R121
October 17, 2026, 1:15pm
1
big update yesterday apparantly, got a new lock screen n all, but thats not what im worried about
after updating n playing a video it sounded fine at first, and then it slowly sounded like the person talking was walking away, until i could barely hear them, at 150% volume, i normally listen at 30%
a sound effect plays and its just as loud as it normally is, ouch
and this only happens with my usb front header headphones, like specifically those, speakers and hdmi audio are fine, and sometimes this audio is fine when im checking the sound volume in settings, except when i do the left and right testing for them, both left and right audio clips play in both ears
its not the headphones, my spares do the same thing, and all the old posts i can find on it are without resolution, despite the fact it was working perfectly before this update, and yes it happens on the lts kernel too
ddnn
October 17, 2026, 2:10pm
2
You may just need to reset your pipewire/wireplumber config. Run the command below then reboot your device.
mv .local/state/wireplumber .local/state/wireplumber-2026-10-17
All this does is rename the folder. When you reboot, your system will then recreate the folder using the default config. You may need to adjust your volume after.
R121
October 17, 2026, 2:12pm
3
mv: cannot stat '/.local/state/wireplumber': No such file or directory
was it supposed to do that
ddnn
4
I made a mistake. Copy and paste it again. No slash at the beginning.
R121
October 17, 2026, 2:17pm
5
its still the same, this just reset my audio levels
ddnn
October 17, 2026, 2:20pm
6
In that case, share some system info.
inxi -Fxxc0z
R121
October 17, 2026, 2:23pm
7
Kernel: 7.2.10-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 16.2.1
Desktop: KDE Plasma v: 6.8.0 tk: Qt v: N/A wm: kwin_wayland dm: N/A
Type: Desktop Mobo: Micro-Star model: MPG Z790 CARBON MAX WIFI II (MS-7D89)
v: 2.0 serial: <superuser required> Firmware: UEFI vendor: American
Megatrends LLC. v: A.90 date: 07/30/2025
Info: 24-core (8-mt/16-st) model: 13th Gen Intel Core i9-13900K bits: 64
type: MST AMCP arch: Raptor Lake rev: 1 cache: L1: 2.1 MiB L2: 32 MiB
L3: 36 MiB
Speed (MHz): avg: 800 min/max: 800/5500:5800:4300 cores: 1: 800 2: 800
3: 800 4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
13: 800 14: 800 15: 800 16: 800 17: 800 18: 800 19: 800 20: 800 21: 800
22: 800 23: 800 24: 800 25: 800 26: 800 27: 800 28: 800 29: 800 30: 800
31: 800 32: 800 bogomips: 191692
Flags-basic: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Device-1: Intel Raptor Lake-S GT1 [UHD Graphics 770] vendor: Micro-Star MSI
driver: i915 v: kernel arch: Xe ports: active: HDMI-A-1 empty: DP-1, DP-2,
HDMI-A-2, HDMI-A-3, HDMI-A-4 bus-ID: 00:02.0 chip-ID: 8086:a780
Device-2: NVIDIA GA104 [GeForce RTX 3060 Ti Lite Hash Rate] vendor: Dell
driver: nvidia v: 615.78.08 arch: Ampere pcie: speed: 2.5 GT/s lanes: 8
