Arch installation desktop vs xorg
i recently installed arch now going to reinstall it again due to ricing issue but have no idea which profile to choose
  Info: quad core model: Intel Xeon E3-1225 v5 bits: 64 type: MCP cache:
    L2: 1024 KiB
  Speed (MHz): avg: 900 min/max: 800/3700 cores: 1: 900 2: 901 3: 900 4: 900
  Device-1: Intel HD Graphics P530 driver: i915 v: kernel
  Display: x11 server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.0 driver:
    X: loaded: modesetting dri: iris gpu: i915 resolution: 1366x768~60Hz
  API: OpenGL Message: Unable to show GL data. glxinfo is missing.
  Message: No device data found.
  API: ALSA v: k6.9.3-arch1-1 status: kernel-api
  Server-1: PipeWire v: 1.0.7 status: active
  Device-1: Intel Ethernet I219-LM driver: e1000e
  IF: eno1 state: down mac: e0:07:1b:ff:67:90
  Device-2: MediaTek 802.11 n WLAN driver: mt7601u type: USB
  IF: wlan0 state: up mac: 20:e9:17:08:41:43
Bluetooth:
  Device-1: N/A driver: btusb type: USB
  Report: rfkill ID: hci0 rfk-id: 0 state: down bt-service: not found
  Local Storage: total: 465.76 GiB used: 5.7 GiB (1.2%)
  ID-1: /dev/sda vendor: Hitachi model: HDS721050CLA660 size: 465.76 GiB
  ID-1: / size: 19.52 GiB used: 5.24 GiB (26.8%) fs: ext4 dev: /dev/sda2
  ID-2: /boot size: 1022 MiB used: 142.6 MiB (14.0%) fs: vfat dev: /dev/sda1
  ID-3: /home size: 436.71 GiB used: 336.5 MiB (0.1%) fs: ext4
    dev: /dev/sda3
  ID-1: swap-1 type: zram size: 4 GiB used: 0 KiB (0.0%) dev: /dev/zram0
  System Temperatures: cpu: 35.0 C pch: 32.5 C mobo: N/A
  Fan Speeds (rpm): N/A
  Memory: total: 16 GiB note: est. available: 14.57 GiB used: 2.49 GiB (17.1%)
  Processes: 192 Uptime: 1h 21m Shell: Bash inxi: 3.3.34
hope this help well i am new here so please explain in simple terms
I’m guessing you are installing through the archinstall script?
I haven’t used it in a while but if you want to simplify your install I would just choose a Desktop Enviroment (since you are asking this question I think it would be best for you or practice your install in VM til you know what you want)
well i installed from official site of arch but now while ricing most people are suggesting me to use xorg or something by the way from wiki and guide i have try to understand xorg but cant get my brain around it is there a simpler version out there to help me understand xorg
I guess you already checked the wiki regarding display servers ?
https://wiki.archlinux.org/title/General_recommendations#Display_server
Also, I dunno the final goal here, but why don’t you install endeavourOS ? :enos: :enos_flag: :rocketa_purple:
What DE are you using?
