
Device-2: NVIDIA TU106 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:10f9 class-ID: 0403
API: ALSA v: k6.17.2-arch1-1 status: kernel-api
Server-1: sndiod v: N/A status: off tools: aucat,midicat,sndioctl
Server-2: PipeWire v: 1.4.9 status: active with: 1: pipewire-pulse
Same here, I wonder what happened. No video will load and my blue tooth head phones aren’t appearing under sound - output devices
Device-1: Intel Tiger Lake-H HD Audio vendor: CLEVO/KAPOK
driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl
bus-ID: 0000:00:1f.3 chip-ID: 8086:43c8 class-ID: 0403
Device-2: NVIDIA GA106 High Definition Audio driver: snd_hda_intel
v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:228e class-ID: 0403
API: ALSA v: k6.18.7-arch1-1 status: kernel-api
Server-1: PipeWire v: 1.4.10 status: active with: 1: wireplumber
status: active 2: pipewire-alsa type: plugin 3: pw-jack type: plugin
tools: pw-cat,pw-cli,wpctl
Server-2: PulseAudio v: 17.0-98-gb096 status: active tools: pacat,pactl
Bink
February 2, 2026, 8:43pm
3
Welcome to the community @sharkow
If this began after an update, have you tried booting with the LTS kernel and confirmed if it is, or isn’t an issue there?
That sounds like it might be an unrelated issue @garyghost .
@sharkow 's is with respect to internal speakers, but audio to external speakers works fine.
Yours is with respect to Bluetooth headphones and video playback.
xircon
February 3, 2026, 12:28am
4
Also, check if audio works with any app that is not a browser, I once muted the browser somehow, which left me scratching my head for a while!
sharkow
February 3, 2026, 11:55am
5
This happened not after update
sharkow
February 3, 2026, 11:56am
6
As i said external speakers work
About an hour ago, I updated, and these audio-related packages were included…
upgraded libpipewire (1:1.4.10-1 -> 1:1.4.10-2)
upgraded pipewire (1:1.4.10-1 -> 1:1.4.10-2)
upgraded pipewire-audio (1:1.4.10-1 -> 1:1.4.10-2)
upgraded gst-plugin-pipewire (1:1.4.10-1 -> 1:1.4.10-2)
upgraded pipewire-jack (1:1.4.10-1 -> 1:1.4.10-2)
upgraded pipewire-pulse (1:1.4.10-1 -> 1:1.4.10-2)
Try running an update and reboot.
Bink
February 4, 2026, 10:16pm
9
sharkow:
Update did not helped
How’d you go trying the LTS kernel?
sharkow
February 17, 2026, 8:35pm
11
It just started working at some moment between now and my previous message while i was not using linux. Why it wasn`t working? Why it started working while i was not even using linux?
sharkow
February 18, 2026, 7:05pm
12
Okay, i found out. When i restart in windows and then boot to linux audio don`t work, but if i turn off pc and boot to linux it works
Bink
February 18, 2026, 10:14pm
13
Are you able to confirm that Fast Startup is turned off under Windows?
