hii guys, for a few days now ive had an issue with my laptop running eos on sound. when i boot my pc up it will run perfectly fine until maybe a minute or two after boot, in which case my speakers stop working and media from most places (eg. youtube, steam, discord video plays but the control bar doesnt move) will freeze up after playing for maybe two frames.
a temporary solution is to go into the kde settings and disable and reenable my sound card (using the intel one, i have an nvidia gpu too so nvidia hda is listed but does nothing) but even that disables itself again after a short while.
my device is the hp envy 15t-ep000, which i learned shortly after buying is pretty infamous for linux compatability specifically in the bios and audio front (bang and olufsen speakers). despite this its been working pretty much perfectly for me since i bought it almost a year ago.
ill attach a copy of the result from inxi -FAZ --no-host | eos-sendlog below but before i do heres the basics:
DE: KDE Plasma
CPU: 11th Gen Intel i7-11800H
GPU1: Intel TigerLake-H GT1 UHD Graphics
GPU2: NVIDIA GeForce RTX 3050 Ti Mobile
Kernel: 6.0.9-zen1-1-zen arch: x86_64 bits: 64 Desktop: KDE Plasma v: 5.26.3
Distro: EndeavourOS
Type: Laptop System: HP product: HP ENVY Laptop 15t-ep000 v: N/A
serial: <superuser required>
Mobo: HP model: 88CD v: 94.20 serial: <superuser required> UEFI: AMI
v: F.10 date: 08/18/2021
Battery:
ID-1: BAT0 charge: 29.1 Wh (41.6%) condition: 70.0/83.1 Wh (84.2%)
Info: 8-core model: 11th Gen Intel Core i7-11800H bits: 64 type: MT MCP
cache: L2: 10 MiB
Speed (MHz): avg: 1682 min/max: 800/4600 cores: 1: 800 2: 2300 3: 2300
4: 801 5: 2864 6: 2300 7: 799 8: 2028 9: 2300 10: 801 11: 2300 12: 800
13: 800 14: 2623 15: 800 16: 2300
Device-1: Intel TigerLake-H GT1 [UHD Graphics] driver: i915 v: kernel
Device-2: NVIDIA GA107M [GeForce RTX 3050 Ti Mobile] driver: nvidia
v: 520.56.06
Device-3: Quanta HP Wide Vision HD Camera type: USB driver: uvcvideo
Display: x11 server: X.Org v: 21.1.4 driver: X: loaded: modesetting,nvidia
dri: iris gpu: i915 resolution: 1920x1080~60Hz
API: OpenGL v: 4.6 Mesa 22.2.3 renderer: Mesa Intel UHD Graphics (TGL GT1)
Device-1: Intel Tiger Lake-H HD Audio driver: sof-audio-pci-intel-tgl
Device-2: NVIDIA driver: snd_hda_intel
Sound API: ALSA v: k6.0.9-zen1-1-zen running: yes
Sound Server-1: PipeWire v: 0.3.60 running: yes
Device-1: Intel Tiger Lake PCH CNVi WiFi driver: iwlwifi
IF: wlan0 state: up mac: cc:15:31:b0:b0:94
Bluetooth:
Device-1: Intel AX201 Bluetooth type: USB driver: btusb
Report: rfkill ID: hci0 state: up address: see --recommends
RAID:
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
Local Storage: total: 623.27 GiB used: 476.96 GiB (76.5%)
ID-1: /dev/mmcblk0 model: ACLCF size: 119.08 GiB
ID-2: /dev/nvme0n1 vendor: Intel model: HBRPEKNX0202AH size: 476.94 GiB
ID-3: /dev/nvme1n1 vendor: Intel model: HBRPEKNX0202AHO size: 27.25 GiB
ID-1: / size: 451.55 GiB used: 386.22 GiB (85.5%) fs: ext4
dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.4 MiB used: 464 KiB (0.2%) fs: vfat
dev: /dev/nvme0n1p1
ID-1: swap-1 type: partition size: 16.8 GiB used: 35.5 MiB (0.2%)
dev: /dev/nvme0n1p3
System Temperatures: cpu: 48.0 C mobo: N/A
Fan Speeds (RPM): cpu: 3003 fan-2: 2811
Processes: 411 Uptime: 25m Memory: 15.27 GiB used: 6.26 GiB (41.0%)
Shell: Bash inxi: 3.3.23
