Audio-Gerät fehlt. Kein Ton. Wie Pipewire reparieren?
Das ist die funktionierende Konfiguration von Pop!_OS (Ubuntu-Basis):
pactl list sinks
Ziel #53
	Status: SUSPENDED
	Beschreibung: Family 17h (Models 00h-0fh) HD Audio Controller Analog Stereo
	Treiber: PipeWire
	Abtastwert-Angabe: s32le 2ch 48000Hz
	Kanalzuordnung: front-left,front-right
	Besitzer-Modul: 4294967295
	Stumm: nein
	Lautstärke: front-left: 31539 /  48% / -19,06 dB,   front-right: 31539 /  48% / -19,06 dB
	        Verteilung 0,00
	Basis-Lautstärke: 65536 / 100% / 0,00 dB
	Quellen-Monitor: alsa_output.pci-0000_10_00.3.analog-stereo.monitor
	Latenz: 0 usec, eingestellt 0 usec
	Flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
	Eigenschaften:
		alsa.card = "1"
		alsa.card_name = "HD-Audio Generic"
		alsa.class = "generic"
		alsa.device = "0"
		alsa.driver_name = "snd_hda_intel"
		alsa.id = "ALC1220 Analog"
		alsa.long_card_name = "HD-Audio Generic at 0xfce00000 irq 150"
		alsa.name = "ALC1220 Analog"
		alsa.resolution_bits = "16"
		alsa.subclass = "generic-mix"
		alsa.subdevice = "0"
		alsa.subdevice_name = "subdevice #0"
		api.alsa.card.longname = "HD-Audio Generic at 0xfce00000 irq 150"
		api.alsa.card.name = "HD-Audio Generic"
		api.alsa.path = "front:1"
		api.alsa.pcm.card = "1"
		api.alsa.pcm.stream = "playback"
		audio.channels = "2"
		audio.position = "FL,FR"
		card.profile.device = "5"
		device.api = "alsa"
		device.class = "sound"
		device.id = "44"
		device.profile.description = "Analog Stereo"
		device.profile.name = "analog-stereo"
		device.routes = "2"
		factory.name = "api.alsa.pcm.sink"
		media.class = "Audio/Sink"
		device.description = "Family 17h (Models 00h-0fh) HD Audio Controller"
		node.name = "alsa_output.pci-0000_10_00.3.analog-stereo"
		node.nick = "ALC1220 Analog"
		node.pause-on-idle = "false"
		object.path = "alsa:pcm:1:front:1:playback"
		priority.driver = "1009"
		priority.session = "1009"
		factory.id = "18"
		clock.quantum-limit = "8192"
		client.id = "34"
		node.driver = "true"
		factory.mode = "merge"
		audio.adapt.follower = ""
		library.name = "audioconvert/libspa-audioconvert"
		object.id = "52"
		object.serial = "53"
		node.max-latency = "16384/48000"
		api.alsa.period-size = "1024"
		api.alsa.period-num = "32"
		api.alsa.headroom = "0"
		api.acp.auto-port = "false"
		api.acp.auto-profile = "false"
		api.alsa.card = "1"
		api.alsa.use-acp = "true"
		api.dbus.ReserveDevice1 = "Audio1"
		device.bus = "pci"
		device.bus_path = "pci-0000:10:00.3"
		device.enum.api = "udev"
		device.icon_name = "audio-card-analog-pci"
		device.name = "alsa_card.pci-0000_10_00.3"
		device.nick = "HD-Audio Generic"
		device.plugged.usec = "9888927"
		device.product.id = "0x1457"
		device.product.name = "Family 17h (Models 00h-0fh) HD Audio Controller"
		device.subsystem = "sound"
		sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:10:00.3/sound/card1"
		device.vendor.id = "0x1022"
		device.vendor.name = "Advanced Micro Devices, Inc. [AMD]"
		device.string = "1"
	Ports:
		analog-output-lineout: Line-Ausgang (Typ: Line, Priorität: 9000, Verfügbarkeitsgruppe: Legacy 4, nicht verfügbar)
		analog-output-headphones: Kopfhörer (Typ: Kopfhörer, Priorität: 9900, Verfügbarkeitsgruppe: Legacy 5, verfügbar)
	Aktiver Port: analog-output-headphones
	Formate:
		pcm
Und so sieht es aus, wenn keine CAM angeschlossen ist (EndeavourOS):
pactl list sinks
Sink #48
	State: SUSPENDED
	Description: Family 17h (Models 00h-0fh) HD Audio Controller Analog Stereo
	Driver: PipeWire
	Sample Specification: s32le 2ch 48000Hz
	Channel Map: front-left,front-right
	Owner Module: 4294967295
	Mute: no
	Volume: front-left: 39346 /  60% / -13,29 dB,   front-right: 39346 /  60% / -13,29 dB
	        balance 0,00
	Base Volume: 65536 / 100% / 0,00 dB
	Monitor Source: alsa_output.pci-0000_10_00.3.analog-stereo.monitor
	Latency: 0 usec, configured 0 usec
	Properties:
		alsa.card = "1"
		alsa.device = "0"
		device.api = "alsa"
		device.id = "41"
		device.routes = "2"
		factory.id = "18"
		client.id = "34"
		object.id = "46"
		object.serial = "48"
		api.alsa.card = "1"
		device.bus = "pci"
		device.plugged.usec = "9226051"
		device.string = "1"
	Ports:
		analog-output-lineout: Line-Ausgang (type: Line, priority: 9000, availability group: Legacy 4, not available)
		analog-output-headphones: Kopfhörer (type: Headphones, priority: 9900, availability group: Legacy 5, available)
	Active Port: analog-output-headphones
	Formats:
		pcm
pactl output ist ja identisch:
Summary
--- /home/build/Documents/alsahoptanzmusik/eos
+++ /home/build/Documents/alsahoptanzmusik/pop
@@ -1,20 +1,20 @@
 pactl list sinks
-Sink #48
-	State: SUSPENDED
+Ziel #53
+	Status: SUSPENDED
-	Description: Family 17h (Models 00h-0fh) HD Audio Controller Analog Stereo
-	Driver: PipeWire
-	Sample Specification: s32le 2ch 48000Hz
-	Channel Map: front-left,front-right
-	Owner Module: 4294967295
-	Mute: no
-	Volume: front-left: 39346 /  60% / -13,29 dB,   front-right: 39346 /  60% / -13,29 dB
-	        balance 0,00
-	Base Volume: 65536 / 100% / 0,00 dB
-	Monitor Source: alsa_output.pci-0000_10_00.3.analog-stereo.monitor
-	Latency: 0 usec, configured 0 usec
+	Beschreibung: Family 17h (Models 00h-0fh) HD Audio Controller Analog Stereo
+	Treiber: PipeWire
+	Abtastwert-Angabe: s32le 2ch 48000Hz
+	Kanalzuordnung: front-left,front-right
+	Besitzer-Modul: 4294967295
+	Stumm: nein
+	Lautstärke: front-left: 31539 /  48% / -19,06 dB,   front-right: 31539 /  48% / -19,06 dB
+	        Verteilung 0,00
+	Basis-Lautstärke: 65536 / 100% / 0,00 dB
+	Quellen-Monitor: alsa_output.pci-0000_10_00.3.analog-stereo.monitor
+	Latenz: 0 usec, eingestellt 0 usec
-	Properties:
+	Eigenschaften:
 		alsa.card = "1"
@@ -37,7 +37,7 @@
 		device.api = "alsa"
-		device.id = "41"
+		device.id = "44"
 		device.routes = "2"
@@ -57,8 +57,8 @@
-		object.id = "46"
-		object.serial = "48"
+		object.id = "52"
+		object.serial = "53"
@@ -74,7 +74,7 @@
-		device.plugged.usec = "9226051"
+		device.plugged.usec = "9888927"
@@ -83,8 +83,8 @@
 		device.string = "1"
 	Ports:
-		analog-output-lineout: Line-Ausgang (type: Line, priority: 9000, availability group: Legacy 4, not available)
-		analog-output-headphones: Kopfhörer (type: Headphones, priority: 9900, availability group: Legacy 5, available)
-	Active Port: analog-output-headphones
-	Formats:
+		analog-output-lineout: Line-Ausgang (Typ: Line, Priorität: 9000, Verfügbarkeitsgruppe: Legacy 4, nicht verfügbar)
+		analog-output-headphones: Kopfhörer (Typ: Kopfhörer, Priorität: 9900, Verfügbarkeitsgruppe: Legacy 5, verfügbar)
+	Aktiver Port: analog-output-headphones
+	Formate:
 		pcm
nur deutsch und englisch eben und ID Nummerierungn sind unterschiedlich was normal ist…
Hey Joe,
habe wahrscheinlich eben die Lösung hier gefunden:
https://wiki.ubuntuusers.de/PulseAudio/#Problembehebung
sudo nano /etc/pulse/client.conf
autospawn = no in autospawn = yes umgeändert.
Dann die USB-CAM eingesteckt & den PC neu gestartet.
PulseAudio-Lautstärkeregler (pavucontrol) zeigt nun wieder Audiogeräte an.
Ich kann auch den Ton (z.B. Musik) hören.
Das Mikro der USB-CAM wird zwar nicht angezeigt, aber zumindest gibt’s generell Ton.
Vielleicht lässt sich sogar noch herausfinden, wie das CAM-Mikro wieder aktiviert wird.
https://wiki.ubuntuusers.de/PulseAudio/#Geraete-werden-nicht-erkannt
Grüße & GN8
Edit: Hat leider doch nicht funktioniert.
War nur der USB-Stecker der CAM nicht richtig eingesteckt.
https://www.freedesktop.org/wiki/Software/PulseAudio/Documentation/User/Running/
„Autospawning“ bedeutet, dass, wenn ein PulseAudio-Client versucht, sich mit dem Server zu verbinden, der Server jedoch nicht läuft, der Server automatisch gestartet wird. Die Funktion ist Teil von libpulse und für Anwendungen völlig transparent, d. h. Anwendungen müssen keine Unterstützung für Autospawnen explizit hinzufügen, Autospawnen wird automatisch als Teil des Verbindungsprozesses jeder PulseAudio-Anwendung durchgeführt.
Autospawning ist die übliche Art, den Server zu starten. Der Server wird gestartet, wenn die erste Anwendung eine Verbindung zu ihm herstellen möchte.