ports: active: DP-5,HDMI-A-5 empty: DP-3,DP-4 bus-ID: 01:00.0
chip-ID: 10de:2489
Device-3: Logitech HD Webcam C615 driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 bus-ID: 1-1.4:15 chip-ID: 046d:082c
Display: wayland server: X.org v: 1.21.1.25 with: Xwayland v: 24.1.14
compositor: kwin_wayland driver:
gpu: i915,nv_platform,nvidia,nvidia-nvswitch d-rect: 4864x1848
display-ID: 1
Monitor-1: DP-5 pos: primary,top-left model: Dell E2417H res: 1920x1080
hz: 60 dpi: 93 diag: 604mm (23.8")
Monitor-2: HDMI-A-1 pos: top-center model: Asus VE228 res: 1920x1080
hz: 50 dpi: 102 diag: 547mm (21.5")
Monitor-3: HDMI-A-5 pos: bottom-r model: VA26LHDTV10T res: 1024x768 hz: 60
dpi: 84 diag: 662mm (26.1")
API: EGL v: 1.5 platforms: device: 0 drv: nvidia device: 2 drv: iris
device: 3 drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia wayland:
drv: iris x11: drv: iris inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.6 vendor: intel mesa v: 26.2.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (RPL-S)
device-ID: 8086:a780
API: Vulkan v: 1.4.363 surfaces: N/A device: 0 type: integrated-gpu
driver: mesa intel device-ID: 8086:a780 device: 1 type: discrete-gpu
driver: nvidia device-ID: 10de:2489
de: kscreen-console,kscreen-doctor gpu: gputop, intel_gpu_top, lsgpu,
nvidia-settings, nvidia-smi wl: wayland-info x11: xdpyinfo, xprop, xrandr
Device-1: Intel 700 Series Family HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:7a50
Device-2: NVIDIA GA104 High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel pcie: speed: 16 GT/s lanes: 8
bus-ID: 01:00.1 chip-ID: 10de:228b
Device-4: Micro Star USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 bus-ID: 1-13:11
chip-ID: 0db0:6c09
API: ALSA v: k7.2.10-arch1-1 status: kernel-api
Server-2: PipeWire v: 1.6.9 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin
Device-1: Realtek RTL8126 5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: speed: 8 GT/s lanes: 1 port: 6000 bus-ID: 08:00.0
chip-ID: 10ec:8126
IF: enp8s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Qualcomm NCM8x5/WCN785x Wi-Fi 7 320MHz 2x2 [FastConnect 7800]
vendor: Foxconn Band Simultaneous Wireless driver: ath12k_wifi7_pci v: N/A
pcie: speed: 8 GT/s lanes: 1 bus-ID: 09:00.0 chip-ID: 17cb:1107
Bluetooth:
Device-1: Foxconn / Hon Hai driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 bus-ID: 1-14:16 chip-ID: 0489:e10a
Report: btmgmt ID: hci0 rfk-id: 0 state: down bt-service: disabled
Local Storage: total: 16.76 TiB used: 1.74 TiB (10.4%)
ID-1: /dev/nvme0n1 model: Nextorage SSD NN4LE-1TB2CN size: 953.87 GiB
speed: 63.2 Gb/s lanes: 4 serial: <filter> temp: 43.9 C
ID-2: /dev/nvme1n1 vendor: Crucial model: CT1000T700SSD3 size: 931.51 GiB
speed: 126 Gb/s lanes: 4 serial: <filter> temp: 45.9 C
ID-3: /dev/nvme2n1 model: Nextorage SSD NN4LE-1TB2CN size: 953.87 GiB
