I hope someone here can help. I’m sure there are details I will forget or not know, but I’m happy to provide whatever helps.
I’ve just made the switch from Manjaro yesterday. Actually, both my wife and I have.
We have previously had Guild Wars 2 working very well with Lutris.
Now, on her machine when she tries to launch GW2 in Lutris with either a double-click or hitting the “play” button, it either pauses for a moment and the button reverts back from “stop” to “play,” it sits silently doing nothing, or, it kicks up the fan and just sits there without launching until “stop” is clicked.
Trying to help by applying what worked on my laptop, I followed instructions found here to get it going in Steam, which only immediately gives a popup, Failed to launch Guild Wars 2.
I’ve tried many runners, including the above linked GloriousEggroll for both Proton and Lutris, have installed and reinstalled wine-staging, 32 and 64-bit mono and gecko, nvidia drivers, and followed to the letter the directions on the link I shared.
I also read through the pinned guide in this forum.
Funny thing is it worked well on my machine in Proton where Lutris is now not launching it, but neither are working on hers, yet previously both worked great in Lutris.
Can anyone help me get this thing fired up again? Here’s the inxi -Fazi
from her laptop.
inxi -Fazi
Kernel: 5.15.14-1-lts x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-linux-lts
root=UUID=7f45bc25-c4bc-4b92-95cb-e5d1db0c5835 rw quiet loglevel=3
nowatchdog nvme_load=YES
Desktop: GNOME 41.3 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.3
Type: Laptop System: ASUSTeK product: GL552VW v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: GL552VW v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: GL552VW.218 date: 03/16/2016
Battery:
ID-1: BAT0 charge: 34.3 Wh (98.0%) condition: 35.0/48.2 Wh (72.6%)
volts: 14.4 min: 14.4 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: Not charging cycles: 85
Info: model: Intel Core i7-6700HQ bits: 64 type: MT MCP arch: Skylake-S
family: 6 model-id: 0x5E (94) stepping: 3 microcode: 0xEA
Topology: cpus: 1x cores: 4 tpc: 2 threads: 8 smt: enabled cache:
L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 814 high: 900 min/max: 800/3500 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 810
5: 900 6: 806 7: 800 8: 800 bogomips: 41599
Vulnerabilities:
Type: itlb_multihit status: KVM: VMX disabled
Type: l1tf
mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type: spec_store_bypass
mitigation: Speculative Store Bypass disabled via prctl and seccomp
Type: spectre_v1
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional,
IBRS_FW, STIBP: conditional, RSB filling
Type: tsx_async_abort mitigation: TSX disabled
Device-1: Intel HD Graphics 530 vendor: ASUSTeK driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:191b class-ID: 0300
Device-2: NVIDIA GM107M [GeForce GTX 960M] vendor: ASUSTeK driver: nvidia
v: 495.46 alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:139b
class-ID: 0302
Device-3: IMC Networks USB2.0 UVC HD Webcam type: USB driver: uvcvideo
bus-ID: 1-4:3 chip-ID: 13d3:5654 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.21.1.3 compositor: gnome-shell driver:
loaded: modesetting,nvidia display-ID: :1 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.0x11.3")
s-diag: 583mm (23")
Monitor-1: eDP-1-1 res: 1920x1080 hz: 60 dpi: 142
size: 344x194mm (13.5x7.6") diag: 395mm (15.5")
OpenGL: renderer: NVIDIA GeForce GTX 960M/PCIe/SSE2
v: 4.6.0 NVIDIA 495.46 direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170
class-ID: 0403
Sound Server-1: ALSA v: k5.15.14-1-lts running: yes
Sound Server-2: JACK v: 1.9.19 running: no
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.43 running: yes
Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel bus-ID: 02:00.0
chip-ID: 8086:095a class-ID: 0280
IP v4: <filter> type: dynamic noprefixroute scope: global
broadcast: <filter>
IP v6: <filter> type: noprefixroute scope: link
vendor: ASUSTeK driver: r8169 v: kernel port: d000 bus-ID: 03:00.1
chip-ID: 10ec:8168 class-ID: 0200
IF: enp3s0f1 state: down mac: <filter>
WAN IP: <filter>
Bluetooth:
Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8
bus-ID: 1-9:4 chip-ID: 8087:0a2a class-ID: e001
Report: rfkill ID: hci0 rfk-id: 0 state: down bt-service: disabled
Local Storage: total: 1.14 TiB used: 249.61 GiB (21.4%)```