Autospawn kann deaktiviert werden, indem ‘autospawn = no’ in ~/.config/pulse/client.conf oder /etc/pulse/client.conf gesetzt wird. In diesem Fall muss der Server manuell gestartet werden.
frage mich weshalb das denn bei arch default auf autospawn = no gesetzt ist hört sich ja so an als ob es eigentlich andersrum sein müsste…
Hätte mich jetzt auch gewundert… pulseaudio Einstellungen sollten eh nicht wiklich einen Effekt haben…
kann es sein, dass die Soundkarte von einem anderen Prozess belegt ist und nicht benutzt werden kann. Welcher Prozess die Soundkarte belegt, kann mit folgendem Befehl überprüft werden
sudo fuser -v /dev/dsp* /dev/snd/*
wäre interessant einmal mit camera und einmal ohne…
Ja, das hatte ich gestern als Erstes durchgeführt.
Hier ohne CAM:
                     BEN.        PID ZUGR.  BEFEHL
/dev/snd/controlC0:  name       740 F.... wireplumber
/dev/snd/controlC1:  name       740 F.... wireplumber
/dev/snd/seq:        name       739 F.... pipewire
Mit CAM:
keine Ausgabe (Dummy in pavucontrol)
Hier der entsprechende USB-Port (parents weggelassen):
udevadm info -a -p /sys/bus/usb/devices/usb1/1-0:1.0/usb1-port6
Udevadm info starts with the device specified by the devpath and then
walks up the chain of parent devices. It prints for every device
found, all possible attributes in the udev rules key format.
A rule to match, can be composed by the attributes of the device
and the attributes from one single parent device.
  looking at device '/devices/pci0000:00/0000:00:01.3/0000:02:00.0/usb1/1-0:1.0/usb1-port6':
    KERNEL=="usb1-port6"
    SUBSYSTEM==""
    DRIVER==""
    ATTR{connect_type}=="hotplug"
    ATTR{disable}=="0"
    ATTR{location}=="0x80000106"
    ATTR{over_current_count}=="0"
    ATTR{physical_location/dock}=="no"
    ATTR{physical_location/horizontal_position}=="center"
    ATTR{physical_location/lid}=="no"
    ATTR{physical_location/panel}=="left"
    ATTR{physical_location/vertical_position}=="lower"
    ATTR{power/control}=="auto"
    ATTR{power/runtime_active_time}=="357602"
    ATTR{power/runtime_status}=="active"
    ATTR{power/runtime_suspended_time}=="0"
    ATTR{quirks}=="00000000"
    ATTR{waiting_for_supplier}=="0"
Hiermit kann PipeWire im laufenden System neugestartet werden:
killall pipewire-pulse; killall pipewire
Das erleichtert die Analyse enorm.
Meine Block-Regel hatte einen Fehler, nun wird die USB-CAM zumindest erfolgreich geblockt.
Nutzbar ist sie somit aber nicht.
# Do not want low quality webcam mic
SUBSYSTEM=="usb", DRIVER=="snd-usb-audio", ATTRS{idVendor}=="1224", ATTRS{idProduct}=="2a25", ATTR{authorized}="0"
geändert in:
SUBSYSTEM=="usb", ATTRS{idVendor}=="1224", ATTRS{idProduct}=="2a25", ATTR{authorized}="0"
Das hatte ich aus zwei verschiedenen Anleitungen zusammengeführt (merged).
“Weniger” ist manchmal “mehr”. :grinning:
Ich hab die USB-CAM mal an das Notebook mit EndeavourOS gesteckt, welches quasi noch pur ist.
Was soll ich sagen? Das Problem ist auch dort vorhanden.
Liegt dann wahrscheinlich irgendwo an der EndeavourOS-Grundkonfiguration bzw. evtl. im Zusammenspiel mit dieser speziellen USB-CAM (vlt. wegen Mono-Mikro oder Chipsatz?).
Unter Pop!_OS gibt’s nach-wie-vor keine Probleme.
Bleibt also nur das Blacklisten der Kamera als Workaround.
Vielen Dank für die ausdauernde Unterstützung !!
:blush:
Das sieht ja nun wirklich so aus als wenn durch das Aktivieren der Kamera irgendetwas komplet zusammen bricht… entweder Treiber/Hardware seitig oder Audiosystem bezogen…
bei mir sieht das so aus:
[build@XFCE4-build ~]$ sudo fuser -v /dev/dsp* /dev/snd/*
Specified filename /dev/dsp* does not exist.
                     USER        PID ACCESS COMMAND
/dev/snd/controlC0:  build      1432 F.... wireplumber
/dev/snd/controlC1:  build      1432 F.... wireplumber
/dev/snd/seq:        build      1430 F.... pipewire
/dev/snd/controlC2:  build      1432 F.... wireplumber
wenn die cam eingesteckt wird kommt ein Gerät hinzu…
Bei dir schein entweder Pipewire zu crashen oder pipewire-pulse…
Status kann über systemd abgefragt werden:
systemctl --user status pipewire-pulse
Was ich immer mache ist das ich den Kernel log live anschaue wärend ich ein Gerät einstecke:
journalctl -f
und dann dei Kamera einstecken… sieht so aus bei mir:
Dez 16 21:38:42 XFCE4-build kernel: usb 3-4.4: new high-speed USB device number 25 using xhci_hcd
Dez 16 21:38:43 XFCE4-build kernel: usb 3-4.4: New USB device found, idVendor=0c45, idProduct=636d, bcdDevice= 1.00
Dez 16 21:38:43 XFCE4-build kernel: usb 3-4.4: New USB device strings: Mfr=2, Product=1, SerialNumber=3
Dez 16 21:38:43 XFCE4-build kernel: usb 3-4.4: Product: PC-LM1E
Dez 16 21:38:43 XFCE4-build kernel: usb 3-4.4: Manufacturer: PC-LM1E
Dez 16 21:38:43 XFCE4-build kernel: usb 3-4.4: SerialNumber: PC-LM1E
Dez 16 21:38:43 XFCE4-build kernel: usb 3-4.4: Found UVC 1.00 device PC-LM1E (0c45:636d)
Dez 16 21:38:43 XFCE4-build kernel: input: PC-LM1E: PC-LM1E as /devices/pci0000:00/0000:00:08.1/0000:08:00.3/usb3/3-4/3-4.4/3-4.4:1.0/input/input40
Dez 16 21:38:43 XFCE4-build mtp-probe[12861]: checking bus 3, device 25: "/sys/devices/pci0000:00/0000:00:08.1/0000:08:00.3/usb3/3-4/3-4.4"
Dez 16 21:38:43 XFCE4-build mtp-probe[12861]: bus: 3, device: 25 was not an MTP device
Dez 16 21:38:43 XFCE4-build pipewire[1430]: [3:03:08.243848983] [1430]  INFO Camera camera_manager.cpp:299 libcamera v0.0.2
Dez 16 21:38:43 XFCE4-build mtp-probe[12891]: checking bus 3, device 25: "/sys/devices/pci0000:00/0000:00:08.1/0000:08:00.3/usb3/3-4/3-4.4"
Dez 16 21:38:43 XFCE4-build mtp-probe[12891]: bus: 3, device: 25 was not an MTP device
Da ja POP! auf debian basiert sind die Bibliotheken bei arch/eos neuer ebenso die meisten Pakete.
Da ist was audio oder Hardware angeht nicht speziell konfiguriert bei EndeavourOS.
Ja, denke auch, dass da etwas im Argen liegt.
Ich bekomme ja bereits ohne die CAM Fehler angezeigt:
● pipewire-pulse.service - PipeWire PulseAudio
     Loaded: loaded (/usr/lib/systemd/user/pipewire-pulse.service; enabled; preset: enabled)
     Active: active (running) since Fri 2022-12-16 21:10:31 CET; 52min ago
TriggeredBy: ● pipewire-pulse.socket
   Main PID: 755 (pipewire-pulse)
      Tasks: 2 (limit: 38373)
     Memory: 39.2M
        CPU: 601ms
     CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire-pulse.service
             └─755 /usr/bin/pipewire-pulse
Dez 16 21:10:31 eOS systemd[745]: Started PipeWire PulseAudio.
Dez 16 21:10:31 eOS pipewire-pulse[755]: mod.rt: Can't find xdg-portal: (null)
Dez 16 21:10:31 eOS pipewire-pulse[755]: mod.rt: found session bus but no portal
Dez 16 21:10:31 eOS pipewire-pulse[781]: 536870912
● pipewire.service - PipeWire Multimedia Service
     Loaded: loaded (/usr/lib/systemd/user/pipewire.service; enabled; preset: enabled)
TriggeredBy: ● pipewire.socket
   Main PID: 753 (pipewire)
     Memory: 24.7M
        CPU: 2.158s
     CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire.service
             └─753 /usr/bin/pipewire
Dez 16 21:10:31 eOS systemd[745]: Started PipeWire Multimedia Service.
Dez 16 21:10:31 eOS pipewire[753]: mod.rt: Can't find xdg-portal: (null)
Dez 16 21:10:31 eOS pipewire[753]: mod.rt: found session bus but no portal
Dez 16 21:10:31 eOS pipewire[753]: mod.x11-bell: XOpenDisplay() failed
“xdg-portal” wird nicht gefunden. Muss nicht kritisch sein. Kenne mich aber nicht aus.
Und dann noch die Xorg-Glocke.
Im Moment ist die CAM ja angeschlossen, aber deaktiviert.
Deshalb hier eine etwas andere Fehlermeldung (eine weitere folgt nach Neustart ohne Rule):
Dez 16 22:14:03 eOS kernel: usb 5-1: USB disconnect, device number 2
Dez 16 22:14:08 eOS kernel: usb 5-1: new high-speed USB device number 5 using xhci_hcd
Dez 16 22:14:08 eOS kernel: usb 5-1: New USB device found, idVendor=1224, idProduct=2a25, bcdDevice= 1.00
Dez 16 22:14:08 eOS kernel: usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Dez 16 22:14:08 eOS kernel: usb 5-1: Product: USB PHY 2.0
Dez 16 22:14:08 eOS kernel: usb 5-1: Manufacturer: Jieli Technology
Dez 16 22:14:08 eOS kernel: usb 5-1: Found UVC 1.00 device USB PHY 2.0 (1224:2a25)
Dez 16 22:14:08 eOS kernel: usb 5-1: Forcing device quirks to 0x80 by module parameter for testing purpose.
Dez 16 22:14:08 eOS kernel: usb 5-1: Please report required quirks to the linux-media mailing list.