speed: 63.2 Gb/s lanes: 4 serial: <filter> temp: 53.9 C
ID-4: /dev/nvme3n1 model: Nextorage SSD NN4LE-1TB2CN size: 953.87 GiB
speed: 63.2 Gb/s lanes: 4 serial: <filter> temp: 48.9 C
ID-5: /dev/nvme4n1 model: Nextorage SSD NN4LE-1TB2CN size: 953.87 GiB
ID-6: /dev/sda vendor: Fanxiang model: S101Q 1TB MX size: 953.87 GiB
speed: 6.0 Gb/s serial: <filter>
ID-7: /dev/sdb vendor: Seagate model: ST1000DM003-1SB102 size: 931.51 GiB
ID-8: /dev/sdc vendor: Fanxiang model: S101Q 1TB MX size: 953.87 GiB
ID-9: /dev/sdd vendor: SanDisk model: SD8TB8U256G1001 size: 238.47 GiB
ID-10: /dev/sde vendor: Seagate model: ST1000DM003-1ER162 size: 931.51 GiB
ID-11: /dev/sdf vendor: Seagate model: ST1000DM003-1ER162 size: 931.51 GiB
ID-12: /dev/sdg vendor: Seagate model: ST1000DM003-1ER162 size: 931.51 GiB
ID-13: /dev/sdh vendor: Seagate model: ST1000DM003-1ER162 size: 931.51 GiB
ID-14: /dev/sdi vendor: Seagate model: ST1000DM003-1ER162 size: 931.51 GiB
ID-15: /dev/sdj vendor: Seagate model: ST1000DM003-1ER162 size: 931.51 GiB
ID-16: /dev/sdk vendor: Seagate model: ST1000DM003-1ER162 size: 931.51 GiB
ID-17: /dev/sdl vendor: Seagate model: ST1000DM003-1ER162 size: 931.51 GiB
ID-18: /dev/sdm vendor: Fanxiang model: S101Q 1TB MX size: 953.87 GiB
ID-19: /dev/sdn vendor: Seagate model: ST1000DM003-1CH162 size: 931.51 GiB
ID-1: / size: 929.51 GiB used: 283.06 GiB (30.5%) fs: btrfs
dev: /dev/nvme1n1p2
ID-2: /boot/efi size: 2 GiB used: 664 KiB (0.0%) fs: vfat
dev: /dev/nvme1n1p1
ID-3: /home size: 929.51 GiB used: 283.06 GiB (30.5%) fs: btrfs
dev: /dev/nvme1n1p2
ID-4: /var/log size: 929.51 GiB used: 283.06 GiB (30.5%) fs: btrfs
dev: /dev/nvme1n1p2
ID-1: swap-1 type: partition size: 238.47 GiB used: 0 KiB (0.0%)
priority: -1 dev: /dev/sdd1
System Temperatures: cpu: 55.0 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 64 GiB available: 62.39 GiB used: 6.87 GiB (11.0%)
Processes: 809 Power: uptime: 7m wakeups: 0 Init: systemd v: 262
default: graphical
Packages: 1449 pm: pacman pkgs: 1387 pm: flatpak pkgs: 62 Compilers:
gcc: 16.2.1 Shell: Bash v: 5.3.20 running-in: konsole inxi: 3.3.41
ddnn
October 17, 2026, 2:44pm
8
Please run the following and post the output here.
pactl list cards | grep -A 30 "Micro Star USB Audio"
pactl list sinks | grep -A 20 "Micro Star USB Audio"
These should give detailed breakdowns of your audio device.
R121
October 17, 2026, 2:47pm
9
it didnt give me any info at all
ddnn
October 17, 2026, 2:48pm
10
Try Micro-Star MSI instead then:
pactl list cards | grep -A 30 "Micro-Star MSI"
pactl list sinks | grep -A 20 "Micro-Star MSI"
Though it really should be the first one.
Also, try this:
pactl list cards short | grep -i "micro"
ddnn
October 17, 2026, 2:57pm
12
Suddenly feel like I’ve gone fishing without a rod…
Let’s try a more direct user settings-based approach.
It’s simple. Create a new user login account and test your audio again.
