Requires PySimpleGUI from AUR. I used Kate as the example program to launch. The example is from the Cookbook and it crashes.
#!/usr/bin/env python
import sys
import PySimpleGUI as sg
import subprocess
import os
Demo_Toolbar - A floating toolbar with quick launcher
One cool PySimpleGUI demo. Shows borderless windows, grab_anywhere, tight button layout
You can setup a specific program to launch when a button is clicked, or use the
Combobox to select a .py file found in the root folder, and run that file.
ROOT_PATH = './'
def Launcher():
sg.theme('Dark')
namesonly = [f for f in os.listdir(ROOT_PATH) if f.endswith('.py')]
if len(namesonly) == 0:
namesonly = ['test 1', 'test 2', 'test 3']
sg.set_options(element_padding=(0, 0),
button_element_size=(12, 1), auto_size_buttons=False)
layout = [[sg.Combo(values=namesonly, size=(35, 30), key='demofile'),
sg.Button('Run', button_color=('white', '#00168B')),
sg.Button('Program 1'),
sg.Button('Program 2'),
sg.Button('Program 3', button_color=('white', '#35008B')),
sg.Button('EXIT', button_color=('white', 'firebrick3'))],
[sg.Text('', text_color='white', size=(50, 1), key='output')]]
window = sg.Window('Floating Toolbar',
layout,
no_titlebar=True,
grab_anywhere=True,
keep_on_top=True)
# ---===--- Loop taking in user input and executing appropriate program --- #
while True:
event, values = window.read()
if event == 'EXIT' or event == sg.WIN_CLOSED:
break # exit button clicked
if event == 'Program 1':
subprocess.Popen(["kate"], shell=True, stdout=subprocess.PIPE, stderr=subprocess.PIPE)
elif event == 'Program 2':
print('Run your program 2 here!')
elif event == 'Run':
file = values['demofile']
print('Launching %s' % file)
ExecuteCommandSubprocess('python', os.path.join(ROOT_PATH, file))
else:
print(event)
window.close()
def ExecuteCommandSubprocess(command, *args, wait=False):
try:
if sys.platform == 'linux':
arg_string = ''
arg_string = ' '.join([str(arg) for arg in args])
# for arg in args:
# arg_string += ' ' + str(arg)
print('python3 ' + arg_string)
sp = subprocess.Popen(['python3 ', arg_string],
shell=True,
else:
sp = subprocess.Popen([command, arg_string],
shell=True,
# sp = subprocess.Popen([command, list(args)], shell=True, stdout=subprocess.PIPE, stderr=subprocess.PIPE)
if wait:
out, err = sp.communicate()
if out:
print(out.decode("utf-8"))
if err:
print(err.decode("utf-8"))
except:
pass
if __name__ == '__main__':
Launcher()
Just change kate to any GUI program you have. Kate is on the program 1 button, let it open, close it and the gui crashes when you click another button. Have opened an issue on their Github page, but additional confirmation would be good.
