Application Variety doesn't display in system tray (Plasma 6)
I have been using the application Variety for a number of years. However, since I’ve upgraded to Plasma 6, the icon for Variety no longer displays in the system tray. Is this an issue with Variety or potentially a bug in KDE Plasma 6?
Does it show under the System Tray Settings under Entries at all? If it is what is it set to? Also does the same but occur under and X11 session? (Probably don’t have a solution for you but these are some things to try, I’m off to bed)
Working here:
(wayland)
It doesn’t show under entries. I’ll try in X11.
Is this in a system tray widget in Plasma 6?
Well it displays in the system tray in X11, but not in Wayland.
What happens if you login under Wayland under a new user?
Plasma 6 wayland, yes. Launch variety from a terminal, see if you get any errors.
Launching from terminal will launch fine with no errors and will show in the application tray, it just won’t show in the minimized state in the system tray.
I’ll try with a new user to see if I see the same behavior.
Have you tried delaying it starting? Something like:
#!/bin/bash
sleep 10
variety&
Then run the script in startup.
So no errors launching from terminal. However tonight I was looking at my autostart settings to disable Plasma discover (different issue now).
Now I see this in the auto start details;
2024.06.22 21:16: Failed to load module "appmenu-gtk-module"
    gtk_widget_get_scale_factor: assertion 'GTK_IS_WIDGET (widget)' failed
    WARNING: 2024-06-22 21:16:10,004: create_menu() 'Variety-slideshow not installed.'
is it installed?
I installed it but still get an error:
create_menu() 'Variety Slideshow is not installed. This is an optional extension adding pan and zoom slideshows to Variety"
I can’t find a package for Variety Slideshow.
I get this too, just a warning.
I ended up doing a clean install on new hdd. The variety icon now shows in the system tray. Perhaps it had to do with one of the themes I was using. For now I’m just using the default breeze theme. However what is strange is that prior to the clean install, I created another user, also using breeze them and it would not display. I wish I knew the difference between my old system and this one that led to the difference.
I know I am late to the part but for anyone still having the issue, you just gotta install libappindicator-gtk3 even in plasma and it will start showing.