R121
October 17, 2026, 3:05pm
13
still happens over there yea
R121
October 17, 2026, 3:19pm
14
since you dont seem to have any other ideas, i just reduced the command to usb audio and got this
api.alsa.card.name = "USB Audio"
api.alsa.card.longname = "Generic USB Audio at usb-0000:00:14.0-13, high speed"
device.plugged.usec = "17064166"
device.bus_path = "pci-0000:00:14.0-usb-0:13:1.0"
sysfs.path = "/devices/pci0000:00/0000:00:14.0/usb1/1-13/1-13:1.0/sound/card2"
device.bus-id = "usb-Generic_USB_Audio-00"
device.bus = "usb"
device.subsystem = "sound"
device.vendor.id = "0x0db0"
device.vendor.name = "Micro Star International"
device.product.id = "0x6c09"
device.product.name = "USB Audio"
device.serial = "Generic_USB_Audio"
device.name = "alsa_card.usb-Generic_USB_Audio-00"
device.description = "USB Audio"
device.nick = "USB Audio"
device.icon_name = "audio-card-analog-usb"
api.alsa.use-acp = "true"
api.acp.auto-profile = "false"
api.acp.auto-port = "false"
api.dbus.ReserveDevice1.Priority = "-20"
api.alsa.split-enable = "true"
api.dbus.ReserveDevice1 = "Audio2"
spa.object.id = "6"
factory.id = "15"
client.id = "42"
object.id = "50"
object.serial = "50"
object.path = "alsa:acp:Audio"
alsa.card = "2"
alsa.card_name = "USB Audio"
alsa.long_card_name = "Generic USB Audio at usb-0000:00:14.0-13, high speed"
alsa.driver_name = "snd_usb_audio"
alsa.mixer_name = "USB Mixer"
alsa.components = "USB0db0:6c09"
alsa.id = "Audio"
device.string = "2"
Profiles:
off: Off (sinks: 0, sources: 0, priority: 0, available: yes)
HiFi: HiFi 2.0 channels (sinks: 3, sources: 2, priority: 9000, available: yes)
HiFi 7+1: HiFi 7.1 channels (sinks: 3, sources: 2, priority: 1000, available: yes)
HiFi 5+1: HiFi 5.1 channels (sinks: 3, sources: 2, priority: 1000, available: yes)
pro-audio: Pro Audio (sinks: 4, sources: 3, priority: 1, available: yes)
Active Profile: HiFi
Ports:
[Out] SPDIF: S/PDIF Output (type: SPDIF, priority: 100, latency offset: 0 usec, availability unknown)
Properties:
port.type = "spdif"
device.icon_name = "audio-speakers"
card.profile.port = "0"
Part of profile(s): HiFi 7+1, HiFi 5+1, HiFi
[Out] Speaker: Speakers (type: Speaker, priority: 200, latency offset: 0 usec, availability group: Speaker - Output, available)
Properties:
port.type = "speaker"
port.availability-group = "Speaker - Output"
card.profile.port = "1"
[Out] Headphones: Front Headphones (type: Headphones, priority: 300, latency offset: 0 usec, availability group: Headphone - Output, available)
Properties:
port.type = "headphones"
port.availability-group = "Headphone - Output"
ddnn
October 17, 2026, 3:38pm
15
Okay, now run these as well:
pactl list sinks | grep -A 50 "Name: .*usb.*Audio"
cat /usr/share/alsa/ucm2/usb/0db0:6c09.conf 2>/dev/null || \
cat /usr/share/alsa/ucm2/USB-Audio/USB-Audio.conf | grep -B10 -A30 "0db0:6c09"
R121
October 17, 2026, 3:42pm
16
Description: USB Audio S/PDIF Output
Driver: PipeWire
Sample Specification: s16le 2ch 48000Hz
Channel Map: front-left,front-right
Owner Module: 4294967295
Mute: no
Volume: front-left: 26214 / 40% / -23.88 dB, front-right: 26214 / 40% / -23.88 dB
balance 0.00