Dez 16 22:14:08 eOS kernel: input: USB PHY 2.0: USB CAMERA as /devices/pci0000:00/0000:00:07.1/0000:0f:00.3/usb5/5-1/5-1:1.0/input/input21
Dez 16 22:14:08 eOS kernel: usb 5-1: set resolution quirk: cval->res = 16
Dez 16 22:14:08 eOS mtp-probe[21478]: checking bus 5, device 5: "/sys/devices/pci0000:00/0000:00:07.1/0000:0f:00.3/usb5/5-1"
Dez 16 22:14:08 eOS mtp-probe[21478]: bus: 5, device: 5 was not an MTP device
Dez 16 22:14:08 eOS systemd-udevd[21477]: 5-1:1.0: /etc/udev/rules.d/90-block-webcam-sound.rules:2 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:07.1/0000:0f:00.3/usb5/5-1/5-1:1.0/authorized}, ignoring: No such file or directory
Dez 16 22:14:08 eOS systemd-udevd[21479]: 5-1:1.1: /etc/udev/rules.d/90-block-webcam-sound.rules:2 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:07.1/0000:0f:00.3/usb5/5-1/5-1:1.1/authorized}, ignoring: No such file or directory
Dez 16 22:14:08 eOS systemd-udevd[21480]: 5-1:1.2: /etc/udev/rules.d/90-block-webcam-sound.rules:2 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:07.1/0000:0f:00.3/usb5/5-1/5-1:1.2/authorized}, ignoring: No such file or directory
Dez 16 22:14:08 eOS systemd-udevd[21481]: 5-1:1.3: /etc/udev/rules.d/90-block-webcam-sound.rules:2 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:07.1/0000:0f:00.3/usb5/5-1/5-1:1.3/authorized}, ignoring: No such file or directory
Dez 16 22:14:08 eOS wireplumber[754]: [1:03:52.188928196] [791] ERROR MediaDevice media_device.cpp:483 /dev/media0[]: Failed to open media device at /dev/media0: Datei oder Verzeichnis nicht gefunden
Dez 16 22:14:08 eOS wireplumber[754]: [1:03:52.188951394] [791]  INFO DeviceEnumerator device_enumerator.cpp:218 Unable to populate media device /dev/media0 (Datei oder Verzeichnis nicht gefunden), skipping
Dez 16 22:14:08 eOS systemd-udevd[21488]: controlC2: /usr/lib/udev/rules.d/78-sound-card.rules:5 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:07.1/0000:0f:00.3/usb5/5-1/5-1:1.2/sound/card2/controlC2/../uevent}, ignoring: No such file or directory
Dez 16 22:14:08 eOS systemd-udevd[21479]: 5-1:1.0: /etc/udev/rules.d/90-block-webcam-sound.rules:2 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:07.1/0000:0f:00.3/usb5/5-1/5-1:1.0/authorized}, ignoring: No such file or directory
Dez 16 22:14:08 eOS systemd-udevd[21486]: 5-1:1.2: /etc/udev/rules.d/90-block-webcam-sound.rules:2 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:07.1/0000:0f:00.3/usb5/5-1/5-1:1.2/authorized}, ignoring: No such file or directory
Dez 16 22:14:08 eOS systemd[745]: Reached target Sound Card.
Dez 16 22:14:08 eOS mtp-probe[21491]: checking bus 5, device 5: "/sys/devices/pci0000:00/0000:00:07.1/0000:0f:00.3/usb5/5-1"
Dez 16 22:14:08 eOS mtp-probe[21491]: bus: 5, device: 5 was not an MTP device
Dez 16 22:14:08 eOS wireplumber[754]: [1:03:52.203675487] [791]  WARN DeviceEnumerator device_enumerator.cpp:282 Media device for node /dev/media0 not found
Dez 16 22:14:08 eOS systemd-udevd[21477]: 5-1:1.1: /etc/udev/rules.d/90-block-webcam-sound.rules:2 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:07.1/0000:0f:00.3/usb5/5-1/5-1:1.1/authorized}, ignoring: No such file or directory
Dez 16 22:14:08 eOS systemd-udevd[21486]: 5-1:1.1: /etc/udev/rules.d/90-block-webcam-sound.rules:2 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:07.1/0000:0f:00.3/usb5/5-1/5-1:1.1/authorized}, ignoring: No such file or directory
Dez 16 22:14:08 eOS systemd-udevd[21493]: 5-1:1.3: /etc/udev/rules.d/90-block-webcam-sound.rules:2 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:07.1/0000:0f:00.3/usb5/5-1/5-1:1.3/authorized}, ignoring: No such file or directory
Dez 16 22:14:08 eOS systemd-udevd[21480]: 5-1:1.3: /etc/udev/rules.d/90-block-webcam-sound.rules:2 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:07.1/0000:0f:00.3/usb5/5-1/5-1:1.3/authorized}, ignoring: No such file or directory
Das hatte ich zusätzlich noch irgendwo konfiguriert: Forcing device quirks to 0x80.
Oder doch nicht, und ich sollte es besser?
Pop!_OS basiert auf Ubuntu, welches auf Debian basiert - ja.
Es nutzt aber teilweise recht neue (eigens gepatchte?) Kernel, momentan 6.0.6 - glaube ich.
Auch die Treiber sind dort mittels PPAs ziemlich aktuell.
Unter Windows gibt’s ebenfalls keine merklichen Fehler.
Sollte also erstmal kein Hardwaredefekt sein. Ist aber Billig-Produktion & davon nochmal 2./3. Ware.
Kann also eine unsaubere Firmware oder (teil)defekte Hardware nicht gänzlich ausschließen.
die Fehler sind normal im moment…
die udev Regel scheint ja nicht wirklich zu funktionieren :wink:
Ah, woran ist das zu erkennen?
(Der Ton ist ja neben einem funktionierenden Pavucontrol schon mal vorhanden mit geblockter CAM.)
Dez 16 22:32:33 eOS systemd-timesyncd[614]: Initial clock synchronization to Fri 2022-12-16 22:32:33.807029 CET.
Dez 16 22:35:03 eOS kernel: usb 5-1: new high-speed USB device number 3 using xhci_hcd
Dez 16 22:35:03 eOS kernel: usb 5-1: New USB device found, idVendor=1224, idProduct=2a25, bcdDevice= 1.00
Dez 16 22:35:03 eOS kernel: usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Dez 16 22:35:03 eOS kernel: usb 5-1: Product: USB PHY 2.0
Dez 16 22:35:03 eOS kernel: usb 5-1: Manufacturer: Jieli Technology
Dez 16 22:35:03 eOS mtp-probe[1822]: checking bus 5, device 3: "/sys/devices/pci0000:00/0000:00:07.1/0000:0f:00.3/usb5/5-1"
Dez 16 22:35:03 eOS mtp-probe[1822]: bus: 5, device: 3 was not an MTP device
Dez 16 22:35:03 eOS kernel: mc: Linux media interface: v0.10
Dez 16 22:35:03 eOS kernel: videodev: Linux video capture interface: v2.00
Dez 16 22:35:03 eOS kernel: usb 5-1: set resolution quirk: cval->res = 16
Dez 16 22:35:03 eOS kernel: usbcore: registered new interface driver snd-usb-audio
Dez 16 22:35:03 eOS kernel: usb 5-1: Found UVC 1.00 device USB PHY 2.0 (1224:2a25)
Dez 16 22:35:03 eOS kernel: usb 5-1: Forcing device quirks to 0x80 by module parameter for testing purpose.
Dez 16 22:35:03 eOS kernel: usb 5-1: Please report required quirks to the linux-media mailing list.
Dez 16 22:35:03 eOS kernel: input: USB PHY 2.0: USB CAMERA as /devices/pci0000:00/0000:00:07.1/0000:0f:00.3/usb5/5-1/5-1:1.0/input/input21
Dez 16 22:35:03 eOS kernel: usbcore: registered new interface driver uvcvideo
Dez 16 22:35:03 eOS mtp-probe[1829]: checking bus 5, device 3: "/sys/devices/pci0000:00/0000:00:07.1/0000:0f:00.3/usb5/5-1"
Dez 16 22:35:03 eOS mtp-probe[1829]: bus: 5, device: 3 was not an MTP device
Dez 16 22:35:03 eOS audit[748]: ANOM_ABEND auid=1000 uid=1000 gid=1001 ses=2 pid=748 comm="wireplumber" exe="/usr/bin/wireplumber" sig=11 res=1
Dez 16 22:35:03 eOS kernel: wireplumber[785]: segfault at 0 ip 00007f8a7fd5344e sp 00007f8a7ef16c80 error 4 in libcamera.so.0.0.2[7f8a7fd0d000+dd000]
Dez 16 22:35:03 eOS kernel: Code: 89 c3 e9 15 dc fb ff 90 0f 1f 40 00 f3 0f 1e fa 41 55 48 8d 05 43 c7 09 00 41 54 55 48 89 fd 48 89 f7 53 48 89 f3 48 83 ec 08 <0f> b6 16 44 8b 66 02 4c 8b 2c d0 ff 15 79 56 0e 00 0f b6 53 01 0f
Dez 16 22:35:03 eOS kernel: audit: type=1701 audit(1671226503.695:78): auid=1000 uid=1000 gid=1001 ses=2 pid=748 comm="wireplumber" exe="/usr/bin/wireplumber" sig=11 res=1
Dez 16 22:35:03 eOS systemd[738]: Reached target Sound Card.
Dez 16 22:35:03 eOS systemd[1]: Created slice Slice /system/systemd-coredump.
Dez 16 22:35:03 eOS audit: BPF prog-id=39 op=LOAD
Dez 16 22:35:03 eOS audit: BPF prog-id=40 op=LOAD
Dez 16 22:35:03 eOS audit: BPF prog-id=41 op=LOAD
Dez 16 22:35:03 eOS kernel: audit: type=1334 audit(1671226503.703:79): prog-id=39 op=LOAD
Dez 16 22:35:03 eOS kernel: audit: type=1334 audit(1671226503.703:80): prog-id=40 op=LOAD
Dez 16 22:35:03 eOS kernel: audit: type=1334 audit(1671226503.703:81): prog-id=41 op=LOAD
Dez 16 22:35:03 eOS systemd[1]: Started Process Core Dump (PID 1840/UID 0).
Dez 16 22:35:03 eOS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@0-1840-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dez 16 22:35:03 eOS kernel: audit: type=1130 audit(1671226503.725:82): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@0-1840-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dez 16 22:35:03 eOS systemd-coredump[1841]: [🡕] Process 748 (wireplumber) of user 1000 dumped core.
