everytime i turn down my audio i dosent turn down it just kinda muffles the audio ive tried it on the live environment and in hyprland and the same thing happens is there any way to fix this or am i stuck with it?
may be a hardware problem, is your system old?
brand new laptop and the audio works fine on windows
Please check here: https://discovery.endeavouros.com/forum-log-tool-options/how-to-include-systemlogs-in-your-post/2021/03/
When I get to my PC I will send logs sorry Ive been rly busy with work
Kernel: 6.8.4-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
Desktop: Hyprland v: 0.38.1 dm: SDDM Distro: EndeavourOS base: Arch Linux
Type: Laptop System: ASUSTeK product: ROG Zephyrus Duo 16 GX650RM_GX650RM
v: 1.0 serial:
Mobo: ASUSTeK model: GX650RM v: 1.0 serial:
UEFI: American Megatrends LLC. v: GX650RM.319 date: 08/11/2023
Battery:
ID-1: BAT0 charge: 9.1 Wh (10.7%) condition: 84.9/90.0 Wh (94.3%)
volts: 15.9 min: 15.9 model: ASUSTeK ASUS Battery serial: N/A
status: charging
Device-1: hid-0018:04F3:2F31.0002-battery model: ELAN9009:00 04F3:2F31
serial: N/A charge: N/A status: N/A
Info: 8-core model: AMD Ryzen 7 6800H with Radeon Graphics bits: 64
type: MT MCP arch: Zen 3+ rev: 1 cache: L1: 512 KiB L2: 4 MiB L3: 16 MiB
Speed (MHz): avg: 1782 high: 3168 min/max: 400/4785 cores: 1: 3168 2: 3164
3: 400 4: 3168 5: 3168 6: 400 7: 400 8: 3168 9: 400 10: 400 11: 400 12: 400
13: 3167 14: 3166 15: 3158 16: 400 bogomips: 102254
Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: ASUSTeK
driver: nvidia v: 550.67 arch: Ampere pcie: speed: 16 GT/s lanes: 8 ports:
active: none empty: DP-1,DP-2,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:2520
Device-2: AMD Rembrandt [Radeon 680M] vendor: ASUSTeK driver: amdgpu
v: kernel arch: RDNA-2 pcie: speed: 16 GT/s lanes: 16 ports:
active: DP-3,eDP-1 empty: DP-4, DP-5, DP-6, DP-7, DP-8, Writeback-1
bus-ID: 06:00.0 chip-ID: 1002:1681 temp: 43.0 C
Device-3: Quanta USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 bus-ID: 5-1:2 chip-ID: 0408:30c3
Display: wayland server: X.org v: 1.21.1.12 with: Xwayland v: 23.2.6
compositor: Hyprland v: 0.38.1 driver: X: loaded: amdgpu,nvidia
unloaded: modesetting alternate: fbdev,nouveau,nv,vesa dri: radeonsi
gpu: amdgpu display-ID: 1
Monitor-1: DP-3 model: BOE Display 0x0922 res: 1920x550 dpi: 143
diag: 352mm (13.8")
Monitor-2: eDP-1 model: BOE Display 0x0a6d res: 1920x1200 dpi: 141
diag: 407mm (16")
API: EGL v: 1.5 platforms: device: 0 drv: nvidia device: 2 drv: radeonsi
device: 3 drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia wayland:
drv: radeonsi x11: drv: radeonsi inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.67
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3060 Laptop
GPU/PCIe/SSE2
Device-1: NVIDIA GA106 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel pcie: speed: 16 GT/s lanes: 8
bus-ID: 01:00.1 chip-ID: 10de:228e
Device-2: AMD Rembrandt Radeon High Definition Audio driver: snd_hda_intel
v: kernel pcie: speed: 16 GT/s lanes: 16 bus-ID: 06:00.1 chip-ID: 1002:1640
Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: ASUSTeK
driver: snd_pci_acp6x v: kernel pcie: speed: 16 GT/s lanes: 16
bus-ID: 06:00.5 chip-ID: 1022:15e2
Device-4: AMD Family 17h/19h HD Audio vendor: ASUSTeK
bus-ID: 06:00.6 chip-ID: 1022:15e3
API: ALSA v: k6.8.4-arch1-1 status: kernel-api
Server-2: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin
Device-1: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
pcie: speed: 5 GT/s lanes: 1 port: e000 bus-ID: 03:00.0 chip-ID: 10ec:8125
IF: enp3s0 state: down mac:
Device-2: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
vendor: AzureWave ASUS PCE-AXE59BT driver: mt7921e v: kernel pcie:
speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 14c3:7922
IF: wlan0 state: up mac:
Bluetooth:
Device-1: IMC Networks Wireless_Device driver: btusb v: 0.8 type: USB
rev: 2.1 speed: 480 Mb/s lanes: 1 bus-ID: 1-4:3 chip-ID: 13d3:3568
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: bt-v: 5.2
lmp-v: 11
Local Storage: total: 1.86 TiB used: 35.19 GiB (1.8%)
ID-1: /dev/nvme0n1 vendor: TeamGroup model: TM8FPD002T size: 1.86 TiB
speed: 31.6 Gb/s lanes: 4 serial: temp: 30.9 C
ID-1: / size: 1.45 TiB used: 35.16 GiB (2.4%) fs: ext4 dev: /dev/nvme0n1p5
ID-2: /boot/efi size: 96 MiB used: 26.5 MiB (27.7%) fs: vfat
dev: /dev/nvme0n1p1
System Temperatures: cpu: 48.6 C mobo: 30.0 C gpu: amdgpu temp: 43.0 C
Fan Speeds (rpm): cpu: 0
Memory: total: 16 GiB note: est. available: 14.89 GiB used: 3.27 GiB (22.0%)
Processes: 358 Power: uptime: 4m wakeups: 0 Init: systemd v: 255
default: graphical
Packages: pm: pacman pkgs: 1093 Compilers: clang: 17.0.6 gcc: 13.2.1
Shell: fish v: 3.7.1 running-in: kitty inxi: 3.3.33
damn thats a little overkill on info but
may be the culprit here somehow. Maybe by the sole fact its nvidia or maybe your audio out is clogged? check it, but I am unsure if that is the problem. Try to update your drivers if they are available. All the other audio devices may also be the problem but the nvidia audio caught my eye, because everyone knows Linux doesn’t work too well with nvidia stuff.