Base Volume: 65536 / 100% / 0.00 dB
Monitor Source: alsa_output.usb-Generic_USB_Audio-00.HiFi__SPDIF__sink.monitor
Latency: 0 usec, configured 0 usec
Flags: HARDWARE HW_MUTE_CTRL DECIBEL_VOLUME LATENCY
Properties:
object.path = "alsa:acp:Audio:10:playback"
api.alsa.path = "hw:Audio,3"
api.alsa.open.ucm = "true"
api.alsa.pcm.card = "2"
api.alsa.pcm.stream = "playback"
port.group = "playback"
device.bus = "usb"
audio.channels = "2"
audio.position = "[ FL, FR ]"
device.routes = "1"
alsa.mixer_device = "_ucm0005.hw:Audio"
alsa.resolution_bits = "16"
alsa.card = "2"
alsa.id = "Audio"
device.api = "alsa"
device.class = "sound"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = "USB Audio #3"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "3"
alsa.sync.id = "00000000:00000000:00000000:00000000"
device.profile.name = "HiFi: SPDIF: sink"
device.profile.description = "S/PDIF Output"
card.profile.device = "10"
device.id = "50"
factory.name = "api.alsa.pcm.sink"
node.pause-on-idle = "false"
priority.driver = "796"
priority.session = "796"
Description: USB Audio Speakers
Driver: PipeWire
Sample Specification: s32le 2ch 48000Hz
Mute: no
balance 0.00
Monitor Source: alsa_output.usb-Generic_USB_Audio-00.HiFi__Speaker__sink.monitor
Flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
Properties:
object.path = "alsa:acp:Audio:11:playback"
api.alsa.path = "hw:Audio,0"
device.bus = "usb"
device.routes = "1"
alsa.card = "2"
alsa.id = "Audio"
device.api = "alsa"
alsa.name = "USB Audio"
alsa.device = "0"
device.profile.name = "HiFi: Speaker: sink"
device.profile.description = "Speakers"
card.profile.device = "11"
device.id = "50"
priority.driver = "1100"
priority.session = "1100"
Description: USB Audio Front Headphones
Driver: PipeWire
Mute: no
Volume: front-left: 39322 / 60% / -13.31 dB, front-right: 39322 / 60% / -13.31 dB
balance 0.00
Monitor Source: alsa_output.usb-Generic_USB_Audio-00.HiFi__Headphones__sink.monitor
Properties:
object.path = "alsa:acp:Audio:12:playback"
api.alsa.path = "hw:Audio,1"
device.icon_name = "audio-headphones"
device.bus = "usb"
device.routes = "1"
alsa.card = "2"
alsa.id = "Audio"
device.api = "alsa"
alsa.name = "USB Audio #1"
alsa.device = "1"
device.profile.name = "HiFi: Headphones: sink"
device.profile.description = "Front Headphones"
card.profile.device = "12"
device.id = "50"
priority.driver = "828"
priority.session = "828"
# 0db0:1feb MSI Edge Wifi Z690
# 0db0:3130 MSI PRO X670-P WIFI
# 0db0:36e7 MSI MAG B650I Edge WiFi
# 0db0:419c MSI MPG X570S Carbon Max Wifi
# 0db0:422d MSI Mag B650 Tomahawk Wifi
# 0db0:4240 MSI MAG Z590 Tomahawk Wifi
# 0db0:488c MSI MEG Z790 Ace
# 0db0:4c84 MSI MPG X870I EDGE TI EVO WIFI
# 0db0:543d MSI TRX40 Pro 10G
# 0db0:62a4 MSI MPG Z790I Edge WiFi
# 0db0:6c09 MSI MPG Z790 Carbon Wifi
# 0db0:6cc9 MSI MPG Z590 Gaming Plus
# 0db0:70d3 MSI MPG B650 Carbon Wifi
# 0db0:7696 MSI MAG B650M Mortar Wifi
# 0db0:82c4 MSI MEG Z790 Godlike Max
# 0db0:82c7 MSI MEG Z690I Unify
# 0db0:8af7 MSI MPG Z590 Gaming Force
# 0db0:95bb MSI MEG Z690 Unify
# 0db0:961e MSI MEG X670E ACE
# 0db0:9e6d MSI PRO B650-A WIFI
# 0db0:a073 MSI MAG X570S Torpedo Max
# 0db0:a228 MSI MPG