                                            Stack trace of thread 785:
                                            #0  0x00007f8a7fd5344e _ZN9libcamera12ControlValueaSERKS0_ (libcamera.so.0.0.2 + 0x8b44e)
                                            #1  0x00007f8a7fd549f7 _ZN9libcamera11ControlInfoC1ENS_4SpanIKNS_12ControlValueELm18446744073709551615EEERS3_ (libcamera.so.0.0.2 + 0x8c9f7)
                                            #2  0x00007f8a7fd7972e _ZN9libcamera10V4L2Device19v4l2MenuControlInfoERK19v4l2_query_ext_ctrl (libcamera.so.0.0.2 + 0xb172e)
                                            #3  0x00007f8a7fd79a95 _ZN9libcamera10V4L2Device15v4l2ControlInfoERK19v4l2_query_ext_ctrl (libcamera.so.0.0.2 + 0xb1a95)
                                            #4  0x00007f8a7fd7b340 _ZN9libcamera10V4L2Device12listControlsEv (libcamera.so.0.0.2 + 0xb3340)
                                            #5  0x00007f8a7fd7b6bd _ZN9libcamera10V4L2Device5setFdENS_8UniqueFDE (libcamera.so.0.0.2 + 0xb36bd)
                                            #6  0x00007f8a7fd7b765 _ZN9libcamera10V4L2Device4openEj (libcamera.so.0.0.2 + 0xb3765)
                                            #7  0x00007f8a7fd95bc2 _ZN9libcamera15V4L2VideoDevice4openEv (libcamera.so.0.0.2 + 0xcdbc2)
                                            #8  0x00007f8a7fdd837c _ZN9libcamera13UVCCameraData4initEPNS_11MediaDeviceE (libcamera.so.0.0.2 + 0x11037c)
                                            #9  0x00007f8a7fdd9018 _ZN9libcamera18PipelineHandlerUVC5matchEPNS_16DeviceEnumeratorE (libcamera.so.0.0.2 + 0x111018)
                                            #10 0x00007f8a7fd4e761 _ZN9libcamera13CameraManager7Private22createPipelineHandlersEv (libcamera.so.0.0.2 + 0x86761)
                                            #11 0x00007f8a7fd5c99c _ZN9libcamera16DeviceEnumerator9addDeviceESt10unique_ptrINS_11MediaDeviceESt14default_deleteIS2_EE (libcamera.so.0.0.2 + 0x9499c)
                                            #12 0x00007f8a7fdd56ea _ZN9libcamera20DeviceEnumeratorUdev13addV4L2DeviceEm (libcamera.so.0.0.2 + 0x10d6ea)
                                            #13 0x00007f8a7fdd5a68 _ZN9libcamera20DeviceEnumeratorUdev13addUdevDeviceEP11udev_device (libcamera.so.0.0.2 + 0x10da68)
                                            #14 0x00007f8a7fdd68b1 _ZN9libcamera20DeviceEnumeratorUdev10udevNotifyEv (libcamera.so.0.0.2 + 0x10e8b1)
                                            #15 0x00007f8a7fcb98ef _ZN9libcamera19EventDispatcherPoll16processNotifiersERKSt6vectorI6pollfdSaIS2_EE (libcamera-base.so.0.0.2 + 0x178ef)
                                            #16 0x00007f8a7fcb9edc _ZN9libcamera19EventDispatcherPoll13processEventsEv (libcamera-base.so.0.0.2 + 0x17edc)
                                            #17 0x00007f8a7fcb7b1f _ZN9libcamera6Thread4execEv (libcamera-base.so.0.0.2 + 0x15b1f)
                                            #18 0x00007f8a7fd4eaf4 _ZN9libcamera13CameraManager7Private3runEv (libcamera.so.0.0.2 + 0x86af4)
                                            #19 0x00007f8a7fad62f3 execute_native_thread_routine (libstdc++.so.6 + 0xd62f3)
                                            #20 0x00007f8a8ee7f8fd n/a (libc.so.6 + 0x868fd)
                                            #21 0x00007f8a8ef00c74 __clone (libc.so.6 + 0x107c74)
                                            Stack trace of thread 748:
                                            #0  0x00007f8a8ef02c77 recvmsg (libc.so.6 + 0x109c77)
                                            #1  0x00007f8a8e3a7fb2 n/a (libpipewire-module-protocol-native.so + 0x2afb2)
                                            #2  0x00007f8a8e390a85 n/a (libpipewire-module-protocol-native.so + 0x13a85)
                                            #3  0x00007f8a8e3911f0 n/a (libpipewire-module-protocol-native.so + 0x141f0)
                                            #4  0x00007f8a8f308ce7 n/a (libspa-support.so + 0x6ce7)
                                            #5  0x00007f8a8f291723 n/a (libwireplumber-0.4.so.0 + 0x1f723)
                                            #6  0x00007f8a8f12787b g_main_context_dispatch (libglib-2.0.so.0 + 0x5587b)
                                            #7  0x00007f8a8f17e299 n/a (libglib-2.0.so.0 + 0xac299)
                                            #8  0x00007f8a8f126ddf g_main_loop_run (libglib-2.0.so.0 + 0x54ddf)
                                            #9  0x000055cf609622fd n/a (wireplumber + 0x22fd)
                                            #10 0x00007f8a8ee1c290 n/a (libc.so.6 + 0x23290)
                                            #11 0x00007f8a8ee1c34a __libc_start_main (libc.so.6 + 0x2334a)
                                            #12 0x000055cf609625f5 n/a (wireplumber + 0x25f5)
                                            Stack trace of thread 766:
                                            #0  0x00007f8a8ef01096 epoll_wait (libc.so.6 + 0x108096)
                                            #1  0x00007f8a8f316789 n/a (libspa-support.so + 0x14789)
                                            #2  0x00007f8a8f308b9b n/a (libspa-support.so + 0x6b9b)
                                            #3  0x00007f8a8f042177 n/a (libpipewire-0.3.so.0 + 0x42177)
                                            #4  0x00007f8a8ee7f8fd n/a (libc.so.6 + 0x868fd)
                                            #5  0x00007f8a8ef00c74 __clone (libc.so.6 + 0x107c74)
                                            Stack trace of thread 774:
                                            #0  0x00007f8a8eef40bf __poll (libc.so.6 + 0xfb0bf)
                                            #1  0x00007f8a8f17e1ff n/a (libglib-2.0.so.0 + 0xac1ff)
                                            #2  0x00007f8a8f126132 g_main_context_iteration (libglib-2.0.so.0 + 0x54132)
                                            #3  0x00007f8a8f126182 n/a (libglib-2.0.so.0 + 0x54182)
                                            #4  0x00007f8a8f154e05 n/a (libglib-2.0.so.0 + 0x82e05)
                                            #5  0x00007f8a8ee7f8fd n/a (libc.so.6 + 0x868fd)
                                            #6  0x00007f8a8ef00c74 __clone (libc.so.6 + 0x107c74)
                                            Stack trace of thread 784:
                                            #2  0x00007f8a8f126ddf g_main_loop_run (libglib-2.0.so.0 + 0x54ddf)
                                            #3  0x00007f8a8ed2c37c n/a (libgio-2.0.so.0 + 0x10a37c)
                                            ELF object binary architecture: AMD x86-64
Dez 16 22:35:03 eOS systemd[1]: systemd-coredump@0-1840-0.service: Deactivated successfully.
Dez 16 22:35:03 eOS kernel: audit: type=1131 audit(1671226503.972:83): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@0-1840-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dez 16 22:35:03 eOS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@0-1840-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dez 16 22:35:03 eOS systemd[738]: wireplumber.service: Main process exited, code=dumped, status=11/SEGV
Dez 16 22:35:03 eOS systemd[738]: wireplumber.service: Failed with result 'core-dump'.
Dez 16 22:35:04 eOS audit: BPF prog-id=0 op=UNLOAD
Dez 16 22:35:04 eOS kernel: audit: type=1334 audit(1671226504.045:84): prog-id=0 op=UNLOAD
Dez 16 22:35:04 eOS kernel: audit: type=1334 audit(1671226504.045:85): prog-id=0 op=UNLOAD
Dez 16 22:35:04 eOS kernel: audit: type=1334 audit(1671226504.045:86): prog-id=0 op=UNLOAD
Dez 16 22:35:04 eOS systemd[738]: wireplumber.service: Scheduled restart job, restart counter is at 1.
Dez 16 22:35:04 eOS systemd[738]: Stopped Multimedia Service Session Manager.
Dez 16 22:35:04 eOS systemd[738]: Started Multimedia Service Session Manager.
Dez 16 22:35:04 eOS rtkit-daemon[752]: Successfully made thread 1876 of process 1876 owned by '1000' high priority at nice level -11.
Dez 16 22:35:04 eOS rtkit-daemon[752]: Supervising 6 threads of 4 processes of 1 users.
Dez 16 22:35:04 eOS rtkit-daemon[752]: Successfully made thread 1878 of process 1876 owned by '1000' RT at priority 20.
Dez 16 22:35:04 eOS rtkit-daemon[752]: Supervising 7 threads of 4 processes of 1 users.
Dez 16 22:35:04 eOS wireplumber[1876]: Failed to set scheduler settings: Die Operation ist nicht erlaubt
Dez 16 22:35:04 eOS wireplumber[1876]: [0:03:14.399629476] [1876]  INFO Camera camera_manager.cpp:299 libcamera v0.0.2
Dez 16 22:35:04 eOS audit[1876]: ANOM_ABEND auid=1000 uid=1000 gid=1001 ses=2 pid=1876 comm="wireplumber" exe="/usr/bin/wireplumber" sig=11 res=1
Dez 16 22:35:04 eOS audit: BPF prog-id=42 op=LOAD
Dez 16 22:35:04 eOS audit: BPF prog-id=43 op=LOAD
Dez 16 22:35:04 eOS audit: BPF prog-id=44 op=LOAD
Dez 16 22:35:04 eOS systemd[1]: Started Process Core Dump (PID 1884/UID 0).
Dez 16 22:35:04 eOS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@1-1884-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dez 16 22:35:04 eOS systemd[1]: systemd-coredump@1-1884-0.service: Deactivated successfully.
Dez 16 22:35:04 eOS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@1-1884-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dez 16 22:35:04 eOS systemd[738]: wireplumber.service: Main process exited, code=dumped, status=11/SEGV
Dez 16 22:35:04 eOS systemd[738]: wireplumber.service: Failed with result 'core-dump'.
Dez 16 22:35:04 eOS systemd[738]: wireplumber.service: Scheduled restart job, restart counter is at 2.
