Apply a Clonezilla fix for a Ventoy disk
Some days ago, a Ventoy bug happened which impacted the launching of my Clonezilla isos from my Ventoy disk.
The Ventoy author issued a correction immediately which seems to be successful. However, I am at a loss how to enable it. I need step to step explanations…
Here is the topic. At the end you’ll see the correction published bt the author (38213641710) and the user telling that he successfully applied it..
Hi,
If I am correct, the fix has been merged into master branch, but you have no release yet available.
That means you have to download Master branch (https://github.com/ventoy/Ventoy/tree/refs/heads/master), then follow the “Compile instructions”.
Or wait for the next Release…
Thanks for your explanation. I had seen that the user in this file had solved the problem without understanding how he did it.
So, I’ll wait for Ventoy 1.1.19.
The releases of Ventoy are coming roughly on a three month basis. If the author does not release the new version before november, I’ll just downgrade the package to 1.1.17. which worked well for me.
I think using the CI branch is as easy as downloading the ventoy-linux artifact, extracting and running the executable and updating your USB Drive to it.
This is just what I do not know how to do. Could you give me the commands?
Go into the link ventoy has sent you, scroll down to the Artifacts section and click the download button on the right of the ventoy-linux package.
Thanks.
I went there. 5 Artifacts, among them a ventoy-linux of 18 MB. That I can only “copy” not download and which is an html file, probably to be compiled. Or I miss something?
There’s a download icon on the right.
Not on my computer
That’s because you don’t have a Github account.
OK Thanks
Thanks again to Anilin and all of you.
This is the easiest way to solve this. I now have a Ventoy usb disk which opens again my clonezilla isos.
I do not understand why the author of Ventoy does not publish it and still knowingly let users fall in the 1.1.18 trap. Anyway…