Z590M GAMING EDGE WIFI
# 0db0:a47c MSI MEG X570S Ace Max
# 0db0:a74b MSI MPG Z790 Edge Wifi
# 0db0:b202 MSI MAG Z690 Tomahawk Wifi
# 0db0:cc78 MSI MAG B850M Mortar Wifi
# 0db0:cd0e MSI X870 Tomahawk
# 0db0:d1d7 MSI PRO Z790-A WIFI
# 0db0:d4fa MSI MPG B850I Edge TI Wifi
# 0db0:d6e7 MSI MPG X670E Carbon Wifi
# 0db0:e1f8 MSI MEG X670E Godlike
# 26ce:0a06 ASRock X670E/Z790 Taichi
# 26ce:0a08 ASRock Z790 PG-ITX/TB4, X870 Steel Legend
# 26ce:0a0b ASRock X870E Taichi
Id "((0414:a0(0e|1[0124]))|(0955:cf0a)|(0b05:(19(84|9[69]|ac)|1a(16|2[07]|5[23c]|7a|97|f1)|1b(7c|9b|e1)))|(0db0:(005a|0b58|1(24b|51f|9a2|feb)|3130|36e7|4(19c|22d|240|88c|c84)|543d|62a4|6c[0c]9|70d3|7696|82c[47]|8af7|9(5bb|61e|e6d)|a(073|228|47c|74b)|b202|c(c78|d0e)|d(1d7|4fa|6e7)|e1f8))|(26ce:0a0[68b]))"
Profile "Realtek/ALC4080"
Macro.hp-only.StringMatch "Id='152a:8750' Profile='Common/HeadphonesOnly'"
Macro.hp-tb-dock.StringMatch "Id='03f0:0269' Profile='HP/Thunderbolt-Dock-Audio-Headset'"
middle command didnt do anything
ddnn
October 17, 2026, 3:54pm
17
Everything appears to be okay.
To confirm, have you already tried just messing around with pavucontrol or your DE’s GUI audio settings?
Some more things to check:
dmesg | grep -i "snd_usb\|audio\|usb-audio" | tail -50
aplay -l && aplay -L | grep -A3 "usb.*Audio"
cat /sys/bus/usb/devices/usb*/power/control
R121
October 17, 2026, 3:58pm
18
[ 6.289198] usb 1-13: Product: USB Audio
[ 6.319873] hid-generic 0003:0DB0:6C09.0009: hiddev100,hidraw8: USB HID v1.11 Device [Generic USB Audio] on usb-0000:00:14.0-13/input7
[ 13.163102] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops intel_audio_component_bind_ops [i915])
[ 13.163416] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[ 17.838292] usbcore: registered new interface driver snd-usb-audio
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [VE228]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 3: HDMI 0 [VA26LHDTV10T]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 2: Audio [USB Audio], device 0: USB Audio [USB Audio]
Subdevices: 1/1
card 2: Audio [USB Audio], device 1: USB Audio [USB Audio #1]
Subdevices: 1/1
card 2: Audio [USB Audio], device 2: USB Audio [USB Audio #2]
Subdevices: 1/1
card 2: Audio [USB Audio], device 3: USB Audio [USB Audio #3]
Subdevices: 1/1
usbstream:CARD=Audio
USB Audio
USB Stream Output
usbstream:CARD=C615
auto
auto
auto
auto
auto
auto
and yeah all i can mess with settings wise is the balance(doesnt do anything) or the volume(makes it loud and still bad i guess)
ddnn
October 17, 2026, 4:07pm
19
I mean under “output devices” - do you see any other devices listed? Sometimes just switching between headphones and speakers and back fixes weird issues.
R121
October 17, 2026, 4:16pm
20
yeah a bunch, ive been swapping and comparing and nothing else is broken except the front panel audio, probably because its usb audio which nothing else is
the back panel has a whole sound card smashed into the mobo that they bragged about on the box, that works fine,even can do full surround
all the rest of the output devices are hdmi cables to my displays, like the one to my tv as the third monitor