Dez 16 22:35:04 eOS rtkit-daemon[752]: Successfully made thread 1892 of process 1892 owned by '1000' high priority at nice level -11.
Dez 16 22:35:04 eOS rtkit-daemon[752]: Successfully made thread 1894 of process 1892 owned by '1000' RT at priority 20.
Dez 16 22:35:04 eOS wireplumber[1892]: Failed to set scheduler settings: Die Operation ist nicht erlaubt
Dez 16 22:35:04 eOS wireplumber[1892]: [0:03:14.886162493] [1892]  INFO Camera camera_manager.cpp:299 libcamera v0.0.2
Dez 16 22:35:04 eOS audit[1892]: ANOM_ABEND auid=1000 uid=1000 gid=1001 ses=2 pid=1892 comm="wireplumber" exe="/usr/bin/wireplumber" sig=11 res=1
Dez 16 22:35:04 eOS audit: BPF prog-id=45 op=LOAD
Dez 16 22:35:04 eOS audit: BPF prog-id=46 op=LOAD
Dez 16 22:35:04 eOS audit: BPF prog-id=47 op=LOAD
Dez 16 22:35:04 eOS systemd[1]: Started Process Core Dump (PID 1900/UID 0).
Dez 16 22:35:04 eOS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@2-1900-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dez 16 22:35:05 eOS systemd-coredump[1901]: [🡕] Process 1892 (wireplumber) of user 1000 dumped core.
                                            Stack trace of thread 1899:
                                            #0  0x00007f165562144e _ZN9libcamera12ControlValueaSERKS0_ (libcamera.so.0.0.2 + 0x8b44e)
                                            #1  0x00007f16556229f7 _ZN9libcamera11ControlInfoC1ENS_4SpanIKNS_12ControlValueELm18446744073709551615EEERS3_ (libcamera.so.0.0.2 + 0x8c9f7)
                                            #2  0x00007f165564772e _ZN9libcamera10V4L2Device19v4l2MenuControlInfoERK19v4l2_query_ext_ctrl (libcamera.so.0.0.2 + 0xb172e)
                                            #3  0x00007f1655647a95 _ZN9libcamera10V4L2Device15v4l2ControlInfoERK19v4l2_query_ext_ctrl (libcamera.so.0.0.2 + 0xb1a95)
                                            #4  0x00007f1655649340 _ZN9libcamera10V4L2Device12listControlsEv (libcamera.so.0.0.2 + 0xb3340)
                                            #5  0x00007f16556496bd _ZN9libcamera10V4L2Device5setFdENS_8UniqueFDE (libcamera.so.0.0.2 + 0xb36bd)
                                            #6  0x00007f1655649765 _ZN9libcamera10V4L2Device4openEj (libcamera.so.0.0.2 + 0xb3765)
                                            #7  0x00007f1655663bc2 _ZN9libcamera15V4L2VideoDevice4openEv (libcamera.so.0.0.2 + 0xcdbc2)
                                            #8  0x00007f16556a637c _ZN9libcamera13UVCCameraData4initEPNS_11MediaDeviceE (libcamera.so.0.0.2 + 0x11037c)
                                            #9  0x00007f16556a7018 _ZN9libcamera18PipelineHandlerUVC5matchEPNS_16DeviceEnumeratorE (libcamera.so.0.0.2 + 0x111018)
                                            #10 0x00007f165561c761 _ZN9libcamera13CameraManager7Private22createPipelineHandlersEv (libcamera.so.0.0.2 + 0x86761)
                                            #11 0x00007f165561ca17 _ZN9libcamera13CameraManager7Private4initEv (libcamera.so.0.0.2 + 0x86a17)
                                            #12 0x00007f165561cab4 _ZN9libcamera13CameraManager7Private3runEv (libcamera.so.0.0.2 + 0x86ab4)
                                            #13 0x00007f16552d62f3 execute_native_thread_routine (libstdc++.so.6 + 0xd62f3)
                                            #14 0x00007f16585558fd n/a (libc.so.6 + 0x868fd)
                                            #15 0x00007f16585d6c74 __clone (libc.so.6 + 0x107c74)
                                            Stack trace of thread 1894:
                                            #0  0x00007f16585d7096 epoll_wait (libc.so.6 + 0x108096)
                                            #1  0x00007f16589ec789 n/a (libspa-support.so + 0x14789)
                                            #2  0x00007f16589deb9b n/a (libspa-support.so + 0x6b9b)
                                            #3  0x00007f1658718177 n/a (libpipewire-0.3.so.0 + 0x42177)
                                            #4  0x00007f16585558fd n/a (libc.so.6 + 0x868fd)
                                            #5  0x00007f16585d6c74 __clone (libc.so.6 + 0x107c74)
                                            Stack trace of thread 1892:
                                            #0  0x00007f16585524b6 n/a (libc.so.6 + 0x834b6)
                                            #1  0x00007f1658554cd0 pthread_cond_wait (libc.so.6 + 0x85cd0)
                                            #2  0x00007f16552cee81 __gthread_cond_wait (libstdc++.so.6 + 0xcee81)
                                            #3  0x00007f1655618b3c _ZN9libcamera13CameraManager7Private5startEv (libcamera.so.0.0.2 + 0x82b3c)
                                            #4  0x00007f1655619a8e _ZN9libcamera13CameraManager5startEv (libcamera.so.0.0.2 + 0x83a8e)
                                            #5  0x00007f165574141a n/a (libspa-libcamera.so + 0x641a)
                                            #6  0x00007f16557427e2 n/a (libspa-libcamera.so + 0x77e2)
                                            #7  0x00007f165896e5ca n/a (libwireplumber-0.4.so.0 + 0x265ca)
                                            #8  0x00007f16589921b3 wp_transition_advance (libwireplumber-0.4.so.0 + 0x4a1b3)
                                            #9  0x00007f1658977b5a n/a (libwireplumber-0.4.so.0 + 0x2fb5a)
                                            #10 0x00007f16587fd87b g_main_context_dispatch (libglib-2.0.so.0 + 0x5587b)
                                            #11 0x00007f1658854299 n/a (libglib-2.0.so.0 + 0xac299)
                                            #12 0x00007f16587fcddf g_main_loop_run (libglib-2.0.so.0 + 0x54ddf)
                                            #13 0x00005563974fb2fd n/a (wireplumber + 0x22fd)
                                            #14 0x00007f16584f2290 n/a (libc.so.6 + 0x23290)
                                            #15 0x00007f16584f234a __libc_start_main (libc.so.6 + 0x2334a)
                                            #16 0x00005563974fb5f5 n/a (wireplumber + 0x25f5)
                                            Stack trace of thread 1897:
                                            #0  0x00007f16585cf7fd syscall (libc.so.6 + 0x1007fd)
                                            #1  0x00007f165884dc17 g_cond_wait_until (libglib-2.0.so.0 + 0xa5c17)
                                            #2  0x00007f16587cb893 n/a (libglib-2.0.so.0 + 0x23893)
                                            #3  0x00007f16588306cb n/a (libglib-2.0.so.0 + 0x886cb)
                                            #4  0x00007f165882ae05 n/a (libglib-2.0.so.0 + 0x82e05)
                                            #5  0x00007f16585558fd n/a (libc.so.6 + 0x868fd)
                                            #6  0x00007f16585d6c74 __clone (libc.so.6 + 0x107c74)
                                            Stack trace of thread 1896:
                                            #0  0x00007f16585ca0bf __poll (libc.so.6 + 0xfb0bf)
                                            #1  0x00007f16588541ff n/a (libglib-2.0.so.0 + 0xac1ff)
                                            #2  0x00007f16587fc132 g_main_context_iteration (libglib-2.0.so.0 + 0x54132)
                                            #3  0x00007f16587fc182 n/a (libglib-2.0.so.0 + 0x54182)
                                            Stack trace of thread 1898:
                                            #2  0x00007f16587fcddf g_main_loop_run (libglib-2.0.so.0 + 0x54ddf)
                                            #3  0x00007f165840237c n/a (libgio-2.0.so.0 + 0x10a37c)
Dez 16 22:35:05 eOS systemd[1]: systemd-coredump@2-1900-0.service: Deactivated successfully.
Dez 16 22:35:05 eOS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@2-1900-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dez 16 22:35:05 eOS systemd[738]: wireplumber.service: Main process exited, code=dumped, status=11/SEGV
Dez 16 22:35:05 eOS systemd[738]: wireplumber.service: Failed with result 'core-dump'.
Dez 16 22:35:05 eOS audit: BPF prog-id=0 op=UNLOAD
Dez 16 22:35:05 eOS systemd[738]: wireplumber.service: Scheduled restart job, restart counter is at 3.
Dez 16 22:35:05 eOS systemd[738]: Stopped Multimedia Service Session Manager.
Dez 16 22:35:05 eOS systemd[738]: Started Multimedia Service Session Manager.
Dez 16 22:35:05 eOS rtkit-daemon[752]: Successfully made thread 1908 of process 1908 owned by '1000' high priority at nice level -11.
Dez 16 22:35:05 eOS rtkit-daemon[752]: Supervising 6 threads of 4 processes of 1 users.
Dez 16 22:35:05 eOS rtkit-daemon[752]: Successfully made thread 1910 of process 1908 owned by '1000' RT at priority 20.
Dez 16 22:35:05 eOS rtkit-daemon[752]: Supervising 7 threads of 4 processes of 1 users.
Dez 16 22:35:05 eOS wireplumber[1908]: Failed to set scheduler settings: Die Operation ist nicht erlaubt
Dez 16 22:35:05 eOS wireplumber[1908]: [0:03:15.382288548] [1908]  INFO Camera camera_manager.cpp:299 libcamera v0.0.2
Dez 16 22:35:05 eOS audit[1908]: ANOM_ABEND auid=1000 uid=1000 gid=1001 ses=2 pid=1908 comm="wireplumber" exe="/usr/bin/wireplumber" sig=11 res=1
Dez 16 22:35:05 eOS audit: BPF prog-id=48 op=LOAD
Dez 16 22:35:05 eOS audit: BPF prog-id=49 op=LOAD
Dez 16 22:35:05 eOS audit: BPF prog-id=50 op=LOAD
Dez 16 22:35:05 eOS systemd[1]: Started Process Core Dump (PID 1916/UID 0).
Dez 16 22:35:05 eOS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@3-1916-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dez 16 22:35:05 eOS systemd-coredump[1917]: [🡕] Process 1908 (wireplumber) of user 1000 dumped core.
