Apache Tomcat not working
I installed tomcat10, and the command catalina version is not recognized from the terminal, as it should be. I’m asking for help to set this up, because I really don’t understand what is happening…
Here’s a picture from pamac GUI showing that it is installed (couldn’t check from terminal):
Perhaps you need to start the service?
https://wiki.archlinux.org/title/Tomcat#Start/stop_Tomcat
I thought it would work :frowning:
I found a solution. The script, which should be executable from the terminal can only be executed from its folder. I wrote a shell script, which calls the catalina.sh. The script needs to be added to $PATH and that’s it.
For me the catalina.sh was in /usr/share/tomcat10/bin.
The script:
#/bin/bash
DIRECTORY="/usr/share/tomcat10/bin"
$DIRECTORY/catalina.sh "$@"
