Audio stuttering with Pipewire
Sure
yt -x -f bestaudio/best' -o ~/Downloads/audio-file 'https://invidious.kavin.rocks/watch?v=4v4Mcncvsac'
My bad, not the right link
Edit: Fixed it
Ya it’s not doing anything?
Edit: What am i doing wrong?
Screenshot_20220128_140616
Oh I see, remove the ’ after bestaudio/best
That’s an error on my part
Sorry, I thought i had youtube-dl installed.
Edit: Still not working as I’m not familiar with this. Remove bestaudio/best
Sorry once again. There was no file format specified. It should be
yt -x -f bestaudio/best -o ~/Downloads/audio-file.opus 'https://invidious.kavin.rocks/watch?v=4v4Mcncvsac'
I just downloaded it the way i know how to do it but it’s webm.
Yeah use the new command I sent you
It doesn’t work because i think you are assuming some things which i don’t know. So i changed it and is now downloading.
Alright
Alternatively you can go to the link https://invidious.kavin.rocks/watch?v=4v4Mcncvsac
and download it there because invidious has an option to download the video as an audio file
I just see a DT video.
Scroll down and you’ll see this
You don’t possess a single audio file? Not one?
Oh wow I think I found my issue
I changed the polyphonics setting and made it slightly higher
I’ll lower it and test it in a few minutes. But I’m 90 percent sure this is the problem as I did change it a few days ago
No i don’t! :man_shrugging:
Audio works fine here!
Edit: Just tried a couple more and no issues.
Edit2: Audio is clear as a bell!
That’s good!
The stuttering only occured when I ran e.g Openspades along with it though, the music player itself didn’t stutter.
However I think I’ve solved the issue by lowering the polyphonics setting. I’ll continue trying it tomorrow and see if it occurs again, if not, well then that’s that sorted :smile:
Damn it.
problem not solved. Still stutters
I was hoping disabling EAX in OpenSpades might fix it but it has not.
I don’t know what to do to be honest. I’ll try LTS I suppose and see if that works.
The stutter persists even on the LTS kernel so I think this is solely a Pipewire problem and most likely to do with the new update that came out a few days back.
Maybe I should downgrade Pipewire