                                            Stack trace of thread 1915:
                                            #0  0x00007f7e66b6d44e _ZN9libcamera12ControlValueaSERKS0_ (libcamera.so.0.0.2 + 0x8b44e)
                                            #1  0x00007f7e66b6e9f7 _ZN9libcamera11ControlInfoC1ENS_4SpanIKNS_12ControlValueELm18446744073709551615EEERS3_ (libcamera.so.0.0.2 + 0x8c9f7)
                                            #2  0x00007f7e66b9372e _ZN9libcamera10V4L2Device19v4l2MenuControlInfoERK19v4l2_query_ext_ctrl (libcamera.so.0.0.2 + 0xb172e)
                                            #3  0x00007f7e66b93a95 _ZN9libcamera10V4L2Device15v4l2ControlInfoERK19v4l2_query_ext_ctrl (libcamera.so.0.0.2 + 0xb1a95)
                                            #4  0x00007f7e66b95340 _ZN9libcamera10V4L2Device12listControlsEv (libcamera.so.0.0.2 + 0xb3340)
                                            #5  0x00007f7e66b956bd _ZN9libcamera10V4L2Device5setFdENS_8UniqueFDE (libcamera.so.0.0.2 + 0xb36bd)
                                            #6  0x00007f7e66b95765 _ZN9libcamera10V4L2Device4openEj (libcamera.so.0.0.2 + 0xb3765)
                                            #7  0x00007f7e66bafbc2 _ZN9libcamera15V4L2VideoDevice4openEv (libcamera.so.0.0.2 + 0xcdbc2)
                                            #8  0x00007f7e66bf237c _ZN9libcamera13UVCCameraData4initEPNS_11MediaDeviceE (libcamera.so.0.0.2 + 0x11037c)
                                            #9  0x00007f7e66bf3018 _ZN9libcamera18PipelineHandlerUVC5matchEPNS_16DeviceEnumeratorE (libcamera.so.0.0.2 + 0x111018)
                                            #10 0x00007f7e66b68761 _ZN9libcamera13CameraManager7Private22createPipelineHandlersEv (libcamera.so.0.0.2 + 0x86761)
                                            #11 0x00007f7e66b68a17 _ZN9libcamera13CameraManager7Private4initEv (libcamera.so.0.0.2 + 0x86a17)
                                            #12 0x00007f7e66b68ab4 _ZN9libcamera13CameraManager7Private3runEv (libcamera.so.0.0.2 + 0x86ab4)
                                            #13 0x00007f7e668d62f3 execute_native_thread_routine (libstdc++.so.6 + 0xd62f3)
                                            #14 0x00007f7e6dc738fd n/a (libc.so.6 + 0x868fd)
                                            #15 0x00007f7e6dcf4c74 __clone (libc.so.6 + 0x107c74)
                                            Stack trace of thread 1910:
                                            #0  0x00007f7e6dcf5096 epoll_wait (libc.so.6 + 0x108096)
                                            #1  0x00007f7e6e10a789 n/a (libspa-support.so + 0x14789)
                                            #2  0x00007f7e6e0fcb9b n/a (libspa-support.so + 0x6b9b)
                                            #3  0x00007f7e6de36177 n/a (libpipewire-0.3.so.0 + 0x42177)
                                            #4  0x00007f7e6dc738fd n/a (libc.so.6 + 0x868fd)
                                            #5  0x00007f7e6dcf4c74 __clone (libc.so.6 + 0x107c74)
                                            Stack trace of thread 1908:
                                            #0  0x00007f7e6dc704b6 n/a (libc.so.6 + 0x834b6)
                                            #1  0x00007f7e6dc72cd0 pthread_cond_wait (libc.so.6 + 0x85cd0)
                                            #2  0x00007f7e668cee81 __gthread_cond_wait (libstdc++.so.6 + 0xcee81)
                                            #3  0x00007f7e66b64b3c _ZN9libcamera13CameraManager7Private5startEv (libcamera.so.0.0.2 + 0x82b3c)
                                            #4  0x00007f7e66b65a8e _ZN9libcamera13CameraManager5startEv (libcamera.so.0.0.2 + 0x83a8e)
                                            #5  0x00007f7e66dbb41a n/a (libspa-libcamera.so + 0x641a)
                                            #6  0x00007f7e66dbc7e2 n/a (libspa-libcamera.so + 0x77e2)
                                            #7  0x00007f7e6e08c5ca n/a (libwireplumber-0.4.so.0 + 0x265ca)
                                            #8  0x00007f7e6e0b01b3 wp_transition_advance (libwireplumber-0.4.so.0 + 0x4a1b3)
                                            #9  0x00007f7e6e095b5a n/a (libwireplumber-0.4.so.0 + 0x2fb5a)
                                            #10 0x00007f7e6df1b87b g_main_context_dispatch (libglib-2.0.so.0 + 0x5587b)
                                            #11 0x00007f7e6df72299 n/a (libglib-2.0.so.0 + 0xac299)
                                            #12 0x00007f7e6df1addf g_main_loop_run (libglib-2.0.so.0 + 0x54ddf)
                                            #13 0x00005625c4a202fd n/a (wireplumber + 0x22fd)
                                            #14 0x00007f7e6dc10290 n/a (libc.so.6 + 0x23290)
                                            #15 0x00007f7e6dc1034a __libc_start_main (libc.so.6 + 0x2334a)
                                            #16 0x00005625c4a205f5 n/a (wireplumber + 0x25f5)
                                            Stack trace of thread 1912:
                                            #0  0x00007f7e6dce80bf __poll (libc.so.6 + 0xfb0bf)
                                            #1  0x00007f7e6df721ff n/a (libglib-2.0.so.0 + 0xac1ff)
                                            #2  0x00007f7e6df1a132 g_main_context_iteration (libglib-2.0.so.0 + 0x54132)
                                            #3  0x00007f7e6df1a182 n/a (libglib-2.0.so.0 + 0x54182)
                                            #4  0x00007f7e6df48e05 n/a (libglib-2.0.so.0 + 0x82e05)
                                            #5  0x00007f7e6dc738fd n/a (libc.so.6 + 0x868fd)
                                            #6  0x00007f7e6dcf4c74 __clone (libc.so.6 + 0x107c74)
                                            Stack trace of thread 1914:
                                            #2  0x00007f7e6df1addf g_main_loop_run (libglib-2.0.so.0 + 0x54ddf)
                                            #3  0x00007f7e6db2037c n/a (libgio-2.0.so.0 + 0x10a37c)
                                            Stack trace of thread 1913:
                                            #0  0x00007f7e6dced7fd syscall (libc.so.6 + 0x1007fd)
                                            #1  0x00007f7e6df6bc17 g_cond_wait_until (libglib-2.0.so.0 + 0xa5c17)
                                            #2  0x00007f7e6dee9893 n/a (libglib-2.0.so.0 + 0x23893)
                                            #3  0x00007f7e6df4e6cb n/a (libglib-2.0.so.0 + 0x886cb)
Dez 16 22:35:05 eOS systemd[1]: systemd-coredump@3-1916-0.service: Deactivated successfully.
Dez 16 22:35:05 eOS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@3-1916-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dez 16 22:35:05 eOS systemd[738]: wireplumber.service: Scheduled restart job, restart counter is at 4.
Dez 16 22:35:05 eOS rtkit-daemon[752]: Successfully made thread 1924 of process 1924 owned by '1000' high priority at nice level -11.
Dez 16 22:35:05 eOS rtkit-daemon[752]: Successfully made thread 1926 of process 1924 owned by '1000' RT at priority 20.
Dez 16 22:35:05 eOS wireplumber[1924]: Failed to set scheduler settings: Die Operation ist nicht erlaubt
Dez 16 22:35:05 eOS wireplumber[1924]: [0:03:15.882019667] [1924]  INFO Camera camera_manager.cpp:299 libcamera v0.0.2
Dez 16 22:35:05 eOS audit[1924]: ANOM_ABEND auid=1000 uid=1000 gid=1001 ses=2 pid=1924 comm="wireplumber" exe="/usr/bin/wireplumber" sig=11 res=1
Dez 16 22:35:05 eOS audit: BPF prog-id=51 op=LOAD
Dez 16 22:35:05 eOS audit: BPF prog-id=52 op=LOAD
Dez 16 22:35:05 eOS audit: BPF prog-id=53 op=LOAD
Dez 16 22:35:05 eOS systemd[1]: Started Process Core Dump (PID 1932/UID 0).
Dez 16 22:35:05 eOS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@4-1932-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dez 16 22:35:06 eOS systemd-coredump[1933]: [🡕] Process 1924 (wireplumber) of user 1000 dumped core.
