So my audio stopped working suddenly after using headphones and after hours of troubleshooting i see in alsamixer that when i plug headphones speakers get automatically muted, but when i unplug them they don’t get unmuted, only headphones get muted. When i plug them again, they don’t unmute.
So system seems to have problem with unmuting speakers/headphones upon plug in or plug out and it keeps only muting stuff.
In alsamixer i have automute disabled. Strange is, when i enable it, it disables automatically when i plug in headphones.
Rebooting didn’t help, also reinstalling kernel, downgrading wireplumber pipewire and alsa, going to lts kernel also didn’t help.
I would be very thankful for any help here
Try this then reboot:
It didn’t work
Are you using an external display?
And what’s the output of: inxi -Fxxc0z
No external display and:
Kernel: 6.13.5-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
Desktop: KDE Plasma v: 6.3.2 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Type: Detachable System: Micro (HK) Tech product: V3 v: N/A
serial:
Mobo: Shenzhen Meigao Equipment model: HPPAC serial:
UEFI: American Megatrends LLC. v: 1.05 date: 04/10/2024
Battery:
ID-1: BATT charge: 21.8 Wh (43.6%) condition: 50.0/51.0 Wh (97.9%)
volts: 11.2 min: 11.6 model: Standard SR Real Battery serial:
status: discharging
Device-1: hid-0018:222A:550D.0004-battery model: PNP0C50:00 222A:550D
serial: N/A charge: N/A status: N/A
Device-2: hidpp_battery_0 model: Logitech MX Ergo Multi-Device Trackball
serial: charge: 55% (should be ignored) status: discharging
Info: 8-core model: AMD Ryzen 7 8840U w/ Radeon 780M Graphics bits: 64
type: MT MCP arch: Zen 4 rev: 2 cache: L1: 512 KiB L2: 8 MiB L3: 16 MiB
Speed (MHz): avg: 1099 min/max: 400/3301 boost: disabled cores: 1: 1099
2: 1099 3: 1099 4: 1099 5: 1099 6: 1099 7: 1099 8: 1099 9: 1099 10: 1099
11: 1099 12: 1099 13: 1099 14: 1099 15: 1099 16: 1099 bogomips: 105410
Device-1: Advanced Micro Devices [AMD/ATI] Phoenix3 driver: amdgpu v: kernel
arch: RDNA-3 pcie: speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: DP-1,
DP-2, DP-3, DP-4, DP-5, DP-6, DP-7, DP-8, Writeback-1 bus-ID: c4:00.0
chip-ID: 1002:1900 temp: 31.0 C
Device-2: Sunplus Innovation Hy-Usb2.0-1 MIC driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 bus-ID: 1-1:2 chip-ID: 1bcf:2ce4
Device-3: Kingcome USB2.0 FHD UVC WebCam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 bus-ID: 3-1:2 chip-ID: 2b7e:c705
Display: wayland server: X.org v: 1.21.1.16 with: Xwayland v: 24.1.6
compositor: kwin_wayland driver: X: loaded: amdgpu unloaded: modesetting
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: 0
Monitor-1: eDP-1 model: BOE Display 0x0b7b res: 2560x1600 hz: 165 dpi: 215
diag: 356mm (14")
API: EGL v: 1.5 platforms: device: 0 drv: radeonsi device: 1 drv: swrast
gbm: drv: kms_swrast surfaceless: drv: radeonsi wayland: drv: radeonsi x11:
drv: radeonsi
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.3.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (radeonsi
gfx1103_r1 LLVM 19.1.7 DRM 3.61 6.13.5-arch1-1) device-ID: 1002:1900
display-ID: :1.0
API: Vulkan v: 1.4.304 surfaces: xcb,xlib,wayland device: 0
type: integrated-gpu driver: N/A device-ID: 1002:1900
de: kscreen-console,kscreen-doctor wl: wayland-info
x11: xdpyinfo, xprop, xrandr
Device-1: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High Definition
Audio driver: snd_hda_intel v: kernel pcie: speed: 16 GT/s lanes: 16
bus-ID: c4:00.1 chip-ID: 1002:1640
Device-2: Advanced Micro Devices [AMD] ACP/ACP3X/ACP6x Audio Coprocessor
driver: snd_pci_ps v: kernel pcie: speed: 16 GT/s lanes: 16 bus-ID: c4:00.5
chip-ID: 1022:15e2
Device-3: Advanced Micro Devices [AMD] Family 17h/19h/1ah HD Audio
bus-ID: c4:00.6 chip-ID: 1022:15e3
Device-4: Sunplus Innovation Hy-Usb2.0-1 MIC driver: uvcvideo type: USB
API: ALSA v: k6.13.5-arch1-1 status: kernel-api
Server-1: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin
Device-1: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak] driver: iwlwifi
v: kernel pcie: speed: 5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:2725
IF: wlan0 state: up mac:
Bluetooth:
Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 bus-ID: 1-5:5 chip-ID: 8087:0032
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: bt-v: 5.3
lmp-v: 12
Local Storage: total: 953.87 GiB used: 55.09 GiB (5.8%)
ID-1: /dev/nvme0n1 vendor: Kingston model: OM8PGP41024Q-A0
size: 953.87 GiB speed: 63.2 Gb/s lanes: 4 serial: temp: 22.9 C
ID-1: / size: 465.25 GiB used: 54.9 GiB (11.8%) fs: ext4 dev: /dev/nvme0n1p7
System Temperatures: cpu: 33.1 C mobo: N/A gpu: amdgpu temp: 31.0 C
Fan Speeds (rpm): N/A
Memory: total: 32 GiB note: est. available: 29.16 GiB used: 2.92 GiB (10.0%)
Processes: 396 Power: uptime: 1m wakeups: 0 Init: systemd v: 257
default: graphical
Packages: 1259 pm: pacman pkgs: 1235 pm: flatpak pkgs: 24 Compilers:
clang: 19.1.7 gcc: 14.2.1 Shell: Bash v: 5.2.37 running-in: konsole
inxi: 3.3.37
Okay, let’s try the LTS kernel. If you already have it installed, just reboot and select it.
If you don’t, you can install it like this: sudo pacman -Syu linux-lts linux-lts-headers
If you have GRUB, then run sudo grub-mkconfig -o /boot/grub/grub.cfg
If you have Systemd-boot, then run sudo reinstall-kernels
Then reboot and select the LTS kernel.
Also, please check if there is a BIOS update available for your system by going to the manufacturer’s website and searching for drivers.
Thank you for your fast answer!
So indeed bios update was availible. I did update it and it didn’t help.
I also bootet LTS like you instructed, which also didn’t help.
I don’t knof if its relevant, but i dual boot with windows and on windows everything works fine.
Hmm. Try running this, but after redoing my first suggestion and rebooting:
systemctl --user restart wireplumber pipewire pipewire-pulse
Or you can do it before just to test it. But if it doesn’t work, redo the first thing, test if things are working, and if not, run the above command.
Did as you said and it’s still not working
Fixed it. As usual it was something i’ve broken myself.
I ended switching to different distro, but the issue persisted, but there i noticed it only came up after i applied the fix for volume control for my pc. The issue and solution is described in this thread for anyone interested:
Thank you ddnn for trying to help me!
