Starting a new thread as instructed!
So I recently tried to install endeavor on this older laptop to try it out
It seems to be great aside from audio issues
I tried some of the prior solutions but still the built in speakers do not play anything
pipewire is installed
alsamixer when I bright it up shows the wrong sound card so I pick the correct one and max the volume on everything
put this in the swift5.conf in /etc/modprobe.d/ directory
options snd-intel-dspcfg dsp_driver=1
options snd-hda-intel model=dell-headset-multi
options snd-hda-intel power_save=1
I also tried to install pamac GUI to get the intel sof sound drivers…but I broke something and still only use pamac cli…
anything else I am missing?
No audio stuff is plugged in, a set of headphones plugged in does work, but not the built in speakers. do I need another command line to unmute the speakers ?
some output from audio info center
Sink #564
State: RUNNING
Description: Cannon Point-LP High Definition Audio Controller Speaker
Driver: PipeWire
Sample Specification: s32le 2ch 48000Hz
Channel Map: front-left,front-right
Owner Module: 4294967295
Mute: no
Volume: front-left: 99936 / 152% / 10.99 dB, front-right: 99936 / 152% / 10.99 dB
balance 0.00
Base Volume: 65536 / 100% / 0.00 dB
Monitor Source: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__Speaker__sink.monitor
Latency: 0 usec, configured 0 usec
Flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
Properties:
alsa.card = “0”
alsa.card_name = “sof-hda-dsp”
alsa.class = “generic”
alsa.components = “HDA:8086280b,80860101,00100000 HDA:10ec0256,10251305,00100002 cfg-dmics:2”
alsa.device = “0”
alsa.driver_name = “snd_soc_skl_hda_dsp”
alsa.id = “HDA Analog (*)”
alsa.long_card_name = “WL-SwiftSF515_51T-V1.02-Guinness_WL”
alsa.mixer_device = “_ucm0001.hw:sofhdadsp”
alsa.mixer_name = “Realtek ALC256”
alsa.name = “”
alsa.resolution_bits = “16”
alsa.subclass = “generic-mix”
alsa.subdevice = “0”
alsa.subdevice_name = “subdevice #0”
alsa.sync.id = “00000000:00000000:00000000:00000000”
api.alsa.card.longname = “WL-SwiftSF515_51T-V1.02-Guinness_WL”
api.alsa.card.name = “sof-hda-dsp”
api.alsa.open.ucm = “true”
api.alsa.path = “hw:sofhdadsp”
api.alsa.pcm.card = “0”
api.alsa.pcm.stream = “playback”
audio.channels = “2”
audio.position = “FL,FR”
card.profile.device = “3”
device.api = “alsa”
device.class = “sound”
device.id = “42”
device.profile.description = “Speaker”
device.profile.name = “HiFi: Speaker: sink”
device.routes = “1”
factory.name = “api.alsa.pcm.sink”
media.class = “Audio/Sink”
device.description = “Cannon Point-LP High Definition Audio Controller”
node.name = “alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__Speaker__sink”
node.nick = “Speaker”
node.pause-on-idle = “false”
object.path = “alsa:acp:sofhdadsp:3:playback”
port.group = “playback”
priority.driver = “1000”
priority.session = “1000”
factory.id = “19”
clock.quantum-limit = “8192”
client.id = “41”
node.driver = “true”
node.loop.name = “data-loop.0”
library.name = “audioconvert/libspa-audioconvert”
object.id = “117”
object.serial = “564”
node.max-latency = “4096/48000”
api.alsa.period-size = “1024”
api.alsa.period-num = “8”
api.alsa.headroom = “0”
api.acp.auto-port = “false”
api.acp.auto-profile = “false”
api.alsa.card = “0”
api.alsa.use-acp = “true”
api.dbus.ReserveDevice1 = “Audio0”
api.dbus.ReserveDevice1.Priority = “-20”
device.bus = “pci”
device.bus_path = “pci-0000:00:1f.3-platform-skl_hda_dsp_generic”
device.enum.api = “udev”
device.icon_name = “audio-card-analog-pci”
device.name = “alsa_card.pci-0000_00_1f.3-platform-skl_hda_dsp_generic”
device.nick = “sof-hda-dsp”
device.plugged.usec = “5917057”
device.product.id = “0x9dc8”
device.product.name = “Cannon Point-LP High Definition Audio Controller”
device.subsystem = “sound”
sysfs.path = “/devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0”
device.vendor.id = “0x8086”
device.vendor.name = “Intel Corporation”
device.string = “0”
Ports:
[Out] Speaker: Speaker (type: Speaker, priority: 100, availability unknown)
Active Port: [Out] Speaker
Formats:
pcm
Source #561
State: SUSPENDED
Name: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__HDMI3__sink.monitor
Description: Monitor of Cannon Point-LP High Definition Audio Controller HDMI / DisplayPort 3 Output
Driver: PipeWire
Sample Specification: s24-32le 2ch 48000Hz
Mute: no
Volume: front-left: 65536 / 100% / 0.00 dB, front-right: 65536 / 100% / 0.00 dB
balance 0.00
Monitor of Sink: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__HDMI3__sink
Flags: HARDWARE DECIBEL_VOLUME LATENCY
Properties:
alsa.card = “0”
alsa.device = “5”
alsa.id = “HDMI3 (*)”
alsa.name = “”
api.alsa.path = “hw:sofhdadsp,5”
card.profile.device = “0”
device.api = “alsa”
device.class = “monitor”
device.id = “42”
device.profile.description = “HDMI / DisplayPort 3 Output”
device.profile.name = “HiFi: HDMI3: sink”
device.routes = “1”
node.name = “alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__HDMI3__sink”
node.nick = “HDMI / DisplayPort 3 Output”
object.path = “alsa:acp:sofhdadsp:0:playback”
priority.driver = “664”
priority.session = “664”
factory.id = “19”
client.id = “41”
object.id = “55”
object.serial = “561”
api.alsa.card = “0”
device.bus = “pci”
device.string = “0”
Ports:
[Out] HDMI3: HDMI / DisplayPort 3 Output (type: HDMI, priority: 700, availability group: HDMI/DP,pcm=5, not available)
Active Port: [Out] HDMI3
Formats:
pcm
Have you tried this kernel parameter?
/etc/modprobe.d/swift5.conf
options snd_sof_intel_hda_common hda_model=alc255-acer
https://wiki.archlinux.org/title/Acer_Swift_5
I have, no effect so far.
Did you remove what you previously had there?
Please use code tags around output you post so it is easier for people to read through it.