                                            Stack trace of thread 1931:
                                            #0  0x00007f8c3d5a644e _ZN9libcamera12ControlValueaSERKS0_ (libcamera.so.0.0.2 + 0x8b44e)
                                            #1  0x00007f8c3d5a79f7 _ZN9libcamera11ControlInfoC1ENS_4SpanIKNS_12ControlValueELm18446744073709551615EEERS3_ (libcamera.so.0.0.2 + 0x8c9f7)
                                            #2  0x00007f8c3d5cc72e _ZN9libcamera10V4L2Device19v4l2MenuControlInfoERK19v4l2_query_ext_ctrl (libcamera.so.0.0.2 + 0xb172e)
                                            #3  0x00007f8c3d5cca95 _ZN9libcamera10V4L2Device15v4l2ControlInfoERK19v4l2_query_ext_ctrl (libcamera.so.0.0.2 + 0xb1a95)
                                            #4  0x00007f8c3d5ce340 _ZN9libcamera10V4L2Device12listControlsEv (libcamera.so.0.0.2 + 0xb3340)
                                            #5  0x00007f8c3d5ce6bd _ZN9libcamera10V4L2Device5setFdENS_8UniqueFDE (libcamera.so.0.0.2 + 0xb36bd)
                                            #6  0x00007f8c3d5ce765 _ZN9libcamera10V4L2Device4openEj (libcamera.so.0.0.2 + 0xb3765)
                                            #7  0x00007f8c3d5e8bc2 _ZN9libcamera15V4L2VideoDevice4openEv (libcamera.so.0.0.2 + 0xcdbc2)
                                            #8  0x00007f8c3d62b37c _ZN9libcamera13UVCCameraData4initEPNS_11MediaDeviceE (libcamera.so.0.0.2 + 0x11037c)
                                            #9  0x00007f8c3d62c018 _ZN9libcamera18PipelineHandlerUVC5matchEPNS_16DeviceEnumeratorE (libcamera.so.0.0.2 + 0x111018)
                                            #10 0x00007f8c3d5a1761 _ZN9libcamera13CameraManager7Private22createPipelineHandlersEv (libcamera.so.0.0.2 + 0x86761)
                                            #11 0x00007f8c3d5a1a17 _ZN9libcamera13CameraManager7Private4initEv (libcamera.so.0.0.2 + 0x86a17)
                                            #12 0x00007f8c3d5a1ab4 _ZN9libcamera13CameraManager7Private3runEv (libcamera.so.0.0.2 + 0x86ab4)
                                            #13 0x00007f8c3d2d62f3 execute_native_thread_routine (libstdc++.so.6 + 0xd62f3)
                                            #14 0x00007f8c405328fd n/a (libc.so.6 + 0x868fd)
                                            #15 0x00007f8c405b3c74 __clone (libc.so.6 + 0x107c74)
                                            Stack trace of thread 1924:
                                            #0  0x00007f8c4052f4b6 n/a (libc.so.6 + 0x834b6)
                                            #1  0x00007f8c40531cd0 pthread_cond_wait (libc.so.6 + 0x85cd0)
                                            #2  0x00007f8c3d2cee81 __gthread_cond_wait (libstdc++.so.6 + 0xcee81)
                                            #3  0x00007f8c3d59db3c _ZN9libcamera13CameraManager7Private5startEv (libcamera.so.0.0.2 + 0x82b3c)
                                            #4  0x00007f8c3d59ea8e _ZN9libcamera13CameraManager5startEv (libcamera.so.0.0.2 + 0x83a8e)
                                            #5  0x00007f8c3d70641a n/a (libspa-libcamera.so + 0x641a)
                                            #6  0x00007f8c3d7077e2 n/a (libspa-libcamera.so + 0x77e2)
                                            #7  0x00007f8c4094b5ca n/a (libwireplumber-0.4.so.0 + 0x265ca)
                                            #8  0x00007f8c4096f1b3 wp_transition_advance (libwireplumber-0.4.so.0 + 0x4a1b3)
                                            #9  0x00007f8c40954b5a n/a (libwireplumber-0.4.so.0 + 0x2fb5a)
                                            #10 0x00007f8c407da87b g_main_context_dispatch (libglib-2.0.so.0 + 0x5587b)
                                            #11 0x00007f8c40831299 n/a (libglib-2.0.so.0 + 0xac299)
                                            #12 0x00007f8c407d9ddf g_main_loop_run (libglib-2.0.so.0 + 0x54ddf)
                                            #13 0x0000564c4a0fa2fd n/a (wireplumber + 0x22fd)
                                            #14 0x00007f8c404cf290 n/a (libc.so.6 + 0x23290)
                                            #15 0x00007f8c404cf34a __libc_start_main (libc.so.6 + 0x2334a)
                                            #16 0x0000564c4a0fa5f5 n/a (wireplumber + 0x25f5)
                                            Stack trace of thread 1926:
                                            #0  0x00007f8c405b4096 epoll_wait (libc.so.6 + 0x108096)
                                            #1  0x00007f8c409c9789 n/a (libspa-support.so + 0x14789)
                                            #2  0x00007f8c409bbb9b n/a (libspa-support.so + 0x6b9b)
                                            #3  0x00007f8c406f5177 n/a (libpipewire-0.3.so.0 + 0x42177)
                                            #4  0x00007f8c405328fd n/a (libc.so.6 + 0x868fd)
                                            #5  0x00007f8c405b3c74 __clone (libc.so.6 + 0x107c74)
                                            Stack trace of thread 1930:
                                            #0  0x00007f8c405a70bf __poll (libc.so.6 + 0xfb0bf)
                                            #1  0x00007f8c408311ff n/a (libglib-2.0.so.0 + 0xac1ff)
                                            #2  0x00007f8c407d9ddf g_main_loop_run (libglib-2.0.so.0 + 0x54ddf)
                                            #3  0x00007f8c403df37c n/a (libgio-2.0.so.0 + 0x10a37c)
                                            #4  0x00007f8c40807e05 n/a (libglib-2.0.so.0 + 0x82e05)
                                            #5  0x00007f8c405328fd n/a (libc.so.6 + 0x868fd)
                                            #6  0x00007f8c405b3c74 __clone (libc.so.6 + 0x107c74)
                                            Stack trace of thread 1929:
                                            #0  0x00007f8c405ac7fd syscall (libc.so.6 + 0x1007fd)
                                            #1  0x00007f8c4082ac17 g_cond_wait_until (libglib-2.0.so.0 + 0xa5c17)
                                            #2  0x00007f8c407a8893 n/a (libglib-2.0.so.0 + 0x23893)
                                            #3  0x00007f8c4080d6cb n/a (libglib-2.0.so.0 + 0x886cb)
                                            Stack trace of thread 1928:
                                            #2  0x00007f8c407d9132 g_main_context_iteration (libglib-2.0.so.0 + 0x54132)
                                            #3  0x00007f8c407d9182 n/a (libglib-2.0.so.0 + 0x54182)
Dez 16 22:35:06 eOS systemd[1]: systemd-coredump@4-1932-0.service: Deactivated successfully.
Dez 16 22:35:06 eOS systemd[738]: wireplumber.service: Main process exited, code=dumped, status=11/SEGV
Dez 16 22:35:06 eOS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@4-1932-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dez 16 22:35:06 eOS systemd[738]: wireplumber.service: Failed with result 'core-dump'.
Dez 16 22:35:06 eOS audit: BPF prog-id=0 op=UNLOAD
Dez 16 22:35:06 eOS systemd[738]: wireplumber.service: Scheduled restart job, restart counter is at 5.
Dez 16 22:35:06 eOS systemd[738]: Stopped Multimedia Service Session Manager.
Dez 16 22:35:06 eOS systemd[738]: Started Multimedia Service Session Manager.
Dez 16 22:35:06 eOS rtkit-daemon[752]: Successfully made thread 1943 of process 1943 owned by '1000' high priority at nice level -11.
Dez 16 22:35:06 eOS rtkit-daemon[752]: Supervising 6 threads of 4 processes of 1 users.
Dez 16 22:35:06 eOS rtkit-daemon[752]: Successfully made thread 1945 of process 1943 owned by '1000' RT at priority 20.
Dez 16 22:35:06 eOS rtkit-daemon[752]: Supervising 7 threads of 4 processes of 1 users.
Dez 16 22:35:06 eOS wireplumber[1943]: Failed to set scheduler settings: Die Operation ist nicht erlaubt
Dez 16 22:35:06 eOS wireplumber[1943]: [0:03:16.374379099] [1943]  INFO Camera camera_manager.cpp:299 libcamera v0.0.2
Dez 16 22:35:06 eOS audit[1943]: ANOM_ABEND auid=1000 uid=1000 gid=1001 ses=2 pid=1943 comm="wireplumber" exe="/usr/bin/wireplumber" sig=11 res=1
Dez 16 22:35:06 eOS audit: BPF prog-id=54 op=LOAD
Dez 16 22:35:06 eOS audit: BPF prog-id=55 op=LOAD
Dez 16 22:35:06 eOS audit: BPF prog-id=56 op=LOAD
Dez 16 22:35:06 eOS systemd[1]: Started Process Core Dump (PID 1951/UID 0).
Dez 16 22:35:06 eOS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@5-1951-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dez 16 22:35:06 eOS systemd-coredump[1952]: [🡕] Process 1943 (wireplumber) of user 1000 dumped core.
                                            Stack trace of thread 1950:
                                            #0  0x00007f247678444e _ZN9libcamera12ControlValueaSERKS0_ (libcamera.so.0.0.2 + 0x8b44e)
                                            #1  0x00007f24767859f7 _ZN9libcamera11ControlInfoC1ENS_4SpanIKNS_12ControlValueELm18446744073709551615EEERS3_ (libcamera.so.0.0.2 + 0x8c9f7)
                                            #2  0x00007f24767aa72e _ZN9libcamera10V4L2Device19v4l2MenuControlInfoERK19v4l2_query_ext_ctrl (libcamera.so.0.0.2 + 0xb172e)
                                            #3  0x00007f24767aaa95 _ZN9libcamera10V4L2Device15v4l2ControlInfoERK19v4l2_query_ext_ctrl (libcamera.so.0.0.2 + 0xb1a95)
                                            #4  0x00007f24767ac340 _ZN9libcamera10V4L2Device12listControlsEv (libcamera.so.0.0.2 + 0xb3340)
                                            #5  0x00007f24767ac6bd _ZN9libcamera10V4L2Device5setFdENS_8UniqueFDE (libcamera.so.0.0.2 + 0xb36bd)
                                            #6  0x00007f24767ac765 _ZN9libcamera10V4L2Device4openEj (libcamera.so.0.0.2 + 0xb3765)
                                            #7  0x00007f24767c6bc2 _ZN9libcamera15V4L2VideoDevice4openEv (libcamera.so.0.0.2 + 0xcdbc2)
                                            #8  0x00007f247680937c _ZN9libcamera13UVCCameraData4initEPNS_11MediaDeviceE (libcamera.so.0.0.2 + 0x11037c)
                                            #9  0x00007f247680a018 _ZN9libcamera18PipelineHandlerUVC5matchEPNS_16DeviceEnumeratorE (libcamera.so.0.0.2 + 0x111018)
                                            #10 0x00007f247677f761 _ZN9libcamera13CameraManager7Private22createPipelineHandlersEv (libcamera.so.0.0.2 + 0x86761)
                                            #11 0x00007f247677fa17 _ZN9libcamera13CameraManager7Private4initEv (libcamera.so.0.0.2 + 0x86a17)
                                            #12 0x00007f247677fab4 _ZN9libcamera13CameraManager7Private3runEv (libcamera.so.0.0.2 + 0x86ab4)
                                            #13 0x00007f24764d62f3 execute_native_thread_routine (libstdc++.so.6 + 0xd62f3)
                                            #14 0x00007f24798a28fd n/a (libc.so.6 + 0x868fd)
                                            #15 0x00007f2479923c74 __clone (libc.so.6 + 0x107c74)
                                            Stack trace of thread 1943:
                                            #0  0x00007f247989f4b6 n/a (libc.so.6 + 0x834b6)
                                            #1  0x00007f24798a1cd0 pthread_cond_wait (libc.so.6 + 0x85cd0)
                                            #2  0x00007f24764cee81 __gthread_cond_wait (libstdc++.so.6 + 0xcee81)
                                            #3  0x00007f247677bb3c _ZN9libcamera13CameraManager7Private5startEv (libcamera.so.0.0.2 + 0x82b3c)
                                            #4  0x00007f247677ca8e _ZN9libcamera13CameraManager5startEv (libcamera.so.0.0.2 + 0x83a8e)
                                            #5  0x00007f2476a7741a n/a (libspa-libcamera.so + 0x641a)
                                            #6  0x00007f2476a787e2 n/a (libspa-libcamera.so + 0x77e2)
                                            #7  0x00007f2479cbb5ca n/a (libwireplumber-0.4.so.0 + 0x265ca)
                                            #8  0x00007f2479cdf1b3 wp_transition_advance (libwireplumber-0.4.so.0 + 0x4a1b3)
                                            #9  0x00007f2479cc4b5a n/a (libwireplumber-0.4.so.0 + 0x2fb5a)
                                            #10 0x00007f2479b4a87b g_main_context_dispatch (libglib-2.0.so.0 + 0x5587b)
                                            #11 0x00007f2479ba1299 n/a (libglib-2.0.so.0 + 0xac299)
                                            #12 0x00007f2479b49ddf g_main_loop_run (libglib-2.0.so.0 + 0x54ddf)
                                            #13 0x0000563d2c6002fd n/a (wireplumber + 0x22fd)
                                            #14 0x00007f247983f290 n/a (libc.so.6 + 0x23290)
                                            #15 0x00007f247983f34a __libc_start_main (libc.so.6 + 0x2334a)
                                            #16 0x0000563d2c6005f5 n/a (wireplumber + 0x25f5)
                                            Stack trace of thread 1945:
                                            #0  0x00007f2479924096 epoll_wait (libc.so.6 + 0x108096)
                                            #1  0x00007f2479d39789 n/a (libspa-support.so + 0x14789)
                                            #2  0x00007f2479d2bb9b n/a (libspa-support.so + 0x6b9b)
                                            #3  0x00007f2479a65177 n/a (libpipewire-0.3.so.0 + 0x42177)
                                            #4  0x00007f24798a28fd n/a (libc.so.6 + 0x868fd)
                                            #5  0x00007f2479923c74 __clone (libc.so.6 + 0x107c74)
                                            Stack trace of thread 1948:
                                            #0  0x00007f247991c7fd syscall (libc.so.6 + 0x1007fd)
                                            #1  0x00007f2479b9ac17 g_cond_wait_until (libglib-2.0.so.0 + 0xa5c17)
                                            #2  0x00007f2479b18893 n/a (libglib-2.0.so.0 + 0x23893)
                                            #3  0x00007f2479b7d6cb n/a (libglib-2.0.so.0 + 0x886cb)
                                            #4  0x00007f2479b77e05 n/a (libglib-2.0.so.0 + 0x82e05)
                                            #5  0x00007f24798a28fd n/a (libc.so.6 + 0x868fd)
                                            #6  0x00007f2479923c74 __clone (libc.so.6 + 0x107c74)
                                            Stack trace of thread 1947:
                                            #0  0x00007f24799170bf __poll (libc.so.6 + 0xfb0bf)
                                            #1  0x00007f2479ba11ff n/a (libglib-2.0.so.0 + 0xac1ff)
                                            #2  0x00007f2479b49132 g_main_context_iteration (libglib-2.0.so.0 + 0x54132)
                                            #3  0x00007f2479b49182 n/a (libglib-2.0.so.0 + 0x54182)
                                            Stack trace of thread 1949:
                                            #2  0x00007f2479b49ddf g_main_loop_run (libglib-2.0.so.0 + 0x54ddf)
                                            #3  0x00007f247974f37c n/a (libgio-2.0.so.0 + 0x10a37c)
Dez 16 22:35:06 eOS systemd[1]: systemd-coredump@5-1951-0.service: Deactivated successfully.
Dez 16 22:35:06 eOS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@5-1951-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dez 16 22:35:06 eOS systemd[738]: wireplumber.service: Scheduled restart job, restart counter is at 6.
Dez 16 22:35:06 eOS systemd[738]: wireplumber.service: Start request repeated too quickly.
Dez 16 22:35:06 eOS systemd[738]: Failed to start Multimedia Service Session Manager.
Muss ich meinem Benutzer vielleicht noch mehr Dienste (Groups) hinzufügen?
Zu “input, audio, video” hatte ich in /etc/group bereits “brltty,name” hinzugefügt.
wireplumber crash ,
Nicht fehlerlos meine ich …
Ist der core-dump wichtig (für die weitere Auswertung) oder was empfiehlst Du?
Okay, was gäbe es da zu verbessern?
Bin neu im eOS/Arch-Bereich und muss halt alles immer recherchieren.
Vielleicht die Leerzeichen nach den Kommata weglassen … oder was soll sonst nicht stimmen?
So sieht es unter Pop!_OS aus:
journalctl -f
Dez 16 23:22:16 pop-os-desktop kernel: usb 5-1: new high-speed USB device number 4 using xhci_hcd
Dez 16 23:22:16 pop-os-desktop kernel: usb 5-1: New USB device found, idVendor=1224, idProduct=2a25, bcdDevice= 1.00
Dez 16 23:22:16 pop-os-desktop kernel: usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Dez 16 23:22:16 pop-os-desktop kernel: usb 5-1: Product: USB PHY 2.0
Dez 16 23:22:16 pop-os-desktop kernel: usb 5-1: Manufacturer: Jieli Technology
Dez 16 23:22:16 pop-os-desktop kernel: usb 5-1: Found UVC 1.00 device USB PHY 2.0 (1224:2a25)
Dez 16 23:22:16 pop-os-desktop kernel: input: USB PHY 2.0: USB CAMERA as /devices/pci0000:00/0000:00:07.1/0000:0f:00.3/usb5/5-1/5-1:1.0/input/input21
Dez 16 23:22:16 pop-os-desktop kernel: usb 5-1: set resolution quirk: cval->res = 16
Dez 16 23:22:17 pop-os-desktop mtp-probe[55257]: checking bus 5, device 4: "/sys/devices/pci0000:00/0000:00:07.1/0000:0f:00.3/usb5/5-1"
Dez 16 23:22:17 pop-os-desktop mtp-probe[55257]: bus: 5, device: 4 was not an MTP device
Dez 16 23:22:17 pop-os-desktop systemd[1507]: Reached target Sound Card.
Dez 16 23:22:17 pop-os-desktop /usr/libexec/gdm-x-session[1544]: (II) config/udev: Adding input device USB PHY 2.0: USB CAMERA (/dev/input/event5)
Dez 16 23:22:17 pop-os-desktop /usr/libexec/gdm-x-session[1544]: (**) USB PHY 2.0: USB CAMERA: Applying InputClass "libinput keyboard catchall"
Dez 16 23:22:17 pop-os-desktop /usr/libexec/gdm-x-session[1544]: (II) Using input driver 'libinput' for 'USB PHY 2.0: USB CAMERA'
Dez 16 23:22:17 pop-os-desktop /usr/libexec/gdm-x-session[1544]: (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 81 paused 0
Dez 16 23:22:17 pop-os-desktop /usr/libexec/gdm-x-session[1544]: (**) USB PHY 2.0: USB CAMERA: always reports core events
Dez 16 23:22:17 pop-os-desktop /usr/libexec/gdm-x-session[1544]: (**) Option "Device" "/dev/input/event5"
Dez 16 23:22:17 pop-os-desktop /usr/libexec/gdm-x-session[1544]: (II) event5  - USB PHY 2.0: USB CAMERA: is tagged by udev as: Keyboard
Dez 16 23:22:17 pop-os-desktop /usr/libexec/gdm-x-session[1544]: (II) event5  - USB PHY 2.0: USB CAMERA: device is a keyboard
Dez 16 23:22:17 pop-os-desktop /usr/libexec/gdm-x-session[1544]: (II) event5  - USB PHY 2.0: USB CAMERA: device removed
Dez 16 23:22:17 pop-os-desktop /usr/libexec/gdm-x-session[1544]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:07.1/0000:0f:00.3/usb5/5-1/5-1:1.0/input/input21/event5"
Dez 16 23:22:17 pop-os-desktop /usr/libexec/gdm-x-session[1544]: (II) XINPUT: Adding extended input device "USB PHY 2.0: USB CAMERA" (type: KEYBOARD, id 8)
Dez 16 23:22:17 pop-os-desktop /usr/libexec/gdm-x-session[1544]: (**) Option "xkb_model" "pc105"
Dez 16 23:22:17 pop-os-desktop /usr/libexec/gdm-x-session[1544]: (**) Option "xkb_layout" "de"
Dez 16 23:22:17 pop-os-desktop /usr/libexec/gdm-x-session[1544]: (WW) Option "xkb_variant" requires a string value
Dez 16 23:22:17 pop-os-desktop /usr/libexec/gdm-x-session[1544]: (WW) Option "xkb_options" requires a string value
Dez 16 23:22:17 pop-os-desktop mtp-probe[55285]: checking bus 5, device 4: "/sys/devices/pci0000:00/0000:00:07.1/0000:0f:00.3/usb5/5-1"
Dez 16 23:22:17 pop-os-desktop mtp-probe[55285]: bus: 5, device: 4 was not an MTP device
Sieht doch ziemlich sauber aus, oder?
Ich mach das auch nicht anders… bei arch ändert sich eben auch ständig etwas …
udev Regeln z.B. habe ich mich noch nie worklich mit beschäftigt…
Das zeigt nur das was ich ja schon vorher bemerkt habe das irgendwas crtashed wenn du di Kamera ansteckst. Das ist so gesehen schon mal ne Erkenntnis :wink:
Wenn ich hier schaue sieht dein Format gut aus:
https://wiki.archlinux.org/title/Udev
Beispiel:
/etc/udev/rules.d/83-webcam.rules
KERNEL=="video[0-9]*", SUBSYSTEM=="video4linux", SUBSYSTEMS=="usb", ATTRS{idVendor}=="05a9", ATTRS{idProduct}=="4519", SYMLINK+="video-cam"
Meine auch eher das es eine ganze Menge Fehler auswirft bezogen auf deine Regel… Kann aber auch einen anderen Grund haben… da das Gerät ja weitere Fehler verursacht…
Na ja seltsam schon:
ist ja nun nicht wirklich ein Keyboard…
Wa szeigt denn dein Benutzer für Gruppen an bei eos?
groups
sys games scanner rfkill video storage input disk audio wheel autologin name*
(* username entfernt)